Commit aeed1092 authored by Guillaume Melquiond's avatar Guillaume Melquiond
Rely on autoconf for installation (bug #20195).
Autoconf mandates an install-sh shell script. It can be installed using
"automake --add-missing" when working from the git repository.
parent 6031de02
...@@ -29,6 +29,7 @@ why3.conf ...@@ -29,6 +29,7 @@ why3.conf
/autom4te.cache /autom4te.cache
/Makefile /Makefile
/configure /configure
/install-sh
/semantic.cache /semantic.cache
/TAGS /TAGS
/output_why3 /output_why3
...@@ -37,6 +37,9 @@ EXE = @EXE@ ...@@ -37,6 +37,9 @@ EXE = @EXE@
# other variables # other variables
CC = @CC@ CC = @CC@
MKDIR_P = @MKDIR_P@
INSTALL = @INSTALL@
INSTALL_DATA = @INSTALL_DATA@
OCAMLC = @OCAMLC@ OCAMLC = @OCAMLC@
OCAMLOPT = @OCAMLOPT@ OCAMLOPT = @OCAMLOPT@
OCAMLDEP = @OCAMLDEP@ OCAMLDEP = @OCAMLDEP@
...@@ -288,38 +291,38 @@ install_no_local:: clean_old_install ...@@ -288,38 +291,38 @@ install_no_local:: clean_old_install
else else
install_no_local:: clean_old_install $(TARGET_EMACS) install_no_local:: clean_old_install $(TARGET_EMACS)
endif endif
mkdir -p $(BINDIR) $(MKDIR_P) $(BINDIR)
mkdir -p $(LIBDIR)/why3 $(MKDIR_P) $(LIBDIR)/why3
mkdir -p $(TOOLDIR) $(MKDIR_P) $(TOOLDIR)
mkdir -p $(DATADIR)/why3 $(MKDIR_P) $(DATADIR)/why3
mkdir -p $(DATADIR)/why3/images $(MKDIR_P) $(DATADIR)/why3/images
mkdir -p $(DATADIR)/why3/vim $(MKDIR_P) $(DATADIR)/why3/vim
mkdir -p $(DATADIR)/why3/lang $(MKDIR_P) $(DATADIR)/why3/lang
mkdir -p $(DATADIR)/why3/theories $(MKDIR_P) $(DATADIR)/why3/theories
mkdir -p $(DATADIR)/why3/modules/mach $(MKDIR_P) $(DATADIR)/why3/modules/mach
mkdir -p $(DATADIR)/why3/drivers $(MKDIR_P) $(DATADIR)/why3/drivers
mkdir -p $(DATADIR)/emacs/site-lisp/ $(MKDIR_P) $(DATADIR)/emacs/site-lisp/
cp -f theories/*.why $(DATADIR)/why3/theories $(INSTALL_DATA) theories/*.why $(DATADIR)/why3/theories
cp -f modules/*.mlw $(DATADIR)/why3/modules $(INSTALL_DATA) modules/*.mlw $(DATADIR)/why3/modules
cp -f modules/mach/*.mlw $(DATADIR)/why3/modules/mach $(INSTALL_DATA) modules/mach/*.mlw $(DATADIR)/why3/modules/mach
cp -f drivers/*.drv drivers/*.gen $(DATADIR)/why3/drivers $(INSTALL_DATA) drivers/*.drv drivers/*.gen $(DATADIR)/why3/drivers
cp -f LICENSE $(DATADIR)/why3/ $(INSTALL_DATA) LICENSE $(DATADIR)/why3/
cp -f share/provers-detection-data.conf $(DATADIR)/why3/ $(INSTALL_DATA) share/provers-detection-data.conf $(DATADIR)/why3/
for i in share/images/*.rc; do \ for i in share/images/*.rc; do \
d=`basename $$i .rc`; \ d=`basename $$i .rc`; \
cp -f $$i $(DATADIR)/why3/images; \ $(INSTALL_DATA) $$i $(DATADIR)/why3/images; \
