Commit b06f27ae authored by Sylvain Dailler's avatar Sylvain Dailler
First attempt at having a printer using a label name:.
parent 792b4083
......@@ -98,6 +98,25 @@ let get_model_trace_string ~labels =
| [_; t_str] -> t_str
| _ -> ""
(* Functions for working with ITP labels *)
let is_name_label label =
Strings.has_prefix "name:" label.lab_string
let get_name_label ~labels = Slab.choose (Slab.filter is_name_label labels)
let get_element_name ~labels =
let name_label = get_name_label ~labels in
let splitted1 = Strings.bounded_split ':' name_label.lab_string 2 in
match splitted1 with
| ["name"; content] ->
begin
content
end;
| [_] -> ""
| _ -> assert false
(** Identifiers *)
......@@ -209,6 +228,22 @@ let id_unique printer ?(sanitizer = same) id =
Hid.replace printer.values id name;
name
let id_unique_label printer ?(sanitizer = same) id =
try
Hid.find printer.values id
with Not_found ->
let labels = id.id_label in
if Slab.exists is_name_label labels then
let name = sanitizer (get_element_name ~labels) in
let name = find_unique printer.indices name in
name
else
let name = sanitizer (printer.sanitizer id.id_string) in
name
let string_unique printer s = find_unique printer.indices s
let forget_id printer id =
......@@ -119,6 +119,11 @@ val id_unique :
(** use ident_printer to generate a unique name for ident
an optional sanitizer is applied over the printer's sanitizer *)
val id_unique_label :
ident_printer -> ?sanitizer : (string -> string) -> ident -> string
(** Do the same as id_unique except that it tries first to
use the "name:" label to generate the name instead of id.id_string *)
val string_unique : ident_printer -> string -> string
(** Uniquify string *)
......@@ -20,6 +20,11 @@ let fresh_printer =
open Stdlib
let sanitizer x = x (*sanitizer char_to_lalpha char_to_lalpha x*)
let id_unique printer id =
id_unique_label printer ~sanitizer:sanitizer id
type name_tables = {
namespace : namespace;
known_map : known_map;
......@@ -2,7 +2,7 @@
theory Test
use import int.Int
goal G: forall x. exists y. x = 2 * y
goal G: forall x "name:TOTO". forall y. x = y -> x = 2 * y
ng
t introduce_premises
(* print goal with premisses introduced *)
k
t cut "y = y"
t cut "TOTO = TOTO"
t cut "exists x: int. x = x"
(* print goal with h in context *)
t exists "5"
