Mise à jour terminée. Pour connaître les apports de la version 13.8.4 par rapport à notre ancienne version vous pouvez lire les "Release Notes" suivantes :
https://about.gitlab.com/releases/2021/02/11/security-release-gitlab-13-8-4-released/
https://about.gitlab.com/releases/2021/02/05/gitlab-13-8-3-released/
Commit af175380 authored by Guillaume Melquiond's avatar Guillaume Melquiond
Remove $blockScrolling occurrences, as they are no longer needed since Ace 1.3.
parent 8e74b20e
...@@ -136,23 +136,19 @@ module Editor = ...@@ -136,23 +136,19 @@ module Editor =
let clear_annotations () = let clear_annotations () =
editor ## getSession ## clearAnnotations editor ## getSession ## clearAnnotations
let _Infinity : int = get_global "Infinity"
let scroll_to_end e = let scroll_to_end e =
let len = e ## getSession ## getLength in let len = e ## getSession ## getLength in
let last_line = len - 1 in let last_line = len - 1 in
e ## gotoLine last_line _Infinity Js._false e ## gotoLine last_line 0 Js._false
let () = let () =
let editor_theme : Js.js_string Js.t = get_global "editor_theme" in let editor_theme : Js.js_string Js.t = get_global "editor_theme" in
let task_viewer_mode : Js.js_string Js.t = get_global "task_viewer_mode" in let task_viewer_mode : Js.js_string Js.t = get_global "task_viewer_mode" in
editor ## setTheme editor_theme; editor ## setTheme editor_theme;
JSU.(set editor (Js.string "$blockScrolling") _Infinity);
task_viewer ## setTheme editor_theme; task_viewer ## setTheme editor_theme;
task_viewer ## getSession ## setMode task_viewer_mode; task_viewer ## getSession ## setMode task_viewer_mode;
JSU.(set task_viewer (Js.string "$blockScrolling") _Infinity);
task_viewer ## setReadOnly Js._true task_viewer ## setReadOnly Js._true
