Attention une mise à jour du serveur va être effectuée le vendredi 16 avril entre 12h et 12h30. Cette mise à jour va générer une interruption du service de quelques minutes.
Commit b990765c authored by Kim Nguyễn's avatar Kim Nguyễn
[trywhy3] : implement highlighting of the portion of the source code corresponding to a task.
parent 01d006fa
...@@ -2,46 +2,8 @@ ...@@ -2,46 +2,8 @@
var editor = ace.edit("editor"); var editor = ace.edit("editor");
editor.setTheme("ace/theme/chrome"); editor.setTheme("ace/theme/chrome");
editor.getSession().setMode("ace/mode/why3"); editor.getSession().setMode("ace/mode/why3");
var Range = ace.require("ace/range").Range;
var selectedRange = null;
var marker = null;
editor.$blockScrolling = Infinity; editor.$blockScrolling = Infinity;
function highlightError (x1, y1, x2, y2)
selectedRange = new Range (x1,y1,x2,y2);
marker = editor.session.addMarker(selectedRange, "error", "text");
function highlightRegion (cls, x1, y1, x2, y2)
marker = editor.session.addMarker(selectedRange, cls, "text");
function clearHighlight ()
if (marker) {
editor.session.removeMarker(marker);
marker = null;
editor.on("change", clearHighlight);
function moveToError ()
if (selectedRange) {
editor.selection.setSelectionRange(selectedRange);
editor.moveCursorToPosition(selectedRange.start);
editor.on("focus", moveToError);
function openFile () function openFile ()
document.getElementById("file-selector").click(); document.getElementById("file-selector").click();
...@@ -132,7 +94,7 @@ var saveFile = (function () ...@@ -132,7 +94,7 @@ var saveFile = (function ()
a.style.zIndex = "-10"; a.style.zIndex = "-10";
return function () { return function () {
a.href = "data:application/octet-stream;base64," + btoa(editor.getValue()+"\n"); a.href = "data:application/octet-stream;base64," + btoa(editor.getValue()+"\n");
a.download = /\S/.test(currentFilename) ? currentFilename : "Test.cd"; a.download = /\S/.test(currentFilename) ? currentFilename : "Test.mlw";
a.click(); a.click();
editor.focus(); editor.focus();
...@@ -31,7 +31,7 @@ ...@@ -31,7 +31,7 @@
.hl-task { .hl-task {
position:absolute; position:absolute;
background:rgba(200,200,100,0.5); background:rgba(200,200,100,1);
z-index:40; z-index:40;
/* Interface */ /* Interface */
...@@ -16,24 +16,77 @@ let get_opt o = Js.Opt.get o (fun () -> assert false) ...@@ -16,24 +16,77 @@ let get_opt o = Js.Opt.get o (fun () -> assert false)
(* the view *) (* the view *)
module Console = module Editor =
struct struct
let highlightRegion s l1 c1 l2 c2 = type range
ignore (Js.Unsafe.meth_call Js.Unsafe.global type marker
"highlightRegion" let editor =
Js.Unsafe.( [| inject (Js.string s); let open Js.Unsafe in
inject l1; get global (Js.string "editor")
inject c1;
inject l2; let get_buffer_js () : Js.js_string Js.t =
inject c2 |] ) ) let open Js.Unsafe in
meth_call editor "getValue" [| |]
let clearHighlight ()=
"clearHighlight" [| |])
let get_buffer () = let get_buffer () =
let global = Js.Unsafe.global in Js.to_string (get_buffer_js ())
let editor = Js.Unsafe.get global (Js.string "editor") in
Js.to_string (Js.Unsafe.meth_call editor "getValue" [| |]) let mk_range l1 c1 l2 c2 =
let range : (int -> int -> int -> int -> range Js.t) Js.constr =
get global (Js.string "Range")
in
jsnew range (l1, c1, l2, c2)
let set_selection_range r =
let selection = meth_call editor "getSelection" [| |] in
ignore (meth_call selection "setSelectionRange" [| inject r |])
let add_marker cls r : marker =
let session = meth_call editor "getSession" [| |] in
meth_call session "addMarker"
[| inject r;
inject (Js.string cls);
inject (Js.string "text") |]
let remove_marker m =
ignore (meth_call session "removeMarker" [| inject m|])
let get_char buffer i = int_of_float (buffer ## charCodeAt(i))
let why3_loc_to_range buffer loc =
let goto_line lstop =
let rec loop lcur i =
if lcur == lstop then i
else
let c = get_char buffer i in
loop (if c == 0 then lcur+1 else lcur) (i+1)
in
loop 1 0
in
let rec convert_range l c i n =
if n == 0 then (l, c) else
if (get_char buffer i) == 10
then convert_range (l+1) 0 (i+1) (n-1)
else convert_range l (c+1) (i+1) (n-1)
in
let l1, b, e = loc in
let c1 = b in
let i = goto_line l1 in
let l2, c2 = convert_range l1 b (i+b) (e-b) in
