Commit b4a7d369 authored by Guillaume Melquiond's avatar Guillaume Melquiond
Merge branch 'next' into new_ide
parents a3b4ca1e c7ed1846
before_script:
- . $HOME/.opam/opam-init/variables.sh
stages:
- build
- test
- deploy
ci-bench:
.build_template: &build_definition
stage: build
script:
- misc/ci-bench.sh
- misc/ci-docker.sh misc/ci-local.sh
build:
variables:
COMPILER: system
<<: *build_definition
build-4.03.0:
variables:
COMPILER: 4.03.0
build-4.04.0:
variables:
COMPILER: 4.04.0
build-4.05.0:
variables:
COMPILER: 4.05.0
build-4.06.0:
variables:
COMPILER: 4.06.0
bench:
stage: test
variables:
COMPILER: system
script:
- misc/ci-docker.sh misc/ci-local.sh bench
.bench_template: &bench_definition
stage: test
script:
only:
- tags
- schedules
bench-4.03.0:
variables:
COMPILER: 4.03.0
<<: *bench_definition
bench-4.04.0:
variables:
COMPILER: 4.04.0
bench-4.05.0:
variables:
COMPILER: 4.05.0
bench-4.06.0:
variables:
COMPILER: 4.06.0
deploy:
stage: deploy
script:
- misc/ci-deploy.sh
only:
- master
- /^bugfix[/]v[0-9.]*$/
- tags
FROM bench-image-system
USER root
RUN adduser --disabled-password --gecos '' guest
USER why3
COPY --chown=why3:why3 . why3
WORKDIR /home/why3/why3
RUN eval `opam config env` && \
./configure && \
make -j2
USER root
RUN make install
USER guest
ENV HOME /home/guest
WORKDIR /home/guest
RUN why3 config --detect
FROM ocaml/ocaml:debian-stable
# install dependencies
RUN apt-get update && \
apt-get install -y wget libgmp-dev gtk+-2.0 libgtksourceview2.0-dev gnome-themes-standard libcanberra-gtk-module opam
# create user
RUN sudo adduser --disabled-password --gecos '' why3
USER why3
ENV HOME /home/why3
WORKDIR /home/why3
ARG compiler=system
RUN opam init -a -y -j2 --compiler=$compiler
RUN opam install -y menhir conf-gtksourceview lablgtk ocamlgraph zarith camlzip
# Alt-Ergo
RUN opam install alt-ergo.1.30
#!/bin/sh
set -e
autoconf && (automake --add-missing 2> /dev/null || true)
docker build -t bench-image-system -f misc/Dockerfile.init .
IMAGE=$CI_REGISTRY_IMAGE:$(echo $CI_COMMIT_REF_NAME | tr -cs "[:alnum:].\n" "-")
docker build -t $IMAGE -f misc/Dockerfile.deploy .
docker login -u $CI_REGISTRY_USER -p $CI_REGISTRY_PASSWORD $CI_REGISTRY
docker push $IMAGE
docker rmi $IMAGE
#!/bin/bash
set -e
docker build -t bench-image-$COMPILER -f misc/Dockerfile.init --build-arg compiler=$COMPILER .
CID=$(docker create --rm -i -w /home/why3/why3 bench-image-$COMPILER /bin/sh)
docker start $CID
docker cp . $CID:/home/why3/why3
docker exec -u root $CID chown -R why3:why3 /home/why3/why3
docker attach $CID <<EOF
exec $@
EOF
#!/bin/bash
# runner:
# apt-get install curl opam automake libgmp-dev zlib1g-dev
# Runner installation
# apt-get install curl autoconf automake
# curl -L https://packages.gitlab.com/install/repositories/runner/gitlab-runner/script.deb.sh | bash
# apt-get install gitlab-runner
# curl -fsSL https://download.docker.com/linux/debian/gpg | apt-key add -
# apt-key fingerprint 0EBFCD88
# echo "deb https://download.docker.com/linux/debian stretch stable" >> /etc/apt/sources.list
# apt-get update
# apt-get install gitlab-runner docker-ce
# gitlab-runner register
# https://gitlab.inria.fr/
# shell
# su gitlab-runner
# cd
# opam init
# opam install menhir alt-ergo
# usermod -aG docker gitlab-runner
set -e
# configuration
autoconf
./configure --enable-local
# compilation
make -j2
# detection of provers
if test "$1" = bench; then
bin/why3config --detect-provers
# run the bench
make bench
fi
