Commit b7c77790 authored by MARCHE Claude's avatar MARCHE Claude
LCP: simplified [le_trans], and cosmetic changes
parent e7949e64
...@@ -80,13 +80,13 @@ that it does so correctly. ...@@ -80,13 +80,13 @@ that it does so correctly.
(** {2 First module: longest common prefix} (** {2 First module: longest common prefix}
it corresponds to the basic part of the challenge it corresponds to the basic part of the challenge
module LCP module LCP
use export int.Int use export int.Int
use import array.Array use import array.Array
...@@ -95,8 +95,8 @@ use import array.Array ...@@ -95,8 +95,8 @@ use import array.Array
at respective positions [x] and [y] in array [a] are identical. In at respective positions [x] and [y] in array [a] are identical. In
other words, the array parts a[x..x+l-1] and a[y..y+l-1] are equal other words, the array parts a[x..x+l-1] and a[y..y+l-1] are equal
predicate is_common_prefix (a:array int) (x y l:int) = predicate is_common_prefix (a:array int) (x y l:int) =
0 <= l /\ x+l <= a.length /\ y+l <= a.length /\ 0 <= l /\ x+l <= a.length /\ y+l <= a.length /\
(forall i:int. 0 <= i < l -> a[x+i] = a[y+i]) (forall i:int. 0 <= i < l -> a[x+i] = a[y+i])
(** This lemma helps for the proof of [lcp] (but is not mandatory) and (** This lemma helps for the proof of [lcp] (but is not mandatory) and
...@@ -108,9 +108,9 @@ lemma not_common_prefix_if_last_char_are_different: ...@@ -108,9 +108,9 @@ lemma not_common_prefix_if_last_char_are_different:
(** [is_longest_common_prefix a x y l] is true when [l] is the maximal (** [is_longest_common_prefix a x y l] is true when [l] is the maximal
length such that prefixes at positions [x] and [y] in array [a] length such that prefixes at positions [x] and [y] in array [a]
are identical. *) are identical. *)
predicate is_longest_common_prefix (a:array int) (x y l:int) = predicate is_longest_common_prefix (a:array int) (x y l:int) =
is_common_prefix a x y l /\ is_common_prefix a x y l /\
forall m:int. l < m -> not (is_common_prefix a x y m) forall m:int. l < m -> not (is_common_prefix a x y m)
(** This lemma helps for proving [lcp] (but again is not mandatory), (** This lemma helps for proving [lcp] (but again is not mandatory),
...@@ -213,18 +213,21 @@ let compare (a:array int) (x y:int) : int ...@@ -213,18 +213,21 @@ let compare (a:array int) (x y:int) : int
absurd absurd
(** for the [range] predicate used below *)
use map.MapInjection
(** for the [permut] predicate (permutation of elements) *)
use array.ArrayPermut
predicate le (a : array int) (x y:int) = x = y \/ lt a x y predicate le (a : array int) (x y:int) = x = y \/ lt a x y
(* needed for le_trans (for cases x = y /\ le y z and le x y /\ y = z) *) (* needed for le_trans (for cases x = y /\ le y z and le x y /\ y = z) *)
lemma lcp_same_index : lemma lcp_same_index :
forall a:array int, x:int. forall a:array int, x:int.
0 <= x <= a.length -> LCP.is_longest_common_prefix a x x (a.length - x) 0 <= x <= a.length -> LCP.is_longest_common_prefix a x x (a.length - x)
lemma le_trans : lemma le_trans : forall a:array int, x y z:int.
forall a:array int, x y z:int. le a x y /\ le a y z -> le a x z
0 <= x <= a.length /\ 0 <= y <= a.length /\
0 <= z <= a.length /\ le a x y /\ le a y z -> le a x z
(** spec of sorted in increasing prefix order *) (** spec of sorted in increasing prefix order *)
use map.Map use map.Map
...@@ -236,26 +239,22 @@ let compare (a:array int) (x y:int) : int ...@@ -236,26 +239,22 @@ let compare (a:array int) (x y:int) : int
predicate sorted (a : array int) (data:array int) = predicate sorted (a : array int) (data:array int) =
sorted_sub a data.elts 0 data.length sorted_sub a data.elts 0 data.length
(** spec of permutation of elements *) let sort (a:array int) (data : array int)
use import array.ArrayPermut
use map.MapInjection (* for the range function used below *)
requires { data.length = a.length } requires { data.length = a.length }
requires { MapInjection.range data.elts data.length } requires { MapInjection.range data.elts data.length }
ensures { sorted a data } ensures { sorted a data }
ensures { permut (old data) data } ensures { ArrayPermut.permut (old data) data }
'Init: 'Init:
for i = 0 to data.length - 1 do for i = 0 to data.length - 1 do
invariant { permut (at data 'Init) data } invariant { ArrayPermut.permut (at data 'Init) data }
invariant { sorted_sub a data.elts 0 i } invariant { sorted_sub a data.elts 0 i }
invariant { MapInjection.range data.elts data.length } invariant { MapInjection.range data.elts data.length }
let j = ref i in let j = ref i in
while !j > 0 && compare a data[!j-1] data[!j] > 0 do while !j > 0 && compare a data[!j-1] data[!j] > 0 do
invariant { 0 <= !j <= i } invariant { 0 <= !j <= i }
invariant { sorted_sub a data.elts 0 !j } invariant { sorted_sub a data.elts 0 !j }
invariant { sorted_sub a data.elts !j (i+1) } invariant { sorted_sub a data.elts !j (i+1) }
invariant { forall k1 k2:int. 0 <= k1 < !j /\ !j+1 <= k2 <= i -> invariant { forall k1 k2:int. 0 <= k1 < !j /\ !j+1 <= k2 <= i ->
...@@ -265,9 +264,11 @@ let compare (a:array int) (x y:int) : int ...@@ -265,9 +264,11 @@ let compare (a:array int) (x y:int) : int
let t = data[!j] in let t = data[!j] in
data[!j] <- data[b]; data[!j] <- data[b];
data[b] <- t; data[b] <- t;
assert { exchange (at data 'L) data (!j-1) !j }; assert { ArrayPermut.exchange (at data 'L) data (!j-1) !j };
decr j decr j
done done;
(* needed to prove the invariant [sorted_sub a data.elts 0 i] *)
assert { !j > 0 -> le a data[!j-1] data[!j] }
done done
end end
...@@ -277,7 +278,7 @@ end ...@@ -277,7 +278,7 @@ end
(** {2 Third module: Suffix Array Data Structure } *) (** {2 Third module: Suffix Array Data Structure } *)
module SuffixArray module SuffixArray
...@@ -309,31 +310,33 @@ let select (s:suffixArray) (i:int) : int ...@@ -309,31 +310,33 @@ let select (s:suffixArray) (i:int) : int
use import array.ArrayPermut use import array.ArrayPermut
(** needed to establish invariant in function [create] *) (** needed to establish invariant in function [create] *)
lemma permut_permutation : lemma permut_permutation : forall a1 a2:array int.
