Commit b67fb7c0 authored by Andrei Paskevich's avatar Andrei Paskevich
update sessions
parent 61127a19
This diff is collapsed.
......@@ -24,7 +24,7 @@
locfile="../arm.mlw"
loclnum="16" loccnumb="6" loccnume="20"
expl="VC for insertion_sort"
sum="0253f804b94902a25f1e77e1d4c459c1"
sum="7a48ddec008b758b68d1b8f7bf242745"
proved="false"
expanded="false"
shape="iainfix <=V6c45Aainfix =V7c9Aainfix <=c0V0iainfix <ainfix -c10V16ainfix -c10V5Aainfix <=c0ainfix -c10V5Aainfix <=ainfix *c2V12ainfix *ainfix -V16c2ainfix -V16c1Aainfix =V10ainfix -V16c2AainvV14Aainfix <=V16c11Aainfix <=c2V16Iainfix =V16ainfix +V5c1Fainfix <V22V11Aainfix <=c0V11Aainfix <=ainfix *c2V17ainfix +ainfix *ainfix -V5c2ainfix -V5c1ainfix *c2ainfix -V5V22Aainvamk arrayV0V21Aainfix <=V22V5Aainfix <=c1V22Iainfix =V22ainfix -V11c1FIainfix =V21asetV19V20agetV13V11Aainfix <=c0V0FAainfix <V20V0Aainfix <=c0V20Lainfix -V11c1Iainfix =V19asetV13V11agetV13V18Aainfix <=c0V0FAainfix <V11V0Aainfix <=c0V11Aainfix <V18V0Aainfix <=c0V18Lainfix -V11c1Aainfix <V11V0Aainfix <=c0V11Iainfix =V17ainfix +V12c1Fainfix <agetV13V11agetV13V15Aainfix <V11V0Aainfix <=c0V11Aainfix <V15V0Aainfix <=c0V15Aainfix <=c0V0Lainfix -V11c1Iainfix <=ainfix *c2V12ainfix +ainfix *ainfix -V5c2ainfix -V5c1ainfix *c2ainfix -V5V11AainvV14Aainfix <=V11V5Aainfix <=c1V11Lamk arrayV0V13FAainfix <=ainfix *c2V6ainfix +ainfix *ainfix -V5c2ainfix -V5c1ainfix *c2ainfix -V5V5AainvV9Aainfix <=V5V5Aainfix <=c1V5Iainfix =V10ainfix +V7c1Fainfix <=V5c10Iainfix <=ainfix *c2V6ainfix *ainfix -V5c2ainfix -V5c1Aainfix =V7ainfix -V5c2AainvV9Aainfix <=V5c11Aainfix <=c2V5Lamk arrayV0V8FAainfix <=ainfix *c2V1ainfix *ainfix -c2c2ainfix -c2c1Aainfix =V2ainfix -c2c2AainvV4Aainfix <=c2c11Aainfix <=c2c2Iainfix =V1c0Aainfix =V2c0AainvV4Aainfix <=c0V0Lamk arrayV0V3FF">
......@@ -50,7 +50,7 @@
loclnum="120" loccnumb="6" loccnume="18"
expl="VC for path_init_l2"
sum="beb23c3645199bfd98a3ca8ba1a81b49"
sum="b7f073634088aae7b5aaf2b40c15baf4"
proved="true"
expanded="true"
shape="ainv_l2V5V0V2Iainfix =V5amixfix [<-]V1ainfix -V0c16V4FIainfix =V4c2FIainfix =V3c0FIainfix =V2c0FIainvV1AaseparationV0F">
......@@ -78,7 +78,7 @@
loclnum="127" loccnumb="6" loccnume="18"
expl="VC for path_l2_exit"
sum="25c0115faf8097c35ae492323795ad51"
sum="7985bd31cb47c770cc076d13e2aa0786"
proved="true"
expanded="true"
shape="ainfix =V0c9Iainfix =V4aFalseIainfix <=V3c10qainfix =V4aTrueFIainfix =V3amixfix []V2ainfix -V1c16FIainv_l2V2V1V0AaseparationV1F">
locfile="../assigning_meanings_to_programs.mlw"
loclnum="12" loccnumb="6" loccnume="9"
expl="VC for sum"
sum="6ec85216e9bf59221efb91729e5526a9"
sum="a22a8b12b1c0d38016349831b652911b"
proved="true"
expanded="true"
shape="iainfix =V3asumV1c1ainfix +V2c1ainfix <ainfix -V2V6ainfix -V2V4Aainfix <=c0ainfix -V2V4Aainfix =V5asumV1c1V6Aainfix <=V6ainfix +V2c1Aainfix <=c1V6Iainfix =V6ainfix +V4c1FIainfix =V5ainfix +V3agetV1V4FAainfix <V4V0Aainfix <=c0V4ainfix <=V4V2Iainfix =V3asumV1c1V4Aainfix <=V4ainfix +V2c1Aainfix <=c1V4FAainfix =c0asumV1c1c1Aainfix <=c1ainfix +V2c1Aainfix <=c1c1Iainfix <V2V0Aainfix <=c0V2Aainfix <=c0V0F">
(* This file is generated by Why3's Coq driver *)
(* This file is generated by Why3's Coq 8.4 driver *)
(* Beware! Only edit allowed sections below *)
Require Import BuiltIn.
