Commit b6464fac authored by Jean-Christophe Filliâtre's avatar Jean-Christophe Filliâtre
verifythis_fm2012_treedel: left and right are ghost functions
parent 4d1a93e2
...@@ -66,12 +66,12 @@ module Treedel ...@@ -66,12 +66,12 @@ module Treedel
forall z "induction": zipper 'a, x: 'a, l r: tree 'a. forall z "induction": zipper 'a, x: 'a, l r: tree 'a.
inorder (zip (Node l x r) z) = inorder l ++ Cons x (inorder (zip r z)) inorder (zip (Node l x r) z) = inorder l ++ Cons x (inorder (zip r z))
let left (t: tree pointer) = let ghost left (t: tree pointer) =
requires { t <> Empty } requires { t <> Empty }
ensures { match t with Empty -> false | Node l _ _ -> result = l end } ensures { match t with Empty -> false | Node l _ _ -> result = l end }
match t with Empty -> absurd | Node l _ _ -> l end match t with Empty -> absurd | Node l _ _ -> l end
let right (t: tree pointer) = let ghost right (t: tree pointer) =
ensures { match t with Empty -> false | Node _ _ r -> result = r end } ensures { match t with Empty -> false | Node _ _ r -> result = r end }
match t with Empty -> absurd | Node _ _ r -> r end match t with Empty -> absurd | Node _ _ r -> r end