mkdir $(DATADIR)/why3/images/$$d; \ $(MKDIR_P) $(DATADIR)/why3/images/$$d; \
cp -f share/images/$$d/* $(DATADIR)/why3/images/$$d; \ $(INSTALL_DATA) share/images/$$d/* $(DATADIR)/why3/images/$$d; \
done done
cp -f share/images/*.png $(DATADIR)/why3/images $(INSTALL_DATA) share/images/*.png $(DATADIR)/why3/images
cp -f share/why3session.dtd $(DATADIR)/why3 $(INSTALL_DATA) share/why3session.dtd $(DATADIR)/why3
cp -f share/Makefile.config $(DATADIR)/why3 $(INSTALL_DATA) share/Makefile.config $(DATADIR)/why3
cp -f share/vim/why3.vim $(DATADIR)/why3/vim/why3.vim $(INSTALL_DATA) share/vim/why3.vim $(DATADIR)/why3/vim/why3.vim
cp -f share/lang/why3.lang $(DATADIR)/why3/lang/why3.lang $(INSTALL_DATA) share/lang/why3.lang $(DATADIR)/why3/lang/why3.lang
install_no_local_lib:: install_no_local_lib::
mkdir -p $(OCAMLINSTALLLIB)/why3 $(MKDIR_P) $(OCAMLINSTALLLIB)/why3
cp -f $(wildcard $(addprefix lib/why3/why3., $(INSTALLED_LIB_EXTS))) \ $(INSTALL_DATA) $(wildcard $(addprefix lib/why3/why3., $(INSTALLED_LIB_EXTS))) \
lib/why3/META $(OCAMLINSTALLLIB)/why3 lib/why3/META $(OCAMLINSTALLLIB)/why3
ifeq (@enable_local@,yes) ifeq (@enable_local@,yes)
...@@ -353,9 +356,9 @@ ifneq ($(EMACS),no) ...@@ -353,9 +356,9 @@ ifneq ($(EMACS),no)
endif endif
install_no_local:: install_no_local::
cp -f share/emacs/why3.el $(DATADIR)/emacs/site-lisp/why3.el $(INSTALL_DATA) share/emacs/why3.el $(DATADIR)/emacs/site-lisp/why3.el
ifneq ($(EMACS),no) ifneq ($(EMACS),no)
cp -f share/emacs/why3.elc $(DATADIR)/emacs/site-lisp/why3.elc $(INSTALL_DATA) share/emacs/why3.elc $(DATADIR)/emacs/site-lisp/why3.elc
endif endif
...@@ -456,8 +459,8 @@ CLEANDIRS += plugins $(addprefix plugins/, $(PLUGDIRS)) lib/plugins ...@@ -456,8 +459,8 @@ CLEANDIRS += plugins $(addprefix plugins/, $(PLUGDIRS)) lib/plugins
GENERATED += $(PLUGGENERATED) GENERATED += $(PLUGGENERATED)
mkdir -p $(LIBDIR)/why3/plugins $(MKDIR_P) $(LIBDIR)/why3/plugins
cp -f $(wildcard $(LIBPLUGCMO) $(LIBPLUGCMXS)) $(LIBDIR)/why3/plugins $(INSTALL_DATA) $(wildcard $(LIBPLUGCMO) $(LIBPLUGCMXS)) $(LIBDIR)/why3/plugins
# Why3 commands # Why3 commands
...@@ -506,14 +509,14 @@ clean_old_install:: ...@@ -506,14 +509,14 @@ clean_old_install::
rm -f $(BINDIR)/why3bench$(EXE) $(BINDIR)/why3replayer$(EXE) rm -f $(BINDIR)/why3bench$(EXE) $(BINDIR)/why3replayer$(EXE)
cp -f bin/why3.@OCAMLBEST@ $(BINDIR)/why3$(EXE) $(INSTALL) bin/why3.@OCAMLBEST@ $(BINDIR)/why3$(EXE)
cp -f bin/why3config.@OCAMLBEST@ $(TOOLDIR)/why3config$(EXE) $(INSTALL) bin/why3config.@OCAMLBEST@ $(TOOLDIR)/why3config$(EXE)
cp -f bin/why3execute.@OCAMLBEST@ $(TOOLDIR)/why3execute$(EXE) $(INSTALL) bin/why3execute.@OCAMLBEST@ $(TOOLDIR)/why3execute$(EXE)
