GitLab
What's new
10
Support
Community forum
Keyboard shortcuts
Why3
why3
b0166d3a
b0166d3a
MARCHE Claude
explicit prover result "steps limit exceeded"
+ fixed wrong step limit in one session
a61a3a90
24
24 changed files
123 additions
86 deletions
+123
-86
drivers/alt_ergo_common.drv
+1
-1
drivers/cvc4.drv
drivers/cvc4.drv
+0
-1
drivers/cvc4_14.drv
drivers/cvc4_14.drv
+2
-7
drivers/smt-libv2.drv
+2
-2
examples/vacid_0_red_black_trees/why3session.xml
+4
-4
share/images/fatcow/brick_delete.png
+0
share/images/fatcow/database_delete.png
+0
share/images/fatcow/time_delete.png
+0
share/images/icons.rc
+8
-4
share/provers-detection-data.conf
+2
-2
src/coq-tactic/why3tac.ml4
+1
src/driver/call_provers.ml
+3
-1
src/driver/call_provers.mli
+4
-2
src/driver/driver.ml
+6
-1
src/driver/driver_ast.ml
+2
src/driver/driver_lexer.mll
+1
src/driver/driver_parser.mly
+4
-1
src/ide/gconfig.ml
src/ide/gconfig.ml
+10
src/ide/gconfig.mli
src/ide/gconfig.mli
+2
src/ide/gmain.ml
src/ide/gmain.ml
+3
src/session/session.ml
+1
src/session/session_scheduler.ml
+63
-60
src/why3session/why3session_html.ml
+2
src/why3session/why3session_latex.ml
+2
b0166d3a
@@ -9,7 +9,7 @@ valid "Valid"
invalid "Invalid"
invalid "Invalid"
unknown "I don't know" ""
timeout "Timeout"
timeout "Timeout"
timeout
"Steps limit reached"
stepslimitexceeded
outofmemory "Fatal error: out of memory"
outofmemory "Fatal error: exception Stack_overflow"
fail "typing error:\\(.*\\)$" "Failure : File generation error : \\1"
drivers/cvc4.drv
b0166d3a
@@ -27,7 +27,6 @@ transformation "encoding_smt"
outofmemory "(error \".*out of memory\")\\|Cannot allocate memory"
timeout "interrupted by timeout"
steps "smt::SmtEngine::resourceUnitsUsed, \\([0-9]+.?[0-9]*\\)" 1
(** Extra theories supported by CVC4 *)
drivers/cvc4_14.drv
b0166d3a
@@ -35,14 +35,9 @@ transformation "encoding_smt_if_poly"
stepslimitexceeded "??"
(* regexp for steps should match things like
smt::SmtEngine::resourceUnitsUsed, 1041
but not in the same line as the "valid" answer
b0166d3a
@@ -18,9 +18,9 @@ prelude "(set-logic AUFNIRA)"
printer "smtv2"
printer "smtv2"
filename "%f-%t-%g.smt2"
unknown "^\\(unknown\\|sat\\|Fail\\)" ""
time "why3cpulimit time : %s s"
valid "^unsat"
valid "^unsat
theory BuiltIn
theory BuiltIn
b0166d3a
@@ -135,8 +135,8 @@
@@ -135,8 +135,8 @@
<goal
name=
"almost_rbtree_rbtree_black"
<goal
name=
<proof
prover=
"7"
timelimit=
"10"
memlimit=
"0"
><result
status=
"valid"
time=
"0.01"
steps=
"14"
/></proof>
<proof
prover=
"7"
timelimit=
"10"
memlimit=
"0"
><result
status=
"valid"
time=
"0.01"
steps=
"14"
/></proof>
</goal>
</goal>
<goal
name=
"WP_parameter lbalance"
expl=
"VC for lbalance"
<goal
name=
expl=
"VC for lbalance"
expanded=
"true"
<transf
name=
"split_goal_wp"
<transf
name=
"split_goal_wp"
expanded=
"true"
<goal
name=
"WP_parameter lbalance.1"
expl=
"1. postcondition"
<goal
name=
expl=
"1. postcondition"
<transf
name=
"split_goal_wp"
<transf
name=
"split_goal_wp"
<goal
name=
"WP_parameter lbalance.1.1"
expl=
"1."
<goal
name=
expl=
"1."
