Commit b6f3308c authored by Sylvain Dailler's avatar Sylvain Dailler
Removing root node
parent ab100c42
...@@ -371,17 +371,6 @@ let get_node_detached id = ...@@ -371,17 +371,6 @@ let get_node_detached id =
(* Initialization of the tree *) (* Initialization of the tree *)
(* TODO root node is convenient. Symmetry with session and parent of a node can
always be found. Can be removed. *)
(* Creating the root of the tree. *)
let create_root () =
let root_iter = goals_model#append () in
let root_ref = goals_model#get_row_reference
(goals_model#get_path root_iter) in
Hint.add node_id_to_gtree root_node root_ref;
Hint.add node_id_proved root_node false
let remove_tree goals_model = let remove_tree goals_model =
Hint.iter (fun _x i -> Hint.iter (fun _x i ->
try ignore(goals_model#remove (i#iter)) with _ -> ()) try ignore(goals_model#remove (i#iter)) with _ -> ())
...@@ -394,8 +383,6 @@ let clear_tree_and_table goals_model = ...@@ -394,8 +383,6 @@ let clear_tree_and_table goals_model =
Hint.clear node_id_proved; Hint.clear node_id_proved;
Hint.clear node_id_pa Hint.clear node_id_pa
(* Actually creating root *)
let _ = create_root ()
(* Menu items *) (* Menu items *)
...@@ -417,8 +404,6 @@ let reload_menu_item : GMenu.menu_item = ...@@ -417,8 +404,6 @@ let reload_menu_item : GMenu.menu_item =
~callback:(fun () -> ~callback:(fun () ->
(* Clearing the tree *) (* Clearing the tree *)
clear_tree_and_table goals_model; clear_tree_and_table goals_model;
(* Adding the root again *)
create_root ();
send_request Reload_req) send_request Reload_req)
(* vpan222 contains: (* vpan222 contains:
...@@ -635,8 +620,13 @@ let new_node ?parent ?(collapse=false) id name typ proved detached = ...@@ -635,8 +620,13 @@ let new_node ?parent ?(collapse=false) id name typ proved detached =
Hint.add node_id_type id typ; Hint.add node_id_type id typ;
Hint.add node_id_proved id proved; Hint.add node_id_proved id proved;
Hint.add node_id_detached id detached; Hint.add node_id_detached id detached;
let parent = Opt.map (fun x -> x#iter) parent in (* The tree does not have a root by default so the task is a forest with
let iter = goals_model#append ?parent () in several root files *)
let iter =
match parent with
| None -> goals_model#append ()
| Some p -> goals_model#append ~parent:p#iter ()
in
goals_model#set ~row:iter ~column:name_column name; goals_model#set ~row:iter ~column:name_column name;
goals_model#set ~row:iter ~column:node_id_column id; goals_model#set ~row:iter ~column:node_id_column id;
let new_ref = goals_model#get_row_reference (goals_model#get_path iter) in let new_ref = goals_model#get_row_reference (goals_model#get_path iter) in
...@@ -750,6 +740,7 @@ let interp cmd = ...@@ -750,6 +740,7 @@ let interp cmd =
let id = if List.length rows > 0 then let id = if List.length rows > 0 then
get_node_id ((List.hd rows)#iter) get_node_id ((List.hd rows)#iter)
else else
(* If no nodes are in the tree send command on default root node *)
root_node root_node
in in
send_request (Command_req (id, cmd)); send_request (Command_req (id, cmd));
...@@ -878,8 +869,6 @@ let open_session: GMenu.menu_item = ...@@ -878,8 +869,6 @@ let open_session: GMenu.menu_item =
select_file ~request:(fun f -> select_file ~request:(fun f ->
(* Clearing the ide tree *) (* Clearing the ide tree *)
create_root ();
send_request (Open_session_req f))) send_request (Open_session_req f)))
...@@ -964,7 +953,7 @@ let treat_notification n = match n with ...@@ -964,7 +953,7 @@ let treat_notification n = match n with
let parent = get_node_row parent_id in let parent = get_node_row parent_id in
ignore (new_node ~parent id name typ false detached) ignore (new_node ~parent id name typ false detached)
with Not_found -> with Not_found ->
ignore (new_node id name typ false, detached)) ignore (new_node id name typ false detached))
end end
| Remove id -> | Remove id ->
let n = get_node_row id in let n = get_node_row id in
...@@ -546,8 +546,6 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct ...@@ -546,8 +546,6 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct
P.notify (New_node (new_id, parent, node_type, node_name, node_detached)); P.notify (New_node (new_id, parent, node_type, node_name, node_detached));
new_id new_id
let root = 0
(* Iter on the session tree *) (* Iter on the session tree *)
...@@ -611,7 +609,7 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct ...@@ -611,7 +609,7 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct
let _init_the_tree (): unit = let _init_the_tree (): unit =
let f ~parent node_id = ignore (new_node ~parent node_id) in let f ~parent node_id = ignore (new_node ~parent node_id) in
iter_the_files f root iter_the_files f root_node
let init_and_send_subtree_from_trans parent trans_id : unit = let init_and_send_subtree_from_trans parent trans_id : unit =
iter_subtree_from_trans iter_subtree_from_trans
...@@ -619,11 +617,10 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct ...@@ -619,11 +617,10 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct
let init_and_send_file f = let init_and_send_file f =
iter_subtree_from_file (fun ~parent id -> ignore (new_node ~parent id)) iter_subtree_from_file (fun ~parent id -> ignore (new_node ~parent id))
root f root_node f
let init_and_send_the_tree (): unit = let init_and_send_the_tree (): unit =
P.notify (New_node (0, 0, NRoot, "root", false)); iter_the_files (fun ~parent id -> ignore (new_node ~parent id)) root_node
let resend_the_tree (): unit = let resend_the_tree (): unit =
let send_node ~parent any = let send_node ~parent any =
...@@ -632,8 +629,7 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct ...@@ -632,8 +629,7 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct
let node_type = get_node_type any in let node_type = get_node_type any in
let node_detached = get_node_detached any in let node_detached = get_node_detached any in
P.notify (New_node (node_id, parent, node_type, node_name, node_detached)) in P.notify (New_node (node_id, parent, node_type, node_name, node_detached)) in
P.notify (New_node (0, 0, NRoot, "root", false)); iter_the_files send_node root_node
(* -- send the task -- *) (* -- send the task -- *)
let task_of_id d id = let task_of_id d id =