cp -f bin/why3extract.@OCAMLBEST@ $(TOOLDIR)/why3extract$(EXE) $(INSTALL) bin/why3extract.@OCAMLBEST@ $(TOOLDIR)/why3extract$(EXE)
cp -f bin/why3prove.@OCAMLBEST@ $(TOOLDIR)/why3prove$(EXE) $(INSTALL) bin/why3prove.@OCAMLBEST@ $(TOOLDIR)/why3prove$(EXE)
cp -f bin/why3realize.@OCAMLBEST@ $(TOOLDIR)/why3realize$(EXE) $(INSTALL) bin/why3realize.@OCAMLBEST@ $(TOOLDIR)/why3realize$(EXE)
cp -f bin/why3replay.@OCAMLBEST@ $(TOOLDIR)/why3replay$(EXE) $(INSTALL) bin/why3replay.@OCAMLBEST@ $(TOOLDIR)/why3replay$(EXE)
cp -f bin/why3wc.@OCAMLBEST@ $(TOOLDIR)/why3wc$(EXE) $(INSTALL) bin/why3wc.@OCAMLBEST@ $(TOOLDIR)/why3wc$(EXE)
install_local:: bin/why3 $(addprefix bin/,$(TOOLS_BIN)) install_local:: bin/why3 $(addprefix bin/,$(TOOLS_BIN))
...@@ -685,7 +688,7 @@ clean_old_install:: ...@@ -685,7 +688,7 @@ clean_old_install::
rm -f $(BINDIR)/why3ide$(EXE) rm -f $(BINDIR)/why3ide$(EXE)
cp -f bin/why3ide.@OCAMLBEST@ $(TOOLDIR)/why3ide$(EXE) $(INSTALL) bin/why3ide.@OCAMLBEST@ $(TOOLDIR)/why3ide$(EXE)
install_local:: bin/why3ide install_local:: bin/why3ide
...@@ -736,7 +739,7 @@ clean_old_install:: ...@@ -736,7 +739,7 @@ clean_old_install::
rm -f $(BINDIR)/why3session$(EXE) rm -f $(BINDIR)/why3session$(EXE)
cp -f bin/why3session.@OCAMLBEST@ $(TOOLDIR)/why3session$(EXE) $(INSTALL) bin/why3session.@OCAMLBEST@ $(TOOLDIR)/why3session$(EXE)
install_local:: bin/why3session install_local:: bin/why3session
...@@ -810,8 +813,8 @@ clean:: ...@@ -810,8 +813,8 @@ clean::
rm -f src/coq-tactic/.why3-vo-* rm -f src/coq-tactic/.why3-vo-*
mkdir -p $(LIBDIR)/why3/coq-tactic $(MKDIR_P) $(LIBDIR)/why3/coq-tactic
cp -f lib/coq-tactic/* $(LIBDIR)/why3/coq-tactic $(INSTALL_DATA) lib/coq-tactic/* $(LIBDIR)/why3/coq-tactic
endif endif
...@@ -907,31 +910,31 @@ drivers/coq-realizations.aux: Makefile ...@@ -907,31 +910,31 @@ drivers/coq-realizations.aux: Makefile
mkdir -p $(LIBDIR)/why3/coq $(MKDIR_P) $(LIBDIR)/why3/coq
cp lib/coq/BuiltIn.vo lib/coq/HighOrd.vo $(LIBDIR)/why3/coq/ $(INSTALL_DATA) lib/coq/BuiltIn.vo lib/coq/HighOrd.vo $(LIBDIR)/why3/coq/
mkdir -p $(LIBDIR)/why3/coq/int $(MKDIR_P) $(LIBDIR)/why3/coq/int
cp $(addsuffix .vo, $(COQLIBS_INT)) $(LIBDIR)/why3/coq/int/ $(INSTALL_DATA) $(addsuffix .vo, $(COQLIBS_INT)) $(LIBDIR)/why3/coq/int/
mkdir -p $(LIBDIR)/why3/coq/bool $(MKDIR_P) $(LIBDIR)/why3/coq/bool
cp $(addsuffix .vo, $(COQLIBS_BOOL)) $(LIBDIR)/why3/coq/bool/ $(INSTALL_DATA) $(addsuffix .vo, $(COQLIBS_BOOL)) $(LIBDIR)/why3/coq/bool/
mkdir -p $(LIBDIR)/why3/coq/real $(MKDIR_P) $(LIBDIR)/why3/coq/real
