GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
Why3
why3
b408a39e
b408a39e
Andrei Paskevich
add missing cases to alpha_equal and match functions
04e55786
src/core/term.ml
b408a39e
@@ -244,7 +244,7 @@ type binop =
Fimplies
Fimplies
Fiff
Fiff
type
real_constant
type
real_constant
RConstDecimal
of
string
string
string
option
(* int / frac / exp *)
RConstDecimal
of
string
string
string
option
RConstHexa
of
string
string
string
RConstHexa
of
string
string
string
@@ -641,6 +641,8 @@ let rec t_equal_alpha t1 t2 =
x1
x2
x1
x2
Tvar
v1
Tvar
v2
Tvar
v1
Tvar
v2
v1
v2
v1
v2
Tconst
c1
Tconst
c2
c1
c2
Tapp
s1
l1
Tapp
s2
l2
Tapp
s1
l1
Tapp
s2
l2
(* assert (List.length l1 == List.length l2); *)
s1
s2
for_all2
t_equal_alpha
l1
l2
s1
s2
for_all2
t_equal_alpha
l1
l2
@@ -703,6 +705,8 @@ let rec t_match s t1 t2 =
match
t1
t_node
t2
t_node
match
t1
t_node
t2
t_node
Tbvar
x1
Tbvar
x2
when
x1
x2
Tbvar
x1
Tbvar
x2
when
x1
x2
s
s
Tconst
c1
Tconst
c2
when
c1
c2
s
Tvar
v1
_
Tvar
v1
_
try
if
Mvs
find
v1
s
t2
then
s
else
raise
NoMatch
try
if
Mvs
find
v1
s
t2
then
s
else
raise
NoMatch
Not_found
if
t_closed
t2
Not_found
if
t_closed
t2