Require BuiltIn.
Require bool.Bool.
Require int.Int.
Require int.Abs.
Require int.EuclideanDivision.
......@@ -148,13 +149,24 @@ Axiom pow2_62 : ((pow2 62%Z) = 4611686018427387904%Z).
Axiom pow2_63 : ((pow2 63%Z) = 9223372036854775808%Z).
Axiom Div_pow : forall (x:Z) (i:Z), (((pow2 (i - 1%Z)%Z) <= x)%Z /\
(x < (pow2 i))%Z) -> ((int.EuclideanDivision.div x
(pow2 (i - 1%Z)%Z)) = 1%Z).
Axiom Div_mult_inst : forall (x:Z) (z:Z), (0%Z < x)%Z ->
((int.EuclideanDivision.div ((x * 1%Z)%Z + z)%Z
x) = (1%Z + (int.EuclideanDivision.div z x))%Z).
Axiom Div_pow2 : forall (x:Z) (i:Z), (((-(pow2 i))%Z <= x)%Z /\
(x < (-(pow2 (i - 1%Z)%Z))%Z)%Z) -> ((int.EuclideanDivision.div x
(pow2 (i - 1%Z)%Z)) = (-2%Z)%Z).
Axiom Div_double : forall (x:Z) (y:Z), ((0%Z < y)%Z /\ ((y <= x)%Z /\
(x < (2%Z * y)%Z)%Z)) -> ((int.EuclideanDivision.div x y) = 1%Z).
Axiom Div_pow : forall (x:Z) (i:Z), (0%Z < i)%Z ->
((((pow2 (i - 1%Z)%Z) <= x)%Z /\ (x < (pow2 i))%Z) ->
((int.EuclideanDivision.div x (pow2 (i - 1%Z)%Z)) = 1%Z)).
Axiom Div_double_neg : forall (x:Z) (y:Z), ((((-2%Z)%Z * y)%Z <= x)%Z /\
((x < (-y)%Z)%Z /\ ((-y)%Z < 0%Z)%Z)) -> ((int.EuclideanDivision.div x
y) = (-2%Z)%Z).
Axiom Div_pow2 : forall (x:Z) (i:Z), (0%Z < i)%Z ->
((((-(pow2 i))%Z <= x)%Z /\ (x < (-(pow2 (i - 1%Z)%Z))%Z)%Z) ->
((int.EuclideanDivision.div x (pow2 (i - 1%Z)%Z)) = (-2%Z)%Z)).
Axiom Mod_pow2_gen : forall (x:Z) (i:Z) (k:Z), ((0%Z <= k)%Z /\ (k < i)%Z) ->
((int.EuclideanDivision.mod1 (int.EuclideanDivision.div (x + (pow2 i))%Z
......@@ -182,7 +194,7 @@ Axiom Nth_one : forall (n:Z), ((0%Z <= n)%Z /\ (n < size)%Z) -> ((nth bvone
n) = true).
(* Why3 assumption *)
Definition eq(v1:bv) (v2:bv): Prop := forall (n:Z), ((0%Z <= n)%Z /\
Definition eq (v1:bv) (v2:bv): Prop := forall (n:Z), ((0%Z <= n)%Z /\
(n < size)%Z) -> ((nth v1 n) = (nth v2 n)).
Axiom extensionality : forall (v1:bv) (v2:bv), (eq v1 v2) -> (v1 = v2).
......@@ -255,19 +267,19 @@ Axiom lsl_nth_low : forall (b:bv) (n:Z) (s:Z), ((0%Z <= n)%Z /\
Parameter to_nat_sub: bv -> Z -> Z -> Z.