mk_range (l1-1) c1 (l2-1) c2
let set_on_event e f =
ignore (meth_call editor "on" [| inject (Js.string e);
inject f|])
module Console =
struct
let get_console () = let get_console () =
get_opt (Dom_html.document ## getElementById (Js.string "console")) get_opt (Dom_html.document ## getElementById (Js.string "console"))
...@@ -100,11 +153,42 @@ module Console = ...@@ -100,11 +153,42 @@ module Console =
let task_selection = Hashtbl.create 17 let task_selection = Hashtbl.create 17
let task_deselect () = let is_selected id = Hashtbl.mem task_selection id
Hashtbl.iter (fun _ span -> span ## classList ## remove (Js.string "task-selected")) let select_task id span loc =
task_selection; (span ## classList) ## add (Js.string "task-selected");
Hashtbl.clear task_selection let markers = List.map (Editor.add_marker "hl-task") loc in
Hashtbl.add task_selection id (span, loc, markers)
let deselect_task id =
try
let span, loc, markers = Hashtbl.find task_selection id in
(span ## classList) ## remove (Js.string "task-selected");
List.iter Editor.remove_marker markers;
Hashtbl.remove task_selection id
Not_found -> ()
let clear_task_selection () =
let l = Hashtbl.fold (fun id _ acc -> id :: acc) task_selection [] in
List.iter deselect_task l
let error_marker = ref None
let () =
Editor.set_on_event
"change"
(Js.wrap_callback (fun () -> clear_task_selection ();
match !error_marker with
None -> ()
| Some (m, _) -> Editor.remove_marker m))
let () =
Editor.set_on_event
"focus"
None -> ()
| Some (_, r) -> Editor.set_selection_range r))
let print_why3_output o = let print_why3_output o =
let doc = Dom_html.document in let doc = Dom_html.document in
(* see why3_worker.ml *) (* see why3_worker.ml *)
...@@ -112,10 +196,10 @@ module Console = ...@@ -112,10 +196,10 @@ module Console =
Error s -> print_error s Error s -> print_error s
| ErrorLoc ((l1, b, l2, e), s) -> | ErrorLoc ((l1, b, l2, e), s) ->
ignore (Js.Unsafe.meth_call Js.Unsafe.global let r = Editor.mk_range l1 b l2 e in
"highlightError" error_marker := Some (Editor.add_marker "error" r, r);
(Array.map Js.Unsafe.inject [| l1; b; l2; e |]));
print_error s print_error s
| Result sl -> | Result sl ->
clear (); clear ();
let ul = Dom_html.createUl doc in let ul = Dom_html.createUl doc in
...@@ -135,22 +219,18 @@ module Console = ...@@ -135,22 +219,18 @@ module Console =
with Not_found -> with Not_found ->
attach_to_parent id (parent_id ^ "_ul") expl loc; attach_to_parent id (parent_id ^ "_ul") expl loc;
let span = Dom_html.getElementById (id ^ "_container") in let span = Dom_html.getElementById (id ^ "_container") in
let buffer = Editor.get_buffer_js () in
let loc = List.map (Editor.why3_loc_to_range buffer) loc in
span ## onclick <- span ## onclick <-
Dom.handler Dom.handler
(fun ev -> (fun ev ->
let ctrl = Js.to_bool (ev ## ctrlKey) in let ctrl = Js.to_bool (ev ## ctrlKey) in
if Hashtbl.mem task_selection id then if is_selected id then
if ctrl then if ctrl then deselect_task id else
begin clear_task_selection ()
Hashtbl.remove task_selection id;
else
task_deselect ()
else begin else begin
if not ctrl then task_deselect (); if not ctrl then clear_task_selection ();
Hashtbl.add task_selection id span; select_task id span loc
end; end;
Js._false) Js._false)
end end
...@@ -276,7 +356,7 @@ let why3_parse () = ...@@ -276,7 +356,7 @@ let why3_parse () =
log_time "Before marshalling in main thread"; log_time "Before marshalling in main thread";
reset_workers (); reset_workers ();
first_task := true; first_task := true;
let code = Console.get_buffer () in let code = Editor.get_buffer () in
let msg = marshal (ParseBuffer code) in let msg = marshal (ParseBuffer code) in
log_time "After marshalling in main thread"; log_time "After marshalling in main thread";
(get_why3_worker()) ## postMessage (msg) (get_why3_worker()) ## postMessage (msg)
...@@ -286,7 +366,7 @@ let why3_execute () = ...@@ -286,7 +366,7 @@ let why3_execute () =
Console.print_msg "Compiling buffer … "; Console.print_msg "Compiling buffer … ";
(get_why3_worker()) ## postMessage (marshal (ExecuteBuffer code)) (get_why3_worker()) ## postMessage (marshal (ExecuteBuffer code))
let array_for_all a f = let array_for_all a f =