forall a1 a2:array int. permut a1 a2 /\ permutation a1.elts a1.length ->
permut a1 a2 -> permutation a1.elts a1.length -> permutation a2.elts a2.length permutation a2.elts a2.length
(** constructor of suffixArray structure *) (** constructor of suffixArray structure *)
let create (a:array int) : suffixArray let create (a:array int) : suffixArray
ensures { result.values = a } ensures { result.values = a }
= = let n = a.length in
let n = a.length in let suf = Array.make n 0 in
let suf = Array.make n 0 in for i = 0 to n-1 do
for i = 0 to n-1 do invariant { forall j:int. 0 <= j < i -> suf[j] = j }
invariant { forall j:int. 0 <= j < i -> suf[j] = j } suf[i] <- i done;
suf[i] <- i done; SuffixSort.sort a suf;
SuffixSort.sort a suf; { values = a; suffixes = suf }
let lcp (s:suffixArray) (i:int) : int let lcp (s:suffixArray) (i:int) : int
requires { 0 < i < s.values.length } requires { 0 < i < s.values.length }
ensures { LCP.is_longest_common_prefix s.values ensures { LCP.is_longest_common_prefix s.values
s.suffixes[i-1] s.suffixes[i] result } s.suffixes[i-1] s.suffixes[i] result }
= = LCP.lcp s.values s.suffixes[i] s.suffixes[i-1]
end end
module SuffixArray_test module SuffixArray_test
...@@ -374,16 +377,16 @@ end ...@@ -374,16 +377,16 @@ end
(** {2 Fourth module: Longest Repeated Substring} *) (** {2 Fourth module: Longest Repeated Substring} *)
module LRS module LRS
use import int.Int use import int.Int
use import ref.Ref use import ref.Ref
use map.MapInjection use map.MapInjection
use LCP use LCP
use SuffixSort use SuffixSort
use SuffixArray use SuffixArray
...@@ -393,7 +396,7 @@ module LRS ...@@ -393,7 +396,7 @@ module LRS
lemma lcp_sym : lemma lcp_sym :
forall a:array int, x y l:int. forall a:array int, x y l:int.
0 <= x <= a.length /\ 0 <= y <= a.length -> 0 <= x <= a.length /\ 0 <= y <= a.length ->
LCP.is_longest_common_prefix a x y l -> LCP.is_longest_common_prefix a x y l ->
LCP.is_longest_common_prefix a y x l LCP.is_longest_common_prefix a y x l
...@@ -409,7 +412,7 @@ lemma le_le_common_prefix: ...@@ -409,7 +412,7 @@ lemma le_le_common_prefix:
lemma le_le_longest_common_prefix: lemma le_le_longest_common_prefix:
forall a:array int, x y z l m :int. forall a:array int, x y z l m :int.
SuffixSort.le a x y /\ SuffixSort.le a y z -> SuffixSort.le a x y /\ SuffixSort.le a y z ->
LCP.is_longest_common_prefix a x z l /\ LCP.is_longest_common_prefix a x z l /\
LCP.is_longest_common_prefix a y z m LCP.is_longest_common_prefix a y z m
-> l <= m -> l <= m
...@@ -457,7 +460,7 @@ lemma le_le_common_prefix: ...@@ -457,7 +460,7 @@ lemma le_le_common_prefix:
(** the following assert needs [lcp_sym] lemma *) (** the following assert needs [lcp_sym] lemma *)
assert { forall j k l:int. assert { forall j k l:int.
0 <= j < a.length /\ 0 <= k < a.length /\ j <> k /\ 0 <= j < a.length /\ 0 <= k < a.length /\ j <> k /\
LCP.is_longest_common_prefix a LCP.is_longest_common_prefix a
sa.SuffixArray.suffixes[j] sa.SuffixArray.suffixes[k] l -> sa.SuffixArray.suffixes[j] sa.SuffixArray.suffixes[k] l ->
!solLength >= l}; !solLength >= l};
assert { forall x y:int. assert { forall x y:int.