Axiom to_nat_sub_zero : forall (b:bv) (j:Z) (i:Z), (((0%Z <= i)%Z /\
(i <= j)%Z) /\ (j < size)%Z) -> (((nth b j) = false) -> ((to_nat_sub b j
Axiom to_nat_sub_zero : forall (b:bv) (j:Z) (i:Z), ((0%Z <= i)%Z /\
((i <= j)%Z /\ (j < size)%Z)) -> (((nth b j) = false) -> ((to_nat_sub b j
i) = (to_nat_sub b (j - 1%Z)%Z i))).
Axiom to_nat_sub_one : forall (b:bv) (j:Z) (i:Z), (((0%Z <= i)%Z /\
(i <= j)%Z) /\ (j < size)%Z) -> (((nth b j) = true) -> ((to_nat_sub b j
Axiom to_nat_sub_one : forall (b:bv) (j:Z) (i:Z), ((0%Z <= i)%Z /\
((i <= j)%Z /\ (j < size)%Z)) -> (((nth b j) = true) -> ((to_nat_sub b j
i) = ((pow2 (j - i)%Z) + (to_nat_sub b (j - 1%Z)%Z i))%Z)).
Axiom to_nat_sub_high : forall (b:bv) (j:Z) (i:Z), (j < i)%Z ->
((to_nat_sub b j i) = 0%Z).
Axiom to_nat_of_zero2 : forall (b:bv) (i:Z) (j:Z), (((j < size)%Z /\
(i <= j)%Z) /\ (0%Z <= i)%Z) -> ((forall (k:Z), ((k <= j)%Z /\
Axiom to_nat_of_zero2 : forall (b:bv) (i:Z) (j:Z), ((j < size)%Z /\
((i <= j)%Z /\ (0%Z <= i)%Z)) -> ((forall (k:Z), ((k <= j)%Z /\
(i < k)%Z) -> ((nth b k) = false)) -> ((to_nat_sub b j 0%Z) = (to_nat_sub b
i 0%Z))).
......@@ -279,14 +291,14 @@ Require Import Why3.
Open Scope Z_scope.
(* Why3 goal *)
Theorem to_nat_of_one : forall (b:bv) (i:Z) (j:Z), (((j < size)%Z /\
Theorem to_nat_of_one : forall (b:bv) (i:Z) (j:Z), ((j < size)%Z /\
(i <= k)%Z) -> ((nth b k) = true)) -> ((to_nat_sub b j
i) = ((pow2 ((j - i)%Z + 1%Z)%Z) - 1%Z)%Z)).
intros b i j ((Hj,Hij),Hi).
(* Why3 intros b i j (h1,(h2,h3)) h4. *)
intros b i j (Hj,(Hij,Hi)).
generalize Hij Hj.
pattern j; apply Zlt_lower_bound_ind with (z:=i); auto.
why3 "cvc3" timelimit 3.
Qed.
Require BuiltIn.
Require bool.Bool.
Require int.Int.
Require int.Abs.
y) = (-2%Z)%Z).
n) = true).
......@@ -255,12 +267,12 @@ Axiom lsl_nth_low : forall (b:bv) (n:Z) (s:Z), ((0%Z <= n)%Z /\
......@@ -273,11 +285,12 @@ Ltac ae := why3 "alt-ergo" timelimit 3.
Open Scope Z_scope.
(* Why3 goal *)
Theorem to_nat_of_zero2 : forall (b:bv) (i:Z) (j:Z), (((j < size)%Z /\
Theorem to_nat_of_zero2 : forall (b:bv) (i:Z) (j:Z), ((j < size)%Z /\
i 0%Z))).
intros b i j ((Hj,Hij),Hipos).
intros b i j (Hj,(Hij,Hipos)).
generalize Hj.
clear j Hj Hij.
......@@ -289,4 +302,3 @@ intros Hbits Hnth.
rewrite to_nat_sub_zero; auto with zarith.
Qed.
