GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
bae17b76
bae17b76
MARCHE Claude
new option -q for replayer, prints only warnings
allows to show the warnings in the nightly bench
efec0bde
9
9 changed files
37 additions
15 deletions
+37
-15
CHANGES
CHANGES
+2
ROADMAP
ROADMAP
+11
-1
doc/manpages.tex
doc/manpages.tex
+1
examples/hoare_logic/blocking_semantics5.mlw
+1
-1
examples/hoare_logic/blocking_semantics5/why3session.xml
+1
-1
examples/regtests.sh
+2
-2
src/ide/replay.ml
src/ide/replay.ml
+14
-9
src/session/session_scheduler.ml
+4
-1
src/session/session_scheduler.mli
+1
CHANGES
bae17b76
* marks an incompatible change
o new warning: form exists x, P -> Q
o [replayer] new option -q
o [Provers] support for Coq 8.4
o New scheme for Coq realizations, using type classes
ROADMAP
bae17b76
@@ -132,14 +132,20 @@ scheduled on Sep 2012
New features:
o new API for programs
o type invariants ?
o type invariants
o transformations for induction
o Support for Coq 8.4
o dropped support for Coq 8.2
o new scheme for Coq realizations using type classes
o Support for PVS 6.0, including realizations
o support for iProver and Zenon
o a warning is emitted for unused bound logic variables in
"forall", "exists" and "let"
o new warning: formulas of the form "exists x, P -> Q"
Bug fixes:
@@ -190,6 +196,10 @@ Bug fixes:
== TODOs ==
* faire le menage dans les transformations d'induction : _int _ty
_ty_lex, et DOCUMENTER
* Sortie PVS
** avec mecanisme de realization
doc/manpages.tex
bae17b76
@@ -528,6 +528,7 @@ option \verb|-force| described below.
\item
The exit code is 0 if no difference was detected, 1 if there
was. Other exit codes mean some failure in running the replay.
\item
Option
\verb
-s
suppresses the output of the final tree view.
\item
Option
\verb
-q
runs quietly (no progress info)
\item
Option
\texttt
-I
\textsl
<path>
adds
\texttt
\textsl
<path>
to the loadpath.
\item
Option
\verb
-force
enforces saving the session, if all proof
attempts replayed correctly, even if some goals are not proved.
bae17b76
@@ -711,7 +711,7 @@ function wp (s:stmt) (q:fmla) : fmla =
(** {3 main soundness result} *)
lemma wp_soundness:
forall n
:int, sigma sigma':env, pi pi':stack, s s':stmt,
forall n:int, sigma sigma':env, pi pi':stack, s s':stmt,
sigmat: type_env, pit: type_stack, q:fmla.
compatible_env sigma sigmat pi pit ->
type_stmt sigmat pit s ->
bae17b76
@@ -2734,7 +2734,7 @@
edited=
"blocking_semantics5_WP_wp_soundness_1.v"
obsolete=
"false"
archived=
"false"
<result
status=
"valid"
time=
"0.
83
<result
status=
"valid"
time=
"0.
70
</proof>
</goal>
</theory>
bae17b76
@@ -32,7 +32,7 @@ run_dir () {
for
f
in
ls
$1
/why3session.xml
do
d
dirname
$f
echo
-n
"Replaying
$d
../bin/why3replayer.opt
$REPLAYOPT
$2
$d
2>
$TMPERR
$TMP
-q
$REPLAYOPT
$2
$d
2>
$TMPERR
$TMP
ret
if
test
$ret
"0"
then
echo
-n
"FAILED (ret code=
$ret
@@ -46,7 +46,7 @@ run_dir () {
res
else
echo
-n
"OK"
cat
$TMP
cat
$TMP
$TMPERR
success
expr
$success
+ 1
fi
total
expr
$total
+ 1
src/ide/replay.ml
bae17b76
@@ -30,6 +30,7 @@ let opt_stats = ref true
let
opt_force
ref
false
let
opt_obsolete_only
ref
false
let
opt_bench
ref
false
let
opt_verbose
ref
true
(** {2 Smoke detector} *)
@@ -83,6 +84,9 @@ let spec = Arg.align [
"-s"
Arg
Clear
opt_stats
" do not print statistics"
"-q"
Arg
Clear
opt_verbose
" run quietly"
"-v"
Arg
Set
opt_version
" print version information"
@@ -301,7 +305,7 @@ let same_result r1 r2 =
let
add_to_check_no_smoke
config
found_obs
env_session
sched
let
session
env_session
S
session
in
let
callback
report
eprintf
if
opt_verbose
then
eprintf
let
files
n
m
S
PHstr
fold
file_statistics
session
S
session_files
@@ -329,12 +333,12 @@ session NOT updated)@." n m
else
printf
" %d/%d@."
n
m
if
opt_stats
n
m
then
print_statistics
files
eprintf
"Everything replayed OK.@."
if
opt_verbose
then
eprintf
if
found_obs
n
m
opt_force
then
begin
eprintf
"Saving session...@?"
if
opt_verbose
then
eprintf
S
save_session
config
session
eprintf
" done@."
if
opt_verbose
then
eprintf
" done@."
exit
@@ -351,7 +355,7 @@ session NOT updated)@." n m
let
add_to_check_smoke
env_session
sched
let
callback
report
eprintf
if
opt_verbose
then
eprintf
let
report
filter
function
@@ -362,7 +366,7 @@ let add_to_check_smoke env_session sched =
_
false
report
in
if
report
then
begin
eprintf
"No smoke detected.@."
if
opt_verbose
then
eprintf
exit
else
begin
@@ -417,15 +421,16 @@ let run_as_bench env_session =
let
try
eprintf
"Opening session...@?"
if
opt_verbose
then
eprintf
O
verbose
opt_verbose
let
env_session
found_obs
let
session
S
read_session
project_dir
in
update_session
allow_obsolete
true
session
env
config
in
eprintf
" done.@."
if
opt_verbose
then
eprintf
" done.@."
if
opt_obsolete_only
not
found_obs
then
begin
eprintf
"Session is not obsolete, hence no replayed@."
eprintf
t
replayed@."
printf
exit
bae17b76
@@ -992,6 +992,8 @@ module Base_scheduler (X : sig end) =
let
idle_handler
ref
None
let
timeout_handler
ref
None
let
verbose
ref
true
let
idle
f
match
idle_handler
None
idle_handler
Some
f
@@ -1003,7 +1005,8 @@ module Base_scheduler (X : sig end) =
Some
_
failwith
"Replay.timeout: already one handler installed"
let
notify_timer_state
w
s
r
Printf
eprintf
"Progress: %d/%d/%d
\r
w
s
r
if
verbose
then
Printf
eprintf
"Progress: %d/%d/%d
\r
w
s
r
let
main_loop
let
last
ref
Unix
gettimeofday
in
bae17b76
@@ -265,6 +265,7 @@ module Base_scheduler (X : sig end) : sig
val
timeout
ms
int
unit
bool
unit
val
idle
unit
bool
unit
val
verbose
bool
ref
val
notify_timer_state
int
int
int
unit
(** These functions have the properties required by OBSERVER *)