cp $(addsuffix .vo, $(COQLIBS_REAL)) $(LIBDIR)/why3/coq/real/ $(INSTALL_DATA) $(addsuffix .vo, $(COQLIBS_REAL)) $(LIBDIR)/why3/coq/real/
mkdir -p $(LIBDIR)/why3/coq/number $(MKDIR_P) $(LIBDIR)/why3/coq/number
cp $(addsuffix .vo, $(COQLIBS_NUMBER)) $(LIBDIR)/why3/coq/number/ $(INSTALL_DATA) $(addsuffix .vo, $(COQLIBS_NUMBER)) $(LIBDIR)/why3/coq/number/
mkdir -p $(LIBDIR)/why3/coq/set $(MKDIR_P) $(LIBDIR)/why3/coq/set
cp $(addsuffix .vo, $(COQLIBS_SET)) $(LIBDIR)/why3/coq/set/ $(INSTALL_DATA) $(addsuffix .vo, $(COQLIBS_SET)) $(LIBDIR)/why3/coq/set/
mkdir -p $(LIBDIR)/why3/coq/map $(MKDIR_P) $(LIBDIR)/why3/coq/map
cp $(addsuffix .vo, $(COQLIBS_MAP)) $(LIBDIR)/why3/coq/map/ $(INSTALL_DATA) $(addsuffix .vo, $(COQLIBS_MAP)) $(LIBDIR)/why3/coq/map/
mkdir -p $(LIBDIR)/why3/coq/list $(MKDIR_P) $(LIBDIR)/why3/coq/list
cp $(addsuffix .vo, $(COQLIBS_LIST)) $(LIBDIR)/why3/coq/list/ $(INSTALL_DATA) $(addsuffix .vo, $(COQLIBS_LIST)) $(LIBDIR)/why3/coq/list/
mkdir -p $(LIBDIR)/why3/coq/option $(MKDIR_P) $(LIBDIR)/why3/coq/option
cp $(addsuffix .vo, $(COQLIBS_OPTION)) $(LIBDIR)/why3/coq/option/ $(INSTALL_DATA) $(addsuffix .vo, $(COQLIBS_OPTION)) $(LIBDIR)/why3/coq/option/
mkdir -p $(LIBDIR)/why3/coq/seq $(MKDIR_P) $(LIBDIR)/why3/coq/seq
cp $(addsuffix .vo, $(COQLIBS_SEQ)) $(LIBDIR)/why3/coq/seq/ $(INSTALL_DATA) $(addsuffix .vo, $(COQLIBS_SEQ)) $(LIBDIR)/why3/coq/seq/
mkdir -p $(LIBDIR)/why3/coq/bv $(MKDIR_P) $(LIBDIR)/why3/coq/bv
cp $(addsuffix .vo, $(COQLIBS_BV)) $(LIBDIR)/why3/coq/bv/ $(INSTALL_DATA) $(addsuffix .vo, $(COQLIBS_BV)) $(LIBDIR)/why3/coq/bv/
ifeq (@enable_coq_fp_libs@,yes) ifeq (@enable_coq_fp_libs@,yes)
mkdir -p $(LIBDIR)/why3/coq/floating_point $(MKDIR_P) $(LIBDIR)/why3/coq/floating_point
cp $(addsuffix .vo, $(COQLIBS_FP)) $(LIBDIR)/why3/coq/floating_point/ $(INSTALL_DATA) $(addsuffix .vo, $(COQLIBS_FP)) $(LIBDIR)/why3/coq/floating_point/
endif endif
update-coq: remove-coq-headers update-coq-int update-coq-bool update-coq-real update-coq-number update-coq-set update-coq-map update-coq-list update-coq-option update-coq-fp update-coq-seq update-coq-bv headers-coq update-coq: remove-coq-headers update-coq-int update-coq-bool update-coq-real update-coq-number update-coq-set update-coq-map update-coq-list update-coq-option update-coq-fp update-coq-seq update-coq-bv headers-coq
...@@ -1017,7 +1020,7 @@ drivers/coq-realizations.aux: Makefile ...@@ -1017,7 +1020,7 @@ drivers/coq-realizations.aux: Makefile
endif endif
cp drivers/coq-realizations.aux $(DATADIR)/why3/drivers/ $(INSTALL_DATA) drivers/coq-realizations.aux $(DATADIR)/why3/drivers/