......@@ -46,7 +46,7 @@
name="nth_one1"
locfile="../double.why"
loclnum="73" loccnumb="8" loccnume="16"
sum="53e20bd87a3e79b72c5512963842d539"
sum="9426856b7db1eaa0a7fbf98d0a1d6511"
proved="true"
expanded="true"
shape="ainfix =anthaoneV0aFalseIainfix &lt;=V0c51Aainfix &lt;=c0V0F">
......@@ -63,7 +63,7 @@
name="nth_one2"
loclnum="74" loccnumb="8" loccnume="16"
sum="5c6b679bdaf6e72da6f008127d4dae8b"
sum="b1c633079fda4d75118758023d1bd9d6"
proved="true"
expanded="true"
shape="ainfix =anthaoneV0aTrueIainfix &lt;=V0c61Aainfix &lt;=c52V0F">
......@@ -80,7 +80,7 @@
name="nth_one3"
loclnum="75" loccnumb="8" loccnume="16"
sum="46bc15aba4d6b67856522de76992c667"
sum="7b13e3cc4204cfbf0bcadc9604a16925"
proved="true"
expanded="false"
shape="ainfix =anthaoneV0aFalseIainfix &lt;=V0c63Aainfix &lt;=c62V0F">
......@@ -97,7 +97,7 @@
name="sign_one"
loclnum="77" loccnumb="8" loccnume="16"
sum="ab82e666da6cf4defbf0468de247ca8e"
sum="bdda75f77974f193214e8a50e2cd6d59"
proved="true"
expanded="false"
shape="ainfix =asignaoneaFalse">
......@@ -146,7 +146,7 @@
name="exp_one"
loclnum="78" loccnumb="8" loccnume="15"
sum="d0092b130cd4ba2ae1480e7e7a7fb7d5"
sum="0c3504d58a9734848a0cbc03bc51d27d"
proved="true"
expanded="false"
shape="ainfix =aexpaonec1023">
......@@ -172,7 +172,7 @@
name="mantissa_one"
loclnum="79" loccnumb="8" loccnume="20"
sum="645707f7b8a77e5360f0735d5a5b932d"
sum="e7fa2f72bb2aada4371ebb33b3cc263e"
proved="true"
expanded="false"
shape="ainfix =amantissaaonec0">
......@@ -205,7 +205,7 @@
name="double_value_of_1"
loclnum="81" loccnumb="8" loccnume="25"
sum="ba4b977489801faa24193df21c2ca712"
sum="a43ae53878e69bc2d59a96e436eb69b9"
proved="true"
expanded="false"
shape="ainfix =adouble_of_bv64aonec1.0">
......@@ -39,7 +39,7 @@
name="Nth_j"
locfile="../neg_as_xor.why"
loclnum="13" loccnumb="8" loccnume="13"
sum="a7d9cf0929603ad3efb0168530924828"
sum="b0c07d6787ca3814d68d37a55958ed88"
proved="true"
expanded="true"
shape="ainfix =anthajV0aFalseIainfix &lt;=V0c62Aainfix &lt;=c0V0F">
......@@ -56,7 +56,7 @@
name="sign_of_j"
loclnum="15" loccnumb="8" loccnume="17"
sum="db878064435f19d2d1ff550e668e5ef7"
sum="11d2d005ac052841fddb064ceec1a224"
proved="true"
expanded="true"
shape="ainfix =asignajaTrue">
......@@ -73,7 +73,7 @@
name="mantissa_of_j"
loclnum="16" loccnumb="8" loccnume="21"
sum="9bc445592e04784060be698711ed7011"
sum="0ec22cf2da947df79bbac64e800d2037"
proved="true"
expanded="true"
shape="ainfix =amantissaajc0">
......@@ -122,7 +122,7 @@
name="exp_of_j"
loclnum="17" loccnumb="8" loccnume="16"
sum="43cea4ec0bdced8115798182e3eec086"
sum="d3fd5439e0a062e21d4b47d51da10f85"
proved="true"
expanded="true"
shape="ainfix =aexpajc0">
......@@ -171,7 +171,7 @@
name="int_of_bv"
loclnum="18" loccnumb="8" loccnume="17"
sum="13b8c9db73db1dac2c7bad49f600634e"
sum="062b16a1b9b8983f80b40b9ca9c1b7c1"
proved="true"
expanded="true"
shape="ainfix =adouble_of_bv64ajc0.0">
......@@ -220,7 +220,7 @@
name="MainResultBits"
loclnum="20" loccnumb="8" loccnume="22"
sum="b8c642e5737eee9e8f8dede7b5d40cd8"
