GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
ace20f3d
ace20f3d
Raphaël Rieu-Helft
Fix merge
20ed55b3
13 additions
11 deletions
+13
-11
src/mlw/cprinter.ml
src/mlw/cprinter.ml
+13
-11
src/mlw/cprinter.ml
ace20f3d
@@ -821,8 +821,7 @@ module Translate = struct
_
_
raise
raise
Unsupported
Unsupported
"Non-function with no syntax
"Non-function with no syntax in toplevel let"
in toplevel let"
Unsupported
s
Format
printf
"Unsupported : %s@."
s
Unsupported
s
Format
printf
s
@@ -831,8 +830,9 @@ module Translate = struct
Format
printf
"PDtype %s@."
id
id_string
Format
printf
"PDtype %s@."
id
id_string
begin
begin
match
its
its_ts
ts_def
match
its
its_ts
ts_def
Some
def
C
Dtypedef
ty_of_ty
info
def
id
Alias
def
C
Dtypedef
ty_of_ty
info
def
id
None
Range
_
Float
_
raise
Unsupported
"range types"
NoDef
begin
match
query_syntax
info
syntax
id
begin
match
query_syntax
info
syntax
id
Some
_
Some
_
None
None
@@ -940,13 +940,14 @@ module MLToC = struct
else
C
Snop
else
C
Snop
Eblock
_
assert
false
Eblock
_
assert
false
Eblock
l
Eblock
l
let
env_
not_tail
env
computes_return_value
false
in
let
env_
f
env
false
in
let
rec
aux
function
let
rec
aux
function
if
env
if
env
then
C
Sreturn
Enothing
then
C
Sreturn
Enothing
else
C
Snop
else
C
Snop
h
t
C
Sseq
C
Sblock
expr
info
env_not_tail
h
s
C
Sblock
expr
info
env
s
h
t
C
Sseq
C
Sblock
expr
info
env_f
h
C
Sblock
aux
t
C
Sblock
aux
t
in
in
aux
l
aux
l
@@ -954,10 +955,10 @@ module MLToC = struct
return_or_expr
env
C
Econst
Cint
"1"
return_or_expr
env
C
Econst
Cint
"1"
Eapp
rs
when
rs_equal
rs
rs_false
Eapp
rs
when
rs_equal
rs
rs_false
return_or_expr
env
C
Econst
Cint
"0"
return_or_expr
env
C
Econst
Cint
"0"
Evar
pv
Compile
ML
Evar
pv
let
e
C
Evar
pv_name
pv
in
let
e
C
Evar
pv_name
pv
in
return_or_expr
env
e
return_or_expr
env
e
Econst
ic
Compile
ML
Econst
ic
let
n
Number
compute_int
ic
in
let
n
Number
compute_int
ic
in
let
e
C
Econst
Cint
BigInt
to_string
n
in
let
e
C
Econst
Cint
BigInt
to_string
n
in
return_or_expr
env
e
return_or_expr
env
e
@@ -1067,7 +1068,7 @@ module MLToC = struct
Lvar
pv
le
(* not a block *)
Lvar
pv
le
(* not a block *)
begin
begin
match
le
e_node
match
le
e_node
Econst
ic
Compile
ML
Econst
ic
let
n
Number
compute_int
ic
in
let
n
Number
compute_int
ic
in
let
ce
C
Econst
Cint
BigInt
to_string
n
in
let
ce
C
Econst
Cint
BigInt
to_string
n
in
Format
printf
"propagate constant %s for var %s@."
Format
printf
@@ -1145,7 +1146,8 @@ module MLToC = struct
fun
bs
rs
xs
pvsl
r
fun
bs
rs
xs
pvsl
r
let
id
xs
xs_name
in
let
id
xs
xs_name
in
match
pvsl
r
e_node
match
pvsl
r
e_node
pv
Evar
pv'
when
pv_equal
pv
pv'
env
pv
Compile
ML
Evar
pv'
when
pv_equal
pv
pv'
env
bs
Sid
add
id
rs
bs
Sid
add
id
rs
Eblock
when
is_unit
r
e_ity
is_while
Eblock
when
is_unit
r
e_ity
is_while
Sid
add
id
bs
rs
Sid
add
id
bs
rs
@@ -1187,7 +1189,7 @@ module MLToC = struct
Ematch
_
raise
Unsupported
"pattern matching"
Ematch
_
raise
Unsupported
"pattern matching"
Eabsurd
assert
false
Eabsurd
assert
false
Eassign
_
raise
Unsupported
"assign"
Eassign
_
raise
Unsupported
"assign"
Ehole
assert
false
Ehole
Eignore
_
assert
false
Efun
_
raise
Unsupported
"higher order"
Efun
_
raise
Unsupported
"higher order"
let
translate_decl
info
info
d
decl
C
definition
option
let
translate_decl
info
info
d
decl
C
definition
option