opt byte: drivers/coq-realizations.aux opt byte: drivers/coq-realizations.aux
...@@ -1068,15 +1071,15 @@ drivers/pvs-realizations.aux: Makefile ...@@ -1068,15 +1071,15 @@ drivers/pvs-realizations.aux: Makefile
mkdir -p $(LIBDIR)/why3/pvs/int $(MKDIR_P) $(LIBDIR)/why3/pvs/int
cp $(addsuffix .pvs, $(PVSLIBS_INT)) $(LIBDIR)/why3/pvs/int/ $(INSTALL_DATA) $(addsuffix .pvs, $(PVSLIBS_INT)) $(LIBDIR)/why3/pvs/int/
cp $(addsuffix .prf, $(PVSLIBS_INT)) $(LIBDIR)/why3/pvs/int/ $(INSTALL_DATA) $(addsuffix .prf, $(PVSLIBS_INT)) $(LIBDIR)/why3/pvs/int/
mkdir -p $(LIBDIR)/why3/pvs/real $(MKDIR_P) $(LIBDIR)/why3/pvs/real
cp $(addsuffix .pvs, $(PVSLIBS_REAL)) $(LIBDIR)/why3/pvs/real/ $(INSTALL_DATA) $(addsuffix .pvs, $(PVSLIBS_REAL)) $(LIBDIR)/why3/pvs/real/
cp $(addsuffix .prf, $(PVSLIBS_REAL)) $(LIBDIR)/why3/pvs/real/ $(INSTALL_DATA) $(addsuffix .prf, $(PVSLIBS_REAL)) $(LIBDIR)/why3/pvs/real/
mkdir -p $(LIBDIR)/why3/pvs/floating_point/ $(MKDIR_P) $(LIBDIR)/why3/pvs/floating_point/
cp $(addsuffix .pvs, $(PVSLIBS_FP)) $(LIBDIR)/why3/pvs/floating_point/ $(INSTALL_DATA) $(addsuffix .pvs, $(PVSLIBS_FP)) $(LIBDIR)/why3/pvs/floating_point/
cp drivers/pvs-realizations.aux $(DATADIR)/why3/drivers/ $(INSTALL_DATA) drivers/pvs-realizations.aux $(DATADIR)/why3/drivers/
install_local:: drivers/pvs-realizations.aux install_local:: drivers/pvs-realizations.aux
...@@ -1094,7 +1097,7 @@ drivers/pvs-realizations.aux: Makefile ...@@ -1094,7 +1097,7 @@ drivers/pvs-realizations.aux: Makefile
$(HIDE)echo "(* generated automatically at compilation time *)" > $@ $(HIDE)echo "(* generated automatically at compilation time *)" > $@
endif endif
...@@ -1193,7 +1196,7 @@ endif ...@@ -1193,7 +1196,7 @@ endif
fi) fi)
cp drivers/isabelle-realizations.aux "$(DATADIR)/why3/drivers/" $(INSTALL_DATA) drivers/isabelle-realizations.aux $(DATADIR)/why3/drivers/
install_no_local:: lib/isabelle/last_build install_no_local:: lib/isabelle/last_build
...@@ -1259,7 +1262,7 @@ drivers/isabelle-realizations.aux: Makefile ...@@ -1259,7 +1262,7 @@ drivers/isabelle-realizations.aux: Makefile
cp drivers/isabelle-realizations.aux $(DATADIR)/why3/drivers/ $(INSTALL_DATA) drivers/isabelle-realizations.aux $(DATADIR)/why3/drivers/
endif endif
...@@ -1303,8 +1306,8 @@ lib/why3/why3extract.cmx: $(OCAMLLIBS_CMX) ...@@ -1303,8 +1306,8 @@ lib/why3/why3extract.cmx: $(OCAMLLIBS_CMX)
$(HIDE)$(OCAMLOPT) $(OFLAGS) -pack -o $@ $^ $(HIDE)$(OCAMLOPT) $(OFLAGS) -pack -o $@ $^
cp -f $(wildcard $(addprefix lib/why3/why3extract., $(INSTALLED_LIB_EXTS))) \ $(INSTALL_DATA) $(wildcard $(addprefix lib/why3/why3extract., $(INSTALLED_LIB_EXTS))) \