...@@ -307,7 +387,7 @@ let why3_transform tr f () = ...@@ -307,7 +387,7 @@ let why3_transform tr f () =
f id; f id;
(get_why3_worker()) ## postMessage (marshal (Transform(tr, id)))) (get_why3_worker()) ## postMessage (marshal (Transform(tr, id))))
Console.task_selection; Console.task_selection;
Console.task_deselect () Console.clear_task_selection ()
end end
...@@ -54,7 +54,7 @@ let alt_ergo_driver : Driver.driver = ...@@ -54,7 +54,7 @@ let alt_ergo_driver : Driver.driver =
let () = log_time ("Initialising why3 worker: end ") let () = log_time ("Initialising why3 worker: end ")
let split_trans = Trans.lookup_transform_l "split_goal_wp" env let split_trans = Trans.lookup_transform_l "split_goal_wp" env
(* CF gmain.ml ligne 568 et suivante *)
module W = module W =
struct struct
let send msg = let send msg =
...@@ -74,7 +74,7 @@ module Task = ...@@ -74,7 +74,7 @@ module Task =
parent_id : id; parent_id : id;
mutable status : status; mutable status : status;
mutable subtasks : id list; mutable subtasks : id list;
loc : loc list; loc : why3_loc list;
expl : string; expl : string;
...@@ -87,9 +87,45 @@ module Task = ...@@ -87,9 +87,45 @@ module Task =
Some (get_info id) Some (get_info id)
with with
Not_found -> None Not_found -> None
let get_parent_id id = (get_info id).parent_id let get_parent_id id = (get_info id).parent_id
let mk_loc (_, a,b,c) = (a,b,c)
let collect_locs t =
(* from why 3 ide *)
let locs = ref [] in
let rec get_locs f =
Opt.iter (fun loc -> locs := (mk_loc (Loc.get loc)) :: !locs) f.Term.t_loc;
Term.t_fold (fun () t -> get_locs t ) () f
in
let rec get_t_locs f =
match f.Term.t_node with
| Term.Tbinop (Term.Timplies,f1,f2) ->
get_locs f1;
get_t_locs f2
| Term.Tlet (t,fb) ->
let _,f1 = Term.t_open_bound fb in
get_locs t;
get_t_locs f1
| Term.Tquant (Term.Tforall,fq) ->
let _,_,f1 = Term.t_open_quant fq in
get_t_locs f1
| _ ->
get_locs f
in
let rec merge_locs = function
[] | [ _ ] as l -> l
| ((l1, b1, e1) as h1) :: ((l2, b2, e2) as h2) :: ll ->
if l1 != l2 then h1 :: (merge_locs (h2 :: ll))
else
match t with
| Some { Task.task_decl =
{ Theory.td_node =
Theory.Decl { Decl.d_node = Decl.Dprop (Decl.Pgoal, _, f)}}} ->
get_t_locs f; !locs
| _ -> []
let task_to_string t = let task_to_string t =
ignore (flush_str_formatter ()); ignore (flush_str_formatter ());
...@@ -107,12 +143,16 @@ module Task = ...@@ -107,12 +143,16 @@ module Task =
| Some s -> s | Some s -> s
| None -> vid.Ident.id_string | None -> vid.Ident.id_string
in in
let id_loc = match vid.Ident.id_loc with
None -> []
| Some l -> [ mk_loc (Loc.get l) ]
in
let task_info = let task_info =
{ task = `Task(task); { task = `Task(task);
parent_id = parent_id; parent_id = parent_id;
status = `New; status = `New;
subtasks = []; subtasks = [];
loc = [ (* todo *) ]; loc = id_loc @ (collect_locs task);
expl = expl } expl = expl }
in in
Hashtbl.add task_table id task_info; Hashtbl.add task_table id task_info;
...@@ -128,7 +168,7 @@ module Task = ...@@ -128,7 +168,7 @@ module Task =
parent_id = "theory-list"; parent_id = "theory-list";
subtasks = task_ids; subtasks = task_ids;
loc = [ (* todo *) ]; loc = [];
expl = th_name }; expl = th_name };
th_id th_id
type id = string type id = string
type loc = int * int * int * int type loc = int * int * int * int
type why3_loc = int * int * int (* line, column, length *)
type status = [`New | `Valid | `Unknown ] type status = [`New | `Valid | `Unknown ]
type why3_command = ParseBuffer of string type why3_command = ParseBuffer of string
| ExecuteBuffer of string | ExecuteBuffer of string
...@@ -9,7 +10,7 @@ type why3_command = ParseBuffer of string ...@@ -9,7 +10,7 @@ type why3_command = ParseBuffer of string
type why3_output = Error of string (* msg *) type why3_output = Error of string (* msg *)
| ErrorLoc of (loc * string) (* loc * msg *) | ErrorLoc of (loc * string) (* loc * msg *)
| Theory of id * string (* Theory (id, name) *) | Theory of id * string (* Theory (id, name) *)
| Task of (id * id * string * string * loc list) (* id, parent id, expl, code, location list *) | Task of (id * id * string * string * why3_loc list) (* id, parent id, expl, code, location list *)
| Result of string list | Result of string list
| UpdateStatus of status * id | UpdateStatus of status * id
