Une MAJ de sécurité est nécessaire sur notre version actuelle. Elle sera effectuée lundi 02/08 entre 12h30 et 13h. L'interruption de service devrait durer quelques minutes (probablement moins de 5 minutes).
Commit b3ac0b23 authored by MARCHE Claude's avatar MARCHE Claude
timelimit et nb process configurables dans l IDE
parent 8967561c
......@@ -7,6 +7,8 @@ type t =
mutable window_height : int;
mutable tree_width : int;
mutable task_height : int;
mutable time_limit : int;
mutable max_running_processes : int;
let default =
......@@ -14,6 +16,8 @@ let default =
window_height = 768;
tree_width = 512;
task_height = 384;
time_limit = 2;
max_running_processes = 2;
let conf_file = Filename.concat (Rc.get_home_dir ()) ".whyide.conf"
......@@ -26,6 +30,8 @@ let save_config config =
fprintf fmt "height = %d@\n" config.window_height;
fprintf fmt "tree_width = %d@\n" config.tree_width;
fprintf fmt "task_height = %d@\n" config.task_height;
fprintf fmt "time_limit = %d@\n" config.time_limit;
fprintf fmt "max_processes = %d@\n" config.max_running_processes;
fprintf fmt "@.";
close_out ch
......@@ -35,6 +41,8 @@ let load_main c (key, value) =
| "height" -> c.window_height <- Rc.int value
| "tree_width" -> c.tree_width <- Rc.int value
| "task_height" -> c.task_height <- Rc.int value
| "time_limit" -> c.time_limit <- Rc.int value
| "max_processes" -> c.max_running_processes <- Rc.int value
| s ->
eprintf "Warning: ignore unknown key [%s] in whyide config file@." s
......@@ -185,38 +193,51 @@ let show_about_window () =
let ( _ : GWindow.Buttons.about) = about_dialog#run () in
about_dialog#destroy ()
let nb_processes = ref 2
let preferences () =
let preferences c =
let dialog = GWindow.dialog ~title:"Why: preferences" () in
let vbox = dialog#vbox in
let notebook = GPack.notebook ~packing:vbox#add () in
(** page 1 **)
let label1 = GMisc.label ~text:"Provers" () in
let page1 =
GPack.vbox ~homogeneous:false ~packing:
(fun w -> ignore(notebook#append_page ~tab_label:label1#coerce w)) ()
in
(* debug mode ? *)
let _debugmode =
GButton.check_button ~label:"debug" ~packing:page1#add ()
in
(* timelimit ? *)
let hb = GPack.hbox ~homogeneous:false ~packing:page1#add () in
let _ = GMisc.label ~text:"Time limit" ~packing:hb#add () in
let timelimit_spin = GEdit.spin_button ~digits:0 ~packing:hb#add () in
timelimit_spin#adjustment#set_bounds ~lower:2. ~upper:300. ~step_incr:1. ();
timelimit_spin#adjustment#set_value (float_of_int c.time_limit);
let (_ : GtkSignal.id) =
timelimit_spin#connect#value_changed ~callback:
(fun () -> c.time_limit <- timelimit_spin#value_as_int)
in
(* nb of processes ? *)
let _ = GMisc.label ~text:"Nb of processes" ~packing:hb#add () in
let nb_processes_spin = GEdit.spin_button ~digits:0 ~packing:hb#add () in
nb_processes_spin#adjustment#set_bounds ~lower:1. ~upper:16. ~step_incr:1. ();
nb_processes_spin#adjustment#set_value (float_of_int !nb_processes);
nb_processes_spin#adjustment#set_value (float_of_int c.max_running_processes);
nb_processes_spin#connect#value_changed ~callback:
(fun () -> nb_processes := nb_processes_spin#value_as_int)
(fun () -> c.max_running_processes <- nb_processes_spin#value_as_int)
in
(** page 2 **)
let label2 = GMisc.label ~text:"Misc" () in
let _page2 = GMisc.label ~text:"contents of page 2"
~packing:(fun w -> ignore(notebook#append_page ~tab_label:label2#coerce w)) ()
in
notebook#connect#switch_page
~callback:(fun i -> prerr_endline ("Page switch to " ^ string_of_int i))
in
dialog#add_button "Close" `CLOSE ;
let ( _ : GWindow.Buttons.about) = dialog#run () in
dialog#destroy ()
......@@ -5,6 +5,8 @@ type t =
val read_config : unit -> t
......@@ -37,7 +39,7 @@ val image_failure : GdkPixbuf.pixbuf ref
val show_legend_window : unit -> unit
val show_about_window : unit -> unit
val preferences : unit -> unit
val preferences : t -> unit
Local Variables:
......@@ -44,10 +44,12 @@ let config =
let () = eprintf "%s Load path is: %a@." pname
(Pp.print_list Pp.comma Pp.string) config.loadpath
let timelimit =
match config.timelimit with
| None -> 2
| Some n -> n
......@@ -446,10 +448,13 @@ let image_of_result = function
let () =
begin
Scheduler.async := GtkThread.async;
match config.running_provers_max with
| None -> ()
| Some n ->
if n >= 1 then Scheduler.maximum_running_proofs := n
Scheduler.maximum_running_proofs := gconfig.max_running_processes
......@@ -474,7 +479,7 @@ let rec prover_on_goal p g =
in
callback Scheduler.Scheduled 0.0;
Scheduler.schedule_proof_attempt
~debug:false ~timelimit ~memlimit:0
~debug:false ~timelimit:gconfig.time_limit ~memlimit:0
~prover:p.prover ~command:p.command ~driver:p.driver
~callback
g.Model.task;
......@@ -561,8 +566,11 @@ let file_menu = factory#add_submenu "_File"
let file_factory = new GMenu.factory file_menu ~accel_group
let (_ : GMenu.image_menu_item) =
file_factory#add_image_item ~label:"_Preferences"
~callback:Gconfig.preferences ()
file_factory#add_image_item ~label:"_Preferences" ~callback:
(fun () ->
Gconfig.preferences gconfig;
Scheduler.maximum_running_proofs := gconfig.max_running_processes)
file_factory#add_image_item ~key:GdkKeysyms._Q ~label:"_Quit"
