GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
b1b883a8
b1b883a8
Johannes Kanig
fix usestdin mode for why3server
674e757e
8
8 changed files
58 additions
9 deletions
+58
-9
src/driver/call_provers.ml
+2
-2
src/driver/prove_client.ml
+3
-2
src/driver/prove_client.mli
+1
src/server/README.server
+11
-2
src/server/request.c
+7
-1
src/server/request.h
+3
src/server/server-unix.c
+11
src/server/server-win.c
+20
-2
b1b883a8
@@ -347,7 +347,7 @@ let result_buffer : (server_id, prover_result) Hashtbl.t = Hashtbl.create 17
let
call_on_file
command
limit
res_parser
printer_mapping
let
call_on_file
command
limit
res_parser
printer_mapping
inplace
false
fin
inplace
false
fin
let
id
gen_id
in
let
id
gen_id
in
let
cmd
_
on_timelimit
let
cmd
use_stdin
on_timelimit
actualcommand
cleanup
true
inplace
command
limit
fin
in
actualcommand
cleanup
true
inplace
command
limit
fin
in
let
limit
adapt_limits
limit
on_timelimit
in
let
limit
adapt_limits
limit
on_timelimit
in
let
save
let
save
@@ -359,7 +359,7 @@ let call_on_file ~command ~limit ~res_parser ~printer_mapping
Hashtbl
add
saved_data
id
save
Hashtbl
add
saved_data
id
save
let
timelimit
get_time
limit
in
let
timelimit
get_time
limit
in
let
memlimit
get_mem
limit
in
let
memlimit
get_mem
limit
in
Prove_client
send_request
id
timelimit
memlimit
cmd
Prove_client
send_request
use_stdin
id
timelimit
memlimit
cmd
ServerCall
id
ServerCall
id
let
get_new_results
blocking
let
get_new_results
blocking
b1b883a8
@@ -92,10 +92,11 @@ let set_max_running_provers x =
if
socket
None
then
if
socket
None
then
send_request_string
"parallel;"
string_of_int
x
send_request_string
"parallel;"
string_of_int
x
let
send_request
id
timelimit
memlimit
cmd
let
send_request
use_stdin
id
timelimit
memlimit
cmd
force_connect
force_connect
let
buf
Buffer
create
128
in
let
buf
Buffer
create
128
in
Buffer
add_string
buf
"run;"
let
servercommand
if
use_stdin
then
"runstdin;"
else
"run;"
in
Buffer
add_string
buf
servercommand
Buffer
add_string
buf
string_of_int
id
Buffer
add_string
buf
string_of_int
id
Buffer
add_char
buf
Buffer
add_char
buf
Buffer
add_string
buf
string_of_int
timelimit
Buffer
add_string
buf
string_of_int
timelimit
b1b883a8
@@ -6,6 +6,7 @@ val set_max_running_provers : int -> unit
val
connect
unit
unit
val
connect
unit
unit
val
send_request
val
send_request
use_stdin
bool
id
int
id
int
timelimit
int
timelimit
int
memlimit
int
memlimit
int
b1b883a8
@@ -20,7 +20,7 @@ A client request is a single line which looks like this:
commandkind;payload
commandkind;payload
Where commandkind is a simple string and payload is a semicolon-separated
list. There are currently
only two
possible commands. The first command looks
three
like this:
like this:
run;id;timeout;memlimit;cmd;arg1;arg2;...;argn
@@ -52,7 +52,16 @@ Their meaning is the following:
file - the path to a file which contains the stdout and stderr of the
executed program
executed program
The second commmand is like this:
The second command is very similar:
runstdin;id;timeout;memlimit;cmd;arg1;arg2;...;argn;filename
The meaning of this command is identical to the "run" command, with the
difference that an extra filename is given as the last argument to the
command. This filename is not passed to the command as a commandline argument,
instead it is "piped" into the stdin of the command.