@@ -713,8 +713,8 @@
@@ -713,8 +713,8 @@
</goal>
</goal>
</transf>
</transf>
</goal>
</goal>
<goal
name=
"WP_parameter lbalance.11"
expl=
"11. postcondition"
<goal
name=
expl=
"11. postcondition"
expanded=
"true"
<proof
prover=
"0"
><result
status=
"valid"
time=
0.71
steps=
"117
2
/></proof>
<proof
prover=
"0"
><result
status=
"valid"
time=
1.20
steps=
"117
3
/></proof>
</goal>
</goal>
<goal
name=
"WP_parameter lbalance.12"
expl=
"12. postcondition"
<goal
name=
expl=
"12. postcondition"
<proof
prover=
"4"
><result
status=
"valid"
time=
"0.04"
/></proof>
<proof
prover=
"4"
><result
status=
"valid"
time=
"0.04"
/></proof>
b0166d3a
2.16 KB
b0166d3a
1.8 KB
b0166d3a
2.41 KB
b0166d3a
@@ -9,12 +9,14 @@ unknown = "help32"
invalid = "delete32"
timeout = "clock32"
timeout = "clock32"
outofmemory = "deletefile32"
stepslimitexceeded = "cut32"
failure = "bug32"
failure = "bug32"
valid_obs = "obsaccept32"
unknown_obs = "obshelp32"
invalid_obs = "obsdelete32"
timeout_obs = "obsclock32"
outofmemory_obs = "obsdeletefile32"
stepslimitexceeded_obs = "cut32"
failure_obs = "obsbug32"
yes = "accept32"
yes = "accept32"
no = "delete32"
no = "delete32"
@@ -41,14 +43,16 @@ running = "control_play_blue"
valid = "accept"
valid = "accept"
unknown = "help"
unknown = "help"
invalid = "exclamation"
timeout = "timeline"
timeout = "time_delete"
outofmemory = "ddr_memory"
outofmemory = "database_delete"
stepslimitexceeded = "brick_delete"
failure = "bomb"
failure = "bomb"
valid_obs = "bullet_green"
unknown_obs = "bullet_blue"
invalid_obs = "bullet_red"
timeout_obs = "bullet_white"
timeout_obs = "time_delete"
outofmemory_obs = "bullet_white"
outofmemory_obs = "database_delete"
stepslimitexceeded_obs = "brick_delete"
failure_obs = "bullet_black"
yes = "accept"
yes = "accept"
no = "delete"
no = "delete"
b0166d3a
@@ -66,8 +66,8 @@ version_ok = "1.4"
driver
"drivers/cvc4_14.drv"
driver
# --random-seed=42 is not needed as soon as --random-freq=0.0 by default
# to try: --inst-when=full-last-call
command
"%l/why3-cpulimit %T %m -s %e --tlimit-per=%t000 --lang=smt2 %f"
command
--stats
command_steps
"%l/why3-cpulimit %U %m -s %e --rlimit=%S --lang=smt2 %f"
command_steps
--stats
# CVC4 version 1.0 to 1.3
ATP
cvc4
ATP
cvc4
b0166d3a
@@ -1289,6 +1289,7 @@ let why3tac ?(timelimit=timelimit) s gl =
| Call_provers.Failure s -> error ("Failure: " ^ s)
| Call_provers.Timeout -> error "Timeout"
| OutOfMemory -> error "Out Of Memory"
| StepsLimitExceeded -> error "Steps Limit reached"
| HighFailure ->
| HighFailure ->
error ("Prover failure\n" ^ res.pr_output ^ "\n")
b0166d3a
@@ -87,6 +87,7 @@ type prover_answer =
Invalid
Invalid
Timeout
Timeout
OutOfMemory
OutOfMemory
StepsLimitExceeded
Unknown
of
string
Unknown
of
string
Failure
of
string
Failure
of
string
HighFailure
HighFailure
@@ -111,6 +112,7 @@ let print_prover_answer fmt = function
Invalid
fprintf
fmt
"Invalid"
Invalid
fprintf
fmt
"Invalid"
Timeout
fprintf
fmt
"Timeout"
Timeout
fprintf
fmt
"Timeout"
OutOfMemory
fprintf
fmt
"Ouf Of Memory"
OutOfMemory
fprintf
fmt
"Ouf Of Memory"
StepsLimitExceeded
fprintf
fmt
"Steps limit exceeded"
Unknown
fprintf
fmt
"Unknown"
Unknown
fprintf
fmt
"Unknown"
Failure
fprintf
