Commit ba85effc authored by Andrei Paskevich's avatar Andrei Paskevich
whyml: value tracking for invariants (in progress)
parent 20f70cfe
...@@ -368,6 +368,85 @@ let quantify env regs f = ...@@ -368,6 +368,85 @@ let quantify env regs f =
let f = Mvs.fold update vars (subst_at_now true vv' f) in let f = Mvs.fold update vars (subst_at_now true vv' f) in
wp_forall (List.rev (Mreg.values mreg)) f wp_forall (List.rev (Mreg.values mreg)) f
(* value tracking *)
type point = int
type value = point list Mls.t (* constructor -> field list *)
type state = {
kn : Decl.known_map;
memory : (point, value) Hashtbl.t;
next : point ref;
type names = point Mvs.t
let empty_state kn = {
kn = kn;
memory = Hashtbl.create 5;
next = ref 0;
let next_point state =
let res = !(state.next) in incr state.next; res
let get_ts = function
| Some { ty_node = Tyapp (ts,_) } -> ts
| _ -> assert false
let make_value state csl =
let get_p _ = next_point state in
let new_cs cs = List.map get_p cs.ls_args in
let add_cs m (cs,_) = Mls.add cs (new_cs cs) m in
List.fold_left add_cs Mls.empty csl
let match_point state csl p =
try Hashtbl.find state.memory p with Not_found ->
let value = make_value state csl in
Hashtbl.replace state.memory p value;
value
let rec point_of_term state names t = match t.t_node with
| Tvar vs ->
Mvs.find vs names
| Tapp (ls, tl) ->
begin match Mid.find ls.ls_name state.kn with
| { Decl.d_node = Decl.Ddata tdl } ->
let is_cs (cs,_) = ls_equal ls cs in
let is_cs (_,csl) = List.exists is_cs csl in
if List.exists is_cs tdl
then point_of_constructor state names ls tl
else point_of_projection state names ls (List.hd tl)
| _ -> next_point state
| Tlet (t1, bt) ->
let p = point_of_term state names t1 in
let v, t2 = t_open_bound bt in
let names = Mvs.add v p names in
point_of_term state names t2
(* | Tcase _ when Slab.mem update_lab t.t_label -> *)
| Tcase (_t1,[_b]) -> assert false (* TODO *)
| Tconst _ | Tif _ | Tcase _ | Teps _ -> next_point state
| Tquant _ | Tbinop _ | Tnot _ | Ttrue | Tfalse -> assert false
and point_of_constructor state names ls tl =
let csl = Decl.find_constructors state.kn (get_ts ls.ls_value) in
let pl = List.map (point_of_term state names) tl in
let value = Mls.add ls pl (make_value state csl) in
let p = next_point state in
p
and point_of_projection state names ls t1 =
match Decl.find_constructors state.kn (get_ts t1.t_ty) with
| [cs,pjl] as csl ->
let p1 = point_of_term state names t1 in
let value = match_point state csl p1 in
let rec find_p pjl pl = match pjl, pl with
| Some pj::_, p::_ when ls_equal ls pj -> p
| _::pjl, _::pl -> find_p pjl pl
| _ -> assert false in
find_p pjl (Mls.find cs value)
| _ -> next_point state (* more than one, can't choose *)
(* invariants *) (* invariants *)
let get_invariant kn v = let get_invariant kn v =