$(OCAMLINSTALLLIB)/why3 $(OCAMLINSTALLLIB)/why3
ifneq "$(MAKECMDGOALS:clean%=clean)" "clean" ifneq "$(MAKECMDGOALS:clean%=clean)" "clean"
...@@ -1334,8 +1337,8 @@ jessie.opt: src/jessie/Makefile lib/why3/why3.cmxa ...@@ -1334,8 +1337,8 @@ jessie.opt: src/jessie/Makefile lib/why3/why3.cmxa
@$(MAKE) -C src/jessie Jessie3.cmxs @$(MAKE) -C src/jessie Jessie3.cmxs
mkdir -p $(FRAMAC_LIBDIR)/plugins/ $(MKDIR_P) $(FRAMAC_LIBDIR)/plugins/
cp -f $(wildcard $(addprefix src/jessie/Jessie3., $(INSTALLED_LIB_EXTS))) \ $(INSTALL_DATA) $(wildcard $(addprefix src/jessie/Jessie3., $(INSTALLED_LIB_EXTS))) \
$(FRAMAC_LIBDIR)/plugins/ $(FRAMAC_LIBDIR)/plugins/
clean:: clean::
...@@ -1359,8 +1362,9 @@ clean:: ...@@ -1359,8 +1362,9 @@ clean::
rm -f lib/why3-cpulimit$(EXE) rm -f lib/why3-cpulimit$(EXE)
cp -f lib/why3-cpulimit$(EXE) $(LIBDIR)/why3/why3-cpulimit$(EXE) $(MKDIR_P) $(LIBDIR)/why3
cp -f lib/why3-call-pvs $(LIBDIR)/why3/why3-call-pvs $(INSTALL) lib/why3-cpulimit$(EXE) $(LIBDIR)/why3/why3-cpulimit$(EXE)
$(INSTALL) lib/why3-call-pvs $(LIBDIR)/why3/why3-call-pvs
# why3doc # why3doc
...@@ -1409,7 +1413,7 @@ clean_old_install:: ...@@ -1409,7 +1413,7 @@ clean_old_install::
rm -f $(BINDIR)/why3doc$(EXE) rm -f $(BINDIR)/why3doc$(EXE)
cp -f bin/why3doc.@OCAMLBEST@ $(TOOLDIR)/why3doc$(EXE) $(INSTALL) bin/why3doc.@OCAMLBEST@ $(TOOLDIR)/why3doc$(EXE)
install_local:: bin/why3doc install_local:: bin/why3doc
...@@ -1728,7 +1732,9 @@ clean_old_install:: ...@@ -1728,7 +1732,9 @@ clean_old_install::
if test -d /etc/bash_completion.d -a -w /etc/bash_completion.d; then rm -f /etc/bash_completion.d/why3; fi if test -d /etc/bash_completion.d -a -w /etc/bash_completion.d; then rm -f /etc/bash_completion.d/why3; fi
if test -d /etc/bash_completion.d -a -w /etc/bash_completion.d; then cp -f share/bash/why3 /etc/bash_completion.d; fi if test -d /etc/bash_completion.d -a -w /etc/bash_completion.d; then \
$(INSTALL_DATA) share/bash/why3 /etc/bash_completion.d; \
fi
...@@ -1905,7 +1911,7 @@ wc: ...@@ -1905,7 +1911,7 @@ wc:
NAME = why3-@VERSION@ NAME = why3-@VERSION@
# see .gitattributes for the list of files that are not distributed # see .gitattributes for the list of files that are not distributed
MORE_DIST = configure doc/manual.pdf MORE_DIST = configure install-sh doc/manual.pdf
dist: $(MORE_DIST) dist: $(MORE_DIST)
rm -rf distrib/$(NAME)/ distrib/$(NAME).tar.gz rm -rf distrib/$(NAME)/ distrib/$(NAME).tar.gz
...@@ -156,7 +156,9 @@ else ...@@ -156,7 +156,9 @@ else
fi fi
fi fi
AC_PROG_CC() AC_PROG_CC
AC_PROG_MKDIR_P
AC_PROG_INSTALL
# Check for Ocaml compilers # Check for Ocaml compilers