fmt
"Failure"
Failure
fprintf
fmt
"Failure"
Unknown
s
fprintf
fmt
"Unknown (%s)"
s
Unknown
s
fprintf
fmt
"Unknown (%s)"
s
@@ -139,7 +141,7 @@ let rec grep out l = match l with
begin
try
begin
try
ignore
Str
search_forward
re
out
ignore
Str
search_forward
re
out
match
pa
match
pa
Valid
Invalid
Timeout
OutOfMemory
pa
Valid
Invalid
Timeout
OutOfMemory
StepsLimitExceeded
pa
Unknown
s
Unknown
Str
replace_matched
s
out
Unknown
s
Unknown
Str
replace_matched
s
out
Failure
s
Failure
Str
replace_matched
s
out
Failure
s
Failure
Str
replace_matched
s
out
HighFailure
assert
false
HighFailure
assert
false
b0166d3a
@@ -17,9 +17,11 @@ type prover_answer =
Invalid
Invalid
(** The task is invalid *)
Timeout
Timeout
(** the task timeout, ie it takes more time than specified *)
s
OutOfMemory
OutOfMemory
(** the task runs out of memory *)
StepsLimitExceeded
(** the task required more steps than the limit provided *)
Unknown
of
string
Unknown
of
string
(** The prover can't determine if the task is valid *)
Failure
of
string
Failure
of
string
b0166d3a
@@ -89,14 +89,19 @@ let load_driver = let driver_tag = ref (-1) in fun env file extra_files ->
RegexpInvalid
s
add_to_list
regexps
Str
regexp
s
Invalid
RegexpInvalid
s
add_to_list
regexps
Str
regexp
s
Invalid
RegexpTimeout
s
add_to_list
regexps
Str
regexp
s
Timeout
RegexpTimeout
s
add_to_list
regexps
Str
regexp
s
Timeout
RegexpOutOfMemory
s
add_to_list
regexps
Str
regexp
s
OutOfMemory
RegexpOutOfMemory
s
add_to_list
regexps
Str
regexp
s
OutOfMemory
RegexpStepsLimitExceeded
s
add_to_list
regexps
Str
regexp
s
StepsLimitExceeded
RegexpUnknown
s
t
add_to_list
regexps
Str
regexp
s
Unknown
t
RegexpUnknown
s
t
add_to_list
regexps
Str
regexp
s
Unknown
t
RegexpFailure
s
t
add_to_list
regexps
Str
regexp
s
Failure
t
RegexpFailure
s
t
add_to_list
regexps
Str
regexp
s
Failure
t
TimeRegexp
r
add_to_list
timeregexps
Call_provers
timeregexp
r
TimeRegexp
r
add_to_list
timeregexps
Call_provers
timeregexp
r
StepRegexp
r
ns
add_to_list
stepsregexps
Call_provers
stepsregexp
r
ns
StepRegexp
r
ns
add_to_list
stepsregexps
Call_provers
stepsregexp
r
ns
ExitCodeValid
s
add_to_list
exitcodes
s
Valid
ExitCodeValid
s
add_to_list
exitcodes
s
Valid
ExitCodeInvalid
s
add_to_list
exitcodes
s
Invalid
ExitCodeInvalid
s
add_to_list
exitcodes
s
Invalid
ExitCodeTimeout
s
add_to_list
exitcodes
s
Timeout
ExitCodeTimeout
s
add_to_list
exitcodes
s
Timeout
ExitCodeOutOfMemory
s
add_to_list
exitcodes
s
OutOfMemory
ExitCodeOutOfMemory
s
add_to_list
exitcodes
s
OutOfMemory
ExitCodeStepsLimitExceeded
s
add_to_list
exitcodes
s
StepsLimitExceeded
ExitCodeUnknown
s
t
add_to_list
exitcodes
s
Unknown
t
ExitCodeUnknown
s
t
add_to_list
exitcodes
s
Unknown
t
ExitCodeFailure
s
t
add_to_list
exitcodes
s
Failure
t
ExitCodeFailure
s
t
add_to_list
exitcodes
s
Failure
t
Filename
s
set_or_raise
loc
filename
s
"filename"
Filename
s
set_or_raise
loc
filename
s
"filename"
b0166d3a
@@ -57,6 +57,7 @@ type global =
RegexpInvalid
of
string
RegexpInvalid
of
string
RegexpTimeout
of
string
RegexpTimeout
of
string
RegexpOutOfMemory
of
string
RegexpOutOfMemory
of
string
of
string
RegexpUnknown
of
string
string
RegexpUnknown
of
string
string
RegexpFailure