The third commmand is like this:
parallel;num
parallel;num
b1b883a8
@@ -49,6 +49,7 @@ prequest parse_request(char* str_req, int len, int key) {
int
pos
int
pos
prequest
req
prequest
req
char
tmp
char
tmp
bool
runstdin
false
semic
count_semicolons
str_req
len
semic
count_semicolons
str_req
len
if
semic
if
semic
@@ -73,11 +74,16 @@ prequest parse_request(char* str_req, int len, int key) {
pos
copy_up_to_semicolon
str_req
pos
len
tmp
pos
str_req
pos
len
tmp
if
strncmp
tmp
"run"
pos
if
strncmp
tmp
"run"
pos
return
NULL
if
strncmp
tmp
"runstdin"
pos
runstdin
true
else
return
NULL
req
prequest
malloc
sizeof
request
req
prequest
malloc
sizeof
request
req
key
key
req
key
key
req
numargs
numargs
req
numargs
numargs
req
usestdin
runstdin
pos
str_req
pos
len
req
id
pos
str_req
pos
len
req
id
pos
str_req
pos
len
tmp
pos
str_req
pos
len
tmp
req
timeout
atoi
tmp
req
timeout
atoi
tmp
b1b883a8
#ifndef REQUEST_H
#ifndef REQUEST_H
#define REQUEST_H
#define REQUEST_H
#include <stdbool.h>
typedef
struct
typedef
struct
int
key
int
key
char
id
char
id
int
timeout
int
timeout
int
memlimit
int
memlimit
bool
usestdin
char
cmd
// the command to execute
char
cmd
int
numargs
// the length of the following array
int
numargs
char
args
// the arguments of the process to run (not including the command)
char
args
b1b883a8
@@ -241,12 +241,19 @@ void queue_write(pclient client, char* msgbuf) {
pid_t
create_process
char
cmd
pid_t
create_process
char
cmd
int
argc
int
argc
char
argv
char
argv
bool
usestdin
int
outfile
int
outfile
int
timelimit
int
timelimit
int
memlimit
int
memlimit
struct
rlimit
res
struct
rlimit
res
int
i
int
i
char
unix_argv
char
unix_argv
int
count
argc
// in the case of usestdin, the last argument is in fact not passed to
// execvp, it contains the filename instead
if
usestdin
count
unix_argv
char
malloc
sizeof
char
argc
2
unix_argv
char
malloc
sizeof
char
argc
2
unix_argv
cmd
unix_argv
cmd
unix_argv
argc
NULL
unix_argv
argc
NULL
@@ -292,6 +299,9 @@ pid_t create_process(char* cmd,
//adapt stdout/stderr
dup2
outfile
dup2
outfile
dup2
outfile
2
dup2
outfile
2
if
usestdin
freopen
argv
argc
"r"
stdin
/* execute the command */
execvp
cmd
unix_argv
execvp
cmd
unix_argv
@@ -405,6 +415,7 @@ void run_request (prequest r) {
id
create_process
r
cmd
id
create_process
r
cmd
r
numargs
r
numargs
r
args
r
args
r
usestdin
out_descr
out_descr
r
timeout
r
timeout
r
memlimit
r
memlimit
b1b883a8
@@ -224,13 +224,20 @@ void run_request (prequest r) {
char
outfile
char
outfile
pproc
proc
pproc
proc
int
key
int
key
int
argcount
r
numargs
JOBOBJECT_EXTENDED_LIMIT_INFORMATION
limits
limits
JOBOBJECT_ASSOCIATE_COMPLETION_PORT
portassoc
portassoc
STARTUPINFO
si
STARTUPINFO
si
HANDLE
ghJob
outfilehandle
HANDLE
ghJob
outfilehandle
infilehandle
PROCESS_INFORMATION
pi
PROCESS_INFORMATION
pi
pclient
client
pclient
client
// CreateProcess, it contains the filename instead
if
r
usestdin
argcount
client
pclient
list_lookup
clients
r
key
client
pclient
list_lookup
clients
r
key
if
client
NULL
if
client
NULL
return
return
@@ -246,6 +253,17 @@ void run_request (prequest r) {
// set the stdout for the childprocess
si
hStdOutput
outfilehandle
si
hStdOutput
outfilehandle
si
hStdError
outfilehandle
si
hStdError
outfilehandle
if
r
usestdin
infilehandle
CreateFile
r
args
argcount
GENERIC_READ
FILE_SHARE_READ
NULL
OPEN_ALWAYS
FILE_ATTRIBUTE_NORMAL
NULL
si
hSdtInput
infilehandle
// if we don't set that flag, the stdout we just set won't even be looked at
si
dwFlags
STARTF_USESTDHANDLES
si
dwFlags
/* Compute command line string. When a parameter contains a " or a space we
@@ -260,7 +278,7 @@ void run_request (prequest r) {
/* Now take care of the arguments */
int
k
int
k
for
k
k
r
numargs
k
for
k
k
argcount
k
char
ca
r
args
k
/* current arg */
char
ca
r
args
k
/* current arg */
int
ca_index
/* index of the current character in ca */
int
ca_index