sum="e67e8ff64626154fd727262483f22583"
proved="true"
expanded="true"
shape="ainfix =anthabw_xorV0ajV1anthV0V1Iainfix &lt;V1c63Aainfix &lt;=c0V1FF">
......@@ -245,7 +245,7 @@
name="MainResultSign"
loclnum="23" loccnumb="8" loccnume="22"
sum="75b0e6c8ac543c3dd0ddec53a5fb9557"
sum="aa318a184dd710f5d456887f3f3c9e06"
proved="true"
expanded="true"
shape="ainfix =anthabw_xorV0ajc63anotbanthV0c63F">
......@@ -270,7 +270,7 @@
name="Sign_of_xor_j"
loclnum="25" loccnumb="8" loccnume="21"
sum="8728de3c3203b4e08ad9c90f5a6bbb65"
sum="16129089ff40de7b992dc83878b2e424"
proved="true"
expanded="true"
shape="ainfix =asignabw_xorV0ajanotbasignV0F">
......@@ -319,7 +319,7 @@
name="Exp_of_xor_j"
loclnum="27" loccnumb="8" loccnume="20"
sum="455b0069043d71e599dfecc63a8758c0"
sum="1d7f25cf0479a1b4653fb5da53c80932"
proved="true"
expanded="true"
shape="ainfix =aexpabw_xorV0ajaexpV0F">
......@@ -360,7 +360,7 @@
name="Mantissa_of_xor_j"
loclnum="29" loccnumb="8" loccnume="25"
sum="1f02e9a2a57fd9292ecd416dbb186109"
sum="358f2775fb8ab653ffd112e0011f0f81"
proved="true"
expanded="true"
shape="ainfix =amantissaabw_xorV0ajamantissaV0F">
......@@ -401,7 +401,7 @@
name="MainResultZero"
loclnum="31" loccnumb="8" loccnume="22"
sum="5789944886ff89f58121bdc8ffd2305f"
sum="8e35ab4f8feaafcd296967f7b268407d"
proved="true"
expanded="true"
shape="ainfix =adouble_of_bv64abw_xorV0ajaprefix -.adouble_of_bv64V0Iainfix =amantissaV0c0Aainfix =c0aexpV0F">
......@@ -427,7 +427,7 @@
memlimit="1000"
obsolete="false"
archived="false">
<result status="valid" time="1.24"/>
<result status="valid" time="1.48"/>
</proof>
<proof
prover="4"
......@@ -443,14 +443,14 @@
memlimit="1000"
obsolete="false"
archived="false">
<result status="valid" time="1.27"/>
<result status="valid" time="1.01"/>
</proof>
</goal>
<goal
name="sign_neg"
loclnum="34" loccnumb="8" loccnume="16"
sum="dd4faf3f836502c1a4c2eb22b26cac84"
sum="e9e9f43e43315e87befdb1f4ae28558f"
proved="true"
expanded="true"
shape="ainfix =asign_valueanotbasignV0aprefix -.asign_valueasignV0F">
......@@ -475,7 +475,7 @@
name="MainResult"
loclnum="36" loccnumb="8" loccnume="18"
sum="3117fcfa34ff1753af99b6998919c4e6"
sum="13c0b40c682017066c953ef3e8d2b1b2"
proved="true"
expanded="true"
shape="ainfix =adouble_of_bv64abw_xorV0ajaprefix -.adouble_of_bv64V0Iainfix &lt;aexpV0c2047Aainfix &lt;c0aexpV0F">
......@@ -2395,7 +2395,7 @@
memlimit="1000"
obsolete="false"
archived="false">
<result status="valid" time="1.64"/>
<result status="valid" time="1.33"/>
</proof>
</goal>
<goal
......@@ -3237,7 +3237,7 @@
name="Div_double"
locfile="../power2.why"
loclnum="90" loccnumb="8" loccnume="18"
sum="1fcb539eabe84fdefeff2f4f139265f3"
sum="bda4ae1019d1849b5d9cccb5a863b4ac"
proved="true"
expanded="false"
shape="ainfix =adivV0V1c1Iainfix &lt;V0ainfix *c2V1Aainfix &lt;=V1V0Aainfix &lt;c0V1F">
......@@ -3254,7 +3254,7 @@
name="Div_pow"
loclnum="93" loccnumb="8" loccnume="15"
sum="11153dee5e26877e1fa13aa25ffb1921"
sum="d2fc073ce351900def835eb86b4496ad"
proved="true"
expanded="false"