of
string
string
RegexpFailure
of
string
string
TimeRegexp
of
string
TimeRegexp
of
string
@@ -65,6 +66,7 @@ type global =
ExitCodeInvalid
of
int
ExitCodeInvalid
of
int
ExitCodeTimeout
of
int
ExitCodeTimeout
of
int
ExitCodeOutOfMemory
of
int
ExitCodeOutOfMemory
of
int
of
int
ExitCodeUnknown
of
int
string
ExitCodeUnknown
of
int
string
ExitCodeFailure
of
int
string
ExitCodeFailure
of
int
string
Filename
of
string
Filename
of
string
b0166d3a
@@ -36,6 +36,7 @@
@@ -36,6 +36,7 @@
"invalid"
INVALID
"invalid"
INVALID
"timeout"
TIMEOUT
"timeout"
TIMEOUT
"outofmemory"
OUTOFMEMORY
"outofmemory"
OUTOFMEMORY
"stepslimitexceeded"
STEPSLIMITEXCEEDED
"time"
TIME
"time"
TIME
"unknown"
UNKNOWN
"unknown"
UNKNOWN
"fail"
FAIL
"fail"
FAIL
b0166d3a
@@ -23,7 +23,8 @@
@@ -23,7 +23,8 @@
token
string
OPERATOR
token
string
OPERATOR
token
string
INPUT
(* never reaches the parser *)
token
string
INPUT
token
THEORY
END
SYNTAX
REMOVE
META
PRELUDE
PRINTER
token
THEORY
END
SYNTAX
REMOVE
META
PRELUDE
PRINTER
token
VALID
INVALID
TIMEOUT
OUTOFMEMORY
UNKNOWN
FAIL
TIME
STEPS
token
VALID
INVALID
UNKNOWN
FAIL
token
TIMEOUT
OUTOFMEMORY
STEPSLIMITEXCEEDED
TIME
STEPS
token
UNDERSCORE
LEFTPAR
RIGHTPAR
DOT
QUOTE
EOF
token
UNDERSCORE
LEFTPAR
RIGHTPAR
DOT
QUOTE
EOF
token
BLACKLIST
token
BLACKLIST
token
MODULE
EXCEPTION
VAL
CONVERTER
token
MODULE
EXCEPTION
VAL
CONVERTER
@@ -55,6 +56,7 @@ global:
INVALID
STRING
RegexpInvalid
2
INVALID
STRING
RegexpInvalid
2
TIMEOUT
STRING
RegexpTimeout
2
TIMEOUT
STRING
RegexpTimeout
2
OUTOFMEMORY
STRING
RegexpOutOfMemory
2
OUTOFMEMORY
STRING
RegexpOutOfMemory
2
STEPSLIMITEXCEEDED
STRING
2
TIME
STRING
TimeRegexp
2
TIME
STRING
TimeRegexp
2
STEPS
STRING
INTEGER
StepRegexp
2
3
STEPS
STRING
INTEGER
StepRegexp
2
3
UNKNOWN
STRING
STRING
RegexpUnknown
2
3
UNKNOWN
STRING
STRING
RegexpUnknown
2
3
@@ -62,6 +64,7 @@ global:
VALID
INTEGER
ExitCodeValid
2
VALID
INTEGER
ExitCodeValid
2
INVALID
INTEGER
ExitCodeInvalid
2
INVALID
INTEGER
ExitCodeInvalid
2
TIMEOUT
INTEGER
ExitCodeTimeout
2
TIMEOUT
INTEGER
ExitCodeTimeout
2
STEPSLIMITEXCEEDED
INTEGER
2
UNKNOWN
INTEGER
STRING
ExitCodeUnknown
2
3
UNKNOWN
INTEGER
STRING
ExitCodeUnknown
2
3
FAIL
INTEGER
STRING
ExitCodeFailure
2
3
FAIL
INTEGER
STRING
ExitCodeFailure
2
3
FILENAME
STRING
Filename
2
FILENAME
STRING
Filename
2
src/ide/gconfig.ml
b0166d3a
@@ -265,12 +265,14 @@ let image_unknown = ref !image_default
let
image_invalid
ref
image_default
let
image_invalid
ref
image_default
let
image_timeout
ref
image_default
let
image_timeout
ref
image_default
let
image_outofmemory
ref
image_default
let
image_outofmemory
ref
image_default
let
image_stepslimitexceeded
ref
image_default
let
image_failure
ref
image_default
let
image_failure
ref
image_default
let
image_valid_obs
ref
image_default
let
image_valid_obs
ref
image_default
let
image_unknown_obs
ref
image_default
let
image_unknown_obs
ref
image_default
let
image_invalid_obs
ref
image_default
let
image_invalid_obs
ref
image_default
let
image_timeout_obs
ref
image_default
let
image_timeout_obs
ref
image_default
let
image_outofmemory_obs
ref
image_default
let
ref
image_default
let
image_stepslimitexceeded_obs
ref
image_default
let
image_failure_obs
ref
