Commit b284adfa authored by MARCHE Claude's avatar MARCHE Claude
Support for PolyPaver prover
parent 99d922cd
...@@ -4,15 +4,11 @@ ...@@ -4,15 +4,11 @@
printer "metitarski" printer "metitarski"
filename "%f-%t-%g.tptp" filename "%f-%t-%g.tptp"
valid "^SZS status Theorem" valid 0
valid "^SZS status Unsatisfiable" invalid 111
unknown "^SZS status CounterSatisfiable" "" timeout "Gave up on deciding conjecture: TIMED OUT"
unknown "^SZS status Satisfiable" ""
timeout "^SZS status Timeout"
unknown "^SZS status GaveUp" ""
fail "^SZS status Error" ""
time "why3cpulimit time : %s s" time "why3cpulimit time : %s s"
unknown 1 "toto"
(* to be improved *) (* to be improved *)
module TestFloat
use import floating_point.Double
function Sqrt (X : in Float) return Float
pre 1.0 <= X and X <= 2.0;
--# return R =>
--# R <= (1.0+4.0*PolyPaver.Floats.Eps_Rel)*PolyPaver.Exact.Sqrt(X);
is
R,S : Float;
begin
S := X;
R := PolyPaver.Floats.Add(PolyPaver.Floats.Multiply(0.5,X),0.5);
while R /= s loop
--# assert R in -0.25*X**2+X .. 0.25*X**2+1.0 ;
S := r;
R := PolyPaver.Floats.Multiply(0.5,
PolyPaver.Floats.Add(S,PolyPaver.Floats.Divide(X,S)));
end loop;
return R;
end Sqrt;
theory Test theory TestReal
...@@ -8,11 +8,22 @@ theory Test ...@@ -8,11 +8,22 @@ theory Test
use import real.Real use import real.Real
goal add1 : 1.0 + 2.0 = 3.0
goal add2 : 1.2 + 3.4 = 5.6
use import real.Square
use import real.ExpLog use import real.ExpLog
goal exp_hyp:
forall x:real. 0.01 < X < 5.1785 ->
(3.0 + sqr x / 11.0) * ((exp x - exp (-x))/2.0) <
x * (2.0 + (exp x + exp (-x))/2.0 + sqr x / 11.0)
goal g1: goal g1:
forall a b:real. forall a b:real.
-10.0 <= a <= 10.0 /\ -10.0 <= b <= 10.0 /\ b > a + 0.1 -> -10.0 <= a <= 10.0 /\ -10.0 <= b <= 10.0 /\ b > a + 0.1 ->
exp a - exp b > (b-a) * exp ((a + b) / 2.0) exp b - exp a > (b-a) * exp ((a + b) / 2.0)
end end
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE why3session PUBLIC "-//Why3//proof session v5//EN"
"http://why3.lri.fr/why3session.dtd">
<why3session shape_version="4">
<prover id="0" name="PolyPaver" version="0.3" timelimit="3600" memlimit="1000"/>
<file name="../polypaver.why" expanded="true">
<theory name="Test" sum="2676ef260e99a1019e7c4dfb35399b4f" expanded="true">
<goal name="add1" expanded="true">
<proof prover="0" edited="polypaver-Test-add1_1.tptp"><result status="unknown" time="0.01"/></proof>
</goal>
<goal name="add2" expanded="true">
<proof prover="0" timelimit="5"><result status="unknown" time="0.01"/></proof>
</goal>
<goal name="g1" expanded="true">
<proof prover="0"><result status="valid" time="626.99"/></proof>
</goal>
</theory>
</file>
</why3session>