shape="ainfix =adivV0apow2ainfix -V1c1c1Iainfix &lt;V0apow2V1Aainfix &lt;=apow2ainfix -V1c1V0Iainfix &gt;V1c0F">
......@@ -3287,7 +3287,7 @@
name="Div_double_neg"
loclnum="96" loccnumb="8" loccnume="22"
sum="d05676ffe390734a5735e4d84a38010f"
sum="bfcff34bf93ddec105c5c4dbc51c88c7"
proved="true"
expanded="false"
shape="ainfix =adivV0V1aprefix -c2Iainfix &lt;aprefix -V1c0Aainfix &lt;V0aprefix -V1Aainfix &lt;=ainfix *aprefix -c2V1V0F">
......@@ -3320,7 +3320,7 @@
name="Div_pow2"
loclnum="99" loccnumb="8" loccnume="16"
sum="a7add2d0ed8fdd1e97b35f4634aa331f"
sum="8d27808b5e05937f232478240c70d2e0"
proved="true"
expanded="false"
shape="ainfix =adivV0apow2ainfix -V1c1aprefix -c2Iainfix &lt;V0aprefix -apow2ainfix -V1c1Aainfix &lt;=aprefix -apow2V1V0Iainfix &gt;V1c0F">
......@@ -3353,7 +3353,7 @@
name="Mod_pow2_gen"
loclnum="106" loccnumb="8" loccnume="20"
sum="bc634ba4115c31b26b0a26fa8a42fe8f"
sum="71b1e029d6b788847da1f624fbed9c2e"
proved="true"
expanded="false"
shape="ainfix =amodadivainfix +V0apow2V1apow2V2c2amodadivV0apow2V2c2Iainfix &lt;V2V1Aainfix &lt;=c0V2F">
......@@ -3746,7 +3746,7 @@
name="Pow2_int_real"
loclnum="149" loccnumb="8" loccnume="21"
sum="88542aa636d052e2f3db12855142a25f"
sum="bad4162471b2f59ad9373295192dd218"
proved="true"
expanded="false"
shape="ainfix =apow2V0afrom_intapow2V0Iainfix &gt;=V0c0F">
......@@ -35,7 +35,7 @@
name="l_false"
locfile="../fsetint.why"
loclnum="5" loccnumb="9" loccnume="16"
sum="0158150de9c97af9dd9820938313b4d5"
sum="4cae098d8b82a679b1a74d2c84737019"
proved="false"
expanded="true"
shape="f">
......@@ -91,7 +91,7 @@
name="mem_integer"
loclnum="13" loccnumb="8" loccnume="19"
sum="3658829cdb3f859e8fd24937b2513f62"
sum="205c151a38877b7f91313916922d7186"
proved="false"
expanded="true"
shape="amemV0aintegerF">
......@@ -140,7 +140,7 @@
name="foo"
loclnum="15" loccnumb="7" loccnume="10"
sum="99afe7ade68f07f16139a57d95d5df7e"
sum="89b296fe229e48a8d6ac3a1be7f7b47a"
proved="false"
expanded="true"
shape="f">
name="G1"
locfile="../array.why"
loclnum="4" loccnumb="7" loccnume="9"
sum="6a5e4bcc7b588bfa5e78aaa401a74340"
sum="3980f0191b1d60ae46edc59a32d239c5"
proved="true"
expanded="true"
shape="ainfix =agetasetV2V1V0V1V0FF">
......@@ -96,7 +96,7 @@
name="G2"
loclnum="6" loccnumb="7" loccnume="9"
sum="92e7e0f02caa5e51b6a592a13189bad2"
sum="2388ea470ff7fd77de49c85055b8a1e1"
proved="true"
expanded="true"
shape="ainfix =agetasetV4V0V3V2V1Iainfix =agetV4V2V1INainfix =V2V0FF">
......@@ -153,7 +153,7 @@
name="G3"
loclnum="10" loccnumb="7" loccnume="9"
sum="49164e5453d62978cc5152486def35e3"
sum="52dab61db769bd21f1d4fdf5e82f7b79"
proved="true"
expanded="true"
shape="ainfix =agetasetV2c1V1c0V0Iainfix =agetV2c0V0FF">
......@@ -210,7 +210,7 @@
name="G4"
loclnum="13" loccnumb="7" loccnume="9"
sum="4a5d48e8598b6b2f27a4febc5b896b91"
sum="8da484126da43881b2ddf56a6f81d7bc"
proved="true"
expanded="true"
shape="ainfix =agetasetasetV2c1V1c0V0c1V1FF">
Require BuiltIn.
......@@ -6,7 +6,7 @@ Require int.Int.
Require map.Map.
(* Why3 assumption *) <