image_default
let
image_failure_obs
ref
image_default
let
image_yes
ref
image_default
let
image_yes
ref
image_default
let
image_no
ref
image_default
let
image_no
ref
image_default
@@ -310,12 +312,14 @@ let iconname_unknown = ref ""
let
iconname_invalid
ref
let
iconname_invalid
ref
let
iconname_timeout
ref
let
iconname_timeout
ref
let
iconname_outofmemory
ref
let
ref
let
iconname_stepslimitexceeded
ref
let
iconname_failure
ref
let
iconname_failure
ref
let
iconname_valid_obs
ref
let
iconname_valid_obs
ref
let
iconname_unknown_obs
ref
let
ref
let
iconname_invalid_obs
ref
let
ref
let
iconname_timeout_obs
ref
let
ref
let
iconname_outofmemory_obs
ref
let
ref
let
iconname_stepslimitexceeded_obs
ref
let
iconname_failure_obs
ref
let
ref
let
iconname_yes
ref
let
iconname_yes
ref
let
iconname_no
ref
let
iconname_no
ref
@@ -354,12 +358,14 @@ let load_icon_names () =
iconname_invalid
get_icon_name
"invalid"
iconname_invalid
get_icon_name
"invalid"
iconname_timeout
get_icon_name
"timeout"
iconname_timeout
get_icon_name
"timeout"
get_icon_name
"outofmemory"
get_icon_name
"outofmemory"
get_icon_name
iconname_failure
get_icon_name
"failure"
iconname_failure
get_icon_name
"failure"
iconname_valid_obs
get_icon_name
"valid_obs"
iconname_valid_obs
get_icon_name
"valid_obs"
get_icon_name
"unknown_obs"
get_icon_name
"unknown_obs"
get_icon_name
"invalid_obs"
get_icon_name
"invalid_obs"
get_icon_name
"timeout_obs"
get_icon_name
"timeout_obs"
get_icon_name
"outofmemory_obs"
get_icon_name
"outofmemory_obs"
get_icon_name
"stepslimitexceeded_obs"
get_icon_name
"failure_obs"
get_icon_name
"failure_obs"
iconname_yes
get_icon_name
"yes"
iconname_yes
get_icon_name
"yes"
iconname_no
get_icon_name
"no"
iconname_no
get_icon_name
"no"
@@ -387,12 +393,14 @@ let resize_images size =
image_invalid
size
iconname_invalid
image_invalid
size
iconname_invalid
image_timeout
size
iconname_timeout
image_timeout
size
iconname_timeout
image_outofmemory
size
image_outofmemory
size
size
image_failure
size
iconname_failure
image_failure
size
iconname_failure
image_valid_obs
size
iconname_valid_obs
image_valid_obs
size
iconname_valid_obs
image_unknown_obs
size
image_unknown_obs
size
image_invalid_obs
size
image_invalid_obs
size
image_timeout_obs
size
image_timeout_obs
size
size
size
size
image_failure_obs
size
image_failure_obs
size
image_yes
size
iconname_yes
image_yes
size
iconname_yes
image_no
size
iconname_no
image_no
size
iconname_no
@@ -458,6 +466,8 @@ let show_legend_window () =
i
" External prover reached the time limit
\n
i
\n
ib
image_outofmemory
ib
image_outofmemory
i
" External prover ran out of memory
\n
i
\n
ib
i
" External prover exceeded the steps limit
\n
ib
image_unknown
ib
image_unknown
i
" External prover answer not conclusive
\n
i
\n
ib
image_failure
ib
image_failure
src/ide/gconfig.mli
b0166d3a
@@ -82,12 +82,14 @@ val image_valid : GdkPixbuf.pixbuf ref
val
image_invalid
GdkPixbuf
pixbuf
ref
val
image_invalid
GdkPixbuf
pixbuf
ref
val
image_timeout
GdkPixbuf
pixbuf
ref
val
image_timeout
GdkPixbuf
pixbuf
ref
val
image_outofmemory
GdkPixbuf
pixbuf
ref
val
image_outofmemory
GdkPixbuf
pixbuf
ref
val
GdkPixbuf
pixbuf
ref
val
image_unknown
GdkPixbuf
