Commit ace5595d authored by MARCHE Claude's avatar MARCHE Claude
merge
parent 3960903d
(* preliminaries *)
use array.Array as A
type array 'a = A.t int 'a
logic injective (n:int) (m:int) (a:array 'a) =
forall i j:int. n <= i <= m -> n <= j <= m ->
A.get a i = A.get a j -> i = j
type string
(* Capucine memory model *)
type pointer = int
type region 'a = A.t pointer 'a
type first_free_addr = int
logic valid (a:first_free_addr) (p:pointer) = p < a
logic valid_array (a:first_free_addr) (n:int) (m:int) (r:array pointer) =
forall i:int. n <= i <= m -> valid a (A.get r i)
parameter alloc : ref first_free_addr
parameter new_pointer : tt:unit ->
pointer
writes alloc
{ !alloc = old !alloc + 1 and result = old !alloc }
record Student =
mark: int
inv(this) { 0 <= this.mark <= 100 }
type student = (string, int)
logic invStudent (this:student) =
let (_,m) = this in 0 <= m <= 100
record Course =
group Rstud: Student;
students: array [Rstud]
count: int
sum: int
inv(this) {
count >= 0
injective(0, count-1, this.students)
this.sum = mark_sum(0,this.count-1,this.students)
type course = (region student, array pointer, int, int)
logic markSum (region student) int int (array pointer) : int
axiom MarkSumEmpty :
forall r:region student, i j:int, a : array pointer.
i > j -> markSum r i j a = 0
axiom MarkSumNonEmpty :
i <= j ->
let (_,mark) = A.get r (A.get a j) in
markSum r i j a = markSum r i (j-1) a + mark
lemma MarkSumFootprint:
forall n:int. forall s1: array(Student [R1]).
forall s2: array(Student [R2]).
(forall i:int. [0] <= [i] and [i] < [n] ==>
[!(select(s1,i) : Student[R1]).mark] =
[!(select(s2,i) : Student[R2]).mark])
==> [MarkSum(n, s1)] = [MarkSum(n,s2)]
lemma MarkSum_set_array_outside :
forall r:region student, i j k:int, a: array pointer, p:pointer.
not (i <= k <= j) ->
markSum r i j (A.set a k p) = markSum r i j a
lemma MarkSum_set_region_outside :
forall r:region student, i j:int, a: array pointer, p:pointer, s:student.
(forall k:int. i <= k <= j -> A.get a k <> p) ->
markSum (A.set r p s) i j a = markSum r i j a
logic invCourse (alloc:first_free_addr) (this:course) =
let (rStud,students,count,sum) = this in
count >= 0
valid_array alloc 0 (count - 1) students
injective 0 (count - 1) students
sum = markSum rStud 0 (count-1) students
fun CreateCourse(R:[Course]): [R]
consumes R^e
produces R^c
let c = new Course [R] in
c.count = 0;
c.sum = 0;
pack c;
c
let createCourse (r: (ref (region course))) : pointer =
let c = new_pointer () in
let (rStud,student,count,sum) = A.get !r c in
let newc = (rStud,student,0,0) in
r := A.set !r c newc;
assert { invCourse !alloc newc };
c
{ valid !alloc result }
fun RegisterStudent(R:[Course], c: [R], name: string): [R.Rstud]
consumes R^c
produces R^c
region S in
let s = new Student[S] in
s := (name, 0);
(adoptregion S as R.R_s);
assert [MarkSum(!(!c.students))] = [old(MarkSum(!(!c.students)))];
(focus !c.students) := add(!(!c.students), s);
c := (!c.students, !c.count + 1, !c.total, !c.4);
s
let registerStudent
(r: (ref (region course))) (c:pointer) (name:string) : pointer =
{ valid !alloc c and invCourse !alloc (A.get !r c) }
let s = new_pointer () in
let newstud = (name,0) in
let newc = (A.set rStud s newstud,A.set student count s,count+1,sum) in
s
fun SetMark(R:Course, c:[R], s: [c.Rstud], mark: int) : unit
consumes R^c
produces R^c
unpack c (* c.Rstud^G, R^o *)
let region Rs:Student
let s' = focus s as Rs (* Rs -o c.Rstud, Rs^c, R^o *)
unpack s' (* Rs -o c.Rstud, Rs^o, R^o *)
s'.mark <- mark;
pack s';
pack c
...@@ -206,6 +206,7 @@ let iconname_file = "file32" ...@@ -206,6 +206,7 @@ let iconname_file = "file32"
let iconname_prover = "wizard32" let iconname_prover = "wizard32"
let iconname_transf = "cutb32" let iconname_transf = "cutb32"
let iconname_editor = "edit32" let iconname_editor = "edit32"
let iconname_remove = "deletefile32"
let image_default = ref (image ~size:20 iconname_default) let image_default = ref (image ~size:20 iconname_default)
let image_scheduled = ref !image_default let image_scheduled = ref !image_default
...@@ -222,6 +223,7 @@ let image_file = ref !image_default ...@@ -222,6 +223,7 @@ let image_file = ref !image_default
let image_prover = ref !image_default let image_prover = ref !image_default
let image_transf = ref !image_default let image_transf = ref !image_default
let image_editor = ref !image_default let image_editor = ref !image_default
let image_remove = ref !image_default
let resize_images size = let resize_images size =
image_default := image ~size iconname_default; image_default := image ~size iconname_default;
...@@ -239,6 +241,7 @@ let resize_images size = ...@@ -239,6 +241,7 @@ let resize_images size =
image_prover := image ~size iconname_prover; image_prover := image ~size iconname_prover;