pixbuf
ref
val
image_unknown
GdkPixbuf
pixbuf
ref
val
image_failure
GdkPixbuf
pixbuf
ref
val
image_failure
GdkPixbuf
pixbuf
ref
val
image_valid_obs
GdkPixbuf
pixbuf
ref
val
image_valid_obs
GdkPixbuf
pixbuf
ref
val
image_invalid_obs
GdkPixbuf
pixbuf
ref
val
image_invalid_obs
GdkPixbuf
pixbuf
ref
val
image_timeout_obs
GdkPixbuf
pixbuf
ref
val
image_timeout_obs
GdkPixbuf
pixbuf
ref
val
GdkPixbuf
pixbuf
ref
val
GdkPixbuf
pixbuf
ref
val
GdkPixbuf
pixbuf
ref
val
image_unknown_obs
GdkPixbuf
pixbuf
ref
val
image_unknown_obs
GdkPixbuf
pixbuf
ref
val
image_failure_obs
GdkPixbuf
pixbuf
ref
val
image_failure_obs
GdkPixbuf
pixbuf
ref
src/ide/gmain.ml
b0166d3a
@@ -415,6 +415,9 @@ let image_of_result ~obsolete result =
if
obsolete
then
image_timeout_obs
else
image_timeout
if
obsolete
then
image_timeout_obs
else
image_timeout
Call_provers
OutOfMemory
Call_provers
OutOfMemory
if
obsolete
then
else
image_outofmemory
if
obsolete
then
else
image_outofmemory
Call_provers
StepsLimitExceeded
if
obsolete
then
else
Call_provers
Unknown
_
Call_provers
Unknown
_
if
obsolete
then
image_unknown_obs
else
image_unknown
if
obsolete
then
image_unknown_obs
else
image_unknown
Call_provers
Failure
_
Call_provers
Failure
_
b0166d3a
@@ -562,6 +562,7 @@ let save_result fmt r =
Call_provers
HighFailure
"highfailure"
Call_provers
HighFailure
"highfailure"
Call_provers
Timeout
"timeout"
Call_provers
Timeout
"timeout"
Call_provers
OutOfMemory
"outofmemory"
Call_provers
OutOfMemory
"outofmemory"
Call_provers
StepsLimitExceeded
Call_provers
Invalid
"invalid"
Call_provers
Invalid
"invalid"
r
Call_provers
pr_time
r
Call_provers
pr_time
opt
pp_print_int
"steps"
steps
opt
pp_print_int
"steps"
steps
b0166d3a
@@ -415,6 +415,7 @@ let adapt_limits a =
match
r
match
r
Call_provers
OutOfMemory
increased_time
a
proof_memlimit
Call_provers
OutOfMemory
increased_time
a
proof_memlimit
Call_provers
Timeout
a
proof_timelimit
increased_mem
Call_provers
Timeout
a
proof_timelimit
increased_mem
Call_provers
StepsLimitExceeded
Call_provers
Valid
Call_provers
Valid
Call_provers
Unknown
_
Call_provers
Unknown
_
Call_provers
Invalid
increased_time
increased_mem
Call_provers
Invalid
increased_time
increased_mem
@@ -596,66 +597,6 @@ let run_prover eS eT ~context_unproved_goals_only ~timelimit ~memlimit pr a =
prover_on_goal_or_children
eS
eT
eS
eT
timelimit
memlimit
pr
m
metas_goal
timelimit
memlimit
pr
m
metas_goal
(* method: replay obsolete proofs *)
(* in the default context, a proof should be replayed if
. it was successful or
. it was just edited
let
proof_should_be_replayed
a
match
a
proof_state
Done
Call_provers
pr_answer
Call_provers
Valid
JustEdited
true
_
false
let
rec
replay_on_goal_or_children
eS
eT
obsolete_only
g
iter_goal
fun
a
if
not
obsolete_only
a
proof_obsolete
then
if
not
a
then
run_external_proof
eS
eT
a
iter_transf
eS
eT
obsolete_only
iter_metas
eS
eT
obsolete_only
g
let
replay
eS
eT
obsolete_only
a
match
a
Goal
g
eS
eT
obsolete_only
g
Theory
th
iter
eS
eT
obsolete_only
th
theory_goals
File
file
iter
fun
th
iter
eS
eT
obsolete_only
th
theory_goals
file
file_theories
Proof_attempt
a
eS
eT
obsolete_only
a
proof_parent
Transf
tr
iter
eS
eT
obsolete_only