image_transf := image ~size iconname_transf; image_transf := image ~size iconname_transf;
image_editor := image ~size iconname_editor; image_editor := image ~size iconname_editor;
image_remove := image ~size iconname_remove;
let () = let () =
...@@ -66,6 +66,7 @@ val image_file : GdkPixbuf.pixbuf ref ...@@ -66,6 +66,7 @@ val image_file : GdkPixbuf.pixbuf ref
val image_prover : GdkPixbuf.pixbuf ref val image_prover : GdkPixbuf.pixbuf ref
val image_transf : GdkPixbuf.pixbuf ref val image_transf : GdkPixbuf.pixbuf ref
val image_editor : GdkPixbuf.pixbuf ref val image_editor : GdkPixbuf.pixbuf ref
val image_remove : GdkPixbuf.pixbuf ref
(* status icons *) (* status icons *)
val image_scheduled : GdkPixbuf.pixbuf ref val image_scheduled : GdkPixbuf.pixbuf ref
...@@ -503,18 +503,25 @@ let task_checksum t = ...@@ -503,18 +503,25 @@ let task_checksum t =
let info_window mt s = let info_window mt s =
let buttons = match mt with
| `INFO -> GWindow.Buttons.close
| `WARNING -> GWindow.Buttons.close
| `QUESTION -> GWindow.Buttons.ok_cancel
| `ERROR -> GWindow.Buttons.close
in
let d = GWindow.message_dialog let d = GWindow.message_dialog
~message:s ~message:s
~message_type:mt ~message_type:mt
~buttons:GWindow.Buttons.close ~buttons
~title:"Why3 info or error" ~title:"Why3 info or error"
~show:true () ~show:true ()
in in
let r = ref false in
let (_ : GtkSignal.id) = let (_ : GtkSignal.id) =
d#connect#response d#connect#response
~callback:(function `CLOSE | `DELETE_EVENT -> d#destroy ()) ~callback:(function x -> r := x = `OK; d#destroy ())
in in
() !r
module Helpers = struct module Helpers = struct
...@@ -1283,7 +1290,7 @@ let select_file () = ...@@ -1283,7 +1290,7 @@ let select_file () =
"@[Error while reading file@ '%s':@ %a@]" f "@[Error while reading file@ '%s':@ %a@]" f
Exn_printer.exn_printer e; Exn_printer.exn_printer e;
let msg = flush_str_formatter () in let msg = flush_str_formatter () in
info_window `ERROR msg let (_:bool) = info_window `ERROR msg in ()
end end
| `DELETE_EVENT | `CANCEL -> () | `DELETE_EVENT | `CANCEL -> ()
end ; end ;
...@@ -1291,7 +1298,7 @@ let select_file () = ...@@ -1291,7 +1298,7 @@ let select_file () =
let not_implemented () = let not_implemented () =
info_window `INFO "This feature is not yet implemented, sorry" let (_:bool) = info_window `INFO "This feature is not yet implemented, sorry" in ()
(* File menu *) (* File menu *)
...@@ -1482,8 +1489,10 @@ let () = ...@@ -1482,8 +1489,10 @@ let () =
in in
let b = GButton.button ~packing:provers_box#add ~label:n () in let b = GButton.button ~packing:provers_box#add ~label:n () in
let i = GMisc.image ~pixbuf:(!image_prover) ()in (* prend de la place pour rien
let i = GMisc.image ~pixbuf:(!image_prover) () in
let () = b#set_image i#coerce in let () = b#set_image i#coerce in
b#connect#pressed b#connect#pressed
~callback:(fun () -> prover_on_selected_goals p) ~callback:(fun () -> prover_on_selected_goals p)
...@@ -1788,7 +1797,9 @@ let edit_current_proof () = ...@@ -1788,7 +1797,9 @@ let edit_current_proof () =
| [r] -> edit_selected_row r | [r] -> edit_selected_row r
| _ -> | _ ->
let (_:bool) =
info_window `INFO "Please select exactly one proof to edit" info_window `INFO "Please select exactly one proof to edit"
in ()
let add_item_edit () = let add_item_edit () =
...@@ -1820,18 +1831,46 @@ let () = ...@@ -1820,18 +1831,46 @@ let () =
b#connect#pressed ~callback:not_implemented b#connect#pressed ~callback:not_implemented
in () in ()
(* cleaning *) (* removing *)
let confirm_remove_row r =
let row = filter_model#get_iter r in
match filter_model#get ~row ~column:Model.index_column with
| Model.Row_goal _g ->
let (_:bool) = info_window `ERROR "Cannot remove a goal" in ()
| Model.Row_theory _th ->
let (_:bool) = info_window `ERROR "Cannot remove a theory" in ()
| Model.Row_file _file ->
let (_:bool) = info_window `ERROR "Cannot remove a file" in ()
| Model.Row_proof_attempt _a ->
let (_:bool) = info_window `INFO "Proof attempt removal not implemented" in ()
| Model.Row_transformation _tr ->
let (_:bool) = info_window `INFO "Transformation removal not implemented" in ()
let b =
info_window `QUESTION
"Do you really want to remove the current selection?"
in
if b then remove_selection
let confirm_remove_selection () =
match goals_view#selection#get_selected_rows with
| [r] -> confirm_remove_row r
| _ ->
let (_:bool) =
info_window `INFO "Please select exactly one item to remove"
in ()
let () = let () =
let b = GButton.button ~packing:cleaning_box#add ~label:"Remove" () in let b = GButton.button ~packing:cleaning_box#add ~label:"Remove" () in
(* let i = GMisc.image ~pixbuf:(!image_remove) () in
let i = GMisc.image ~pixbuf:(!image_replay) () in
b#connect#pressed ~callback:not_implemented b#connect#pressed ~callback:confirm_remove_selection
in () in ()
