Commit acd30d83 authored by Andrei Paskevich's avatar Andrei Paskevich
create source directory for plugins and build them
parent 03d721f7
...@@ -91,7 +91,7 @@ EXTCMXA = $(addsuffix .cmxa,$(EXTLIBS)) $(addsuffix .cmx,$(EXTOBJS)) ...@@ -91,7 +91,7 @@ EXTCMXA = $(addsuffix .cmxa,$(EXTLIBS)) $(addsuffix .cmx,$(EXTOBJS))
# main target # main target
all: @OCAMLBEST@ all: @OCAMLBEST@ plugins
ifeq (@enable_local@,yes) ifeq (@enable_local@,yes)
all: install_local all: install_local
...@@ -133,7 +133,7 @@ LIB_TRANSFORM = simplify_recursive_definition simplify_formula \ ...@@ -133,7 +133,7 @@ LIB_TRANSFORM = simplify_recursive_definition simplify_formula \
introduction abstraction close_epsilon lift_epsilon \ introduction abstraction close_epsilon lift_epsilon \
eval_match instantiate_predicate smoke_detector eval_match instantiate_predicate smoke_detector
LIB_PRINTER = alt_ergo why3printer smtv1 smtv2 coq tptp simplify gappa \ LIB_PRINTER = alt_ergo why3printer smtv1 smtv2 coq simplify gappa \
cvc3 yices cvc3 yices
LIBMODULES = src/config \ LIBMODULES = src/config \
...@@ -208,7 +208,6 @@ clean:: ...@@ -208,7 +208,6 @@ clean::
install_no_local:: install_no_local::
mkdir -p $(BINDIR) mkdir -p $(BINDIR)
mkdir -p $(LIBDIR)/why3/plugins
mkdir -p $(LIBDIR)/why3/coq mkdir -p $(LIBDIR)/why3/coq
mkdir -p $(DATADIR)/why3/images mkdir -p $(DATADIR)/why3/images
mkdir -p $(DATADIR)/why3/emacs mkdir -p $(DATADIR)/why3/emacs
...@@ -242,6 +241,84 @@ endif ...@@ -242,6 +241,84 @@ endif
install-all: install install-lib install-all: install install-lib
# Why plugins
PLUGGENERATED =
PLUG_PARSER = genequlin
PLUG_PRINTER = tptp
PLUG_TRANSFORM =
PLUGINS = genequlin tptp
PLUGMODULES = $(addprefix plugins/parser/, $(PLUG_PARSER)) \
$(addprefix plugins/printer/, $(PLUG_PRINTER)) \
$(addprefix plugins/transform/, $(PLUG_TRANSFORM))
PLUGML = $(addsuffix .ml, $(PLUGMODULES))
PLUGMLI = $(addsuffix .mli, $(PLUGMODULES))
PLUGCMO = $(addsuffix .cmo, $(PLUGMODULES))
PLUGCMX = $(addsuffix .cmx, $(PLUGMODULES))
PLUGDIRS = parser printer transform
PLUGINCLUDES = $(addprefix -I plugins/, $(PLUGDIRS))
$(PLUGCMO) $(PLUGCMX): INCLUDES += $(PLUGINCLUDES)
plugins.byte: $(addsuffix .cmo, $(addprefix lib/plugins/, $(PLUGINS)))
plugins.opt : $(addsuffix .cmxs, $(addprefix lib/plugins/, $(PLUGINS)))
lib/plugins/%.cmxs: plugins/parser/%.cmx
$(if $(QUIET), @echo 'Linking $@' &&) \
$(OCAMLOPT) $(OFLAGS) -shared -o $@ $<
lib/plugins/%.cmo: plugins/parser/%.cmo
$(if $(QUIET),@echo 'Linking $@' &&) \
$(OCAMLC) $(BFLAGS) -pack -o $@ $<
lib/plugins/%.cmxs: plugins/printer/%.cmx
lib/plugins/%.cmo: plugins/printer/%.cmo
lib/plugins/%.cmxs: plugins/transform/%.cmx
lib/plugins/%.cmo: plugins/transform/%.cmo
include .depend.plugins
.depend.plugins: $(PLUGGENERATED)
$(OCAMLDEP) -slash -I src -I plugins $(PLUGINCLUDES) \
$(PLUGML) $(PLUGMLI) > $@
depend: .depend.plugins
PLUGSDIRS = plugins $(addprefix plugins/, $(PLUGDIRS))
PLUGCLEAN = $(addsuffix /*.cm[iox], $(PLUGSDIRS)) \
$(addsuffix /*.annot, $(PLUGSDIRS)) \
$(addsuffix /*.output, $(PLUGSDIRS)) \
$(addsuffix /*.automaton, $(PLUGSDIRS)) \
$(addsuffix /*.o, $(PLUGSDIRS)) \
$(addsuffix /*~, $(PLUGSDIRS))
clean::
rm -f $(PLUGCLEAN) $(PLUGGENERATED)
rm -f lib/plugins/*
rm -f .depend.plugins
install_no_local::
cp -f lib/plugins/* $(LIBDIR)/why3/plugins
# Why binary # Why binary
...@@ -443,7 +520,6 @@ clean:: ...@@ -443,7 +520,6 @@ clean::
rm -f src/config/*.annot src/config/*~ rm -f src/config/*.annot src/config/*~
rm -f src/config/*.output src/config/*.automaton rm -f src/config/*.output src/config/*.automaton
rm -f bin/why3config.byte bin/why3config.opt bin/why3config rm -f bin/why3config.byte bin/why3config.opt bin/why3config
rm -f .why.conf
rm -f .depend.config rm -f .depend.config
local_config: bin/why3config.@OCAMLBEST@ local_config: bin/why3config.@OCAMLBEST@
...@@ -922,7 +998,7 @@ install_local: bin/why3doc ...@@ -922,7 +998,7 @@ install_local: bin/why3doc
# bench # bench
.PHONY: bench test comp_bench_plugins .PHONY: bench test
bench:: bin/why3.@OCAMLBEST@ bin/why3ml.@OCAMLBEST@ bin/why3config.@OCAMLBEST@ plugins $(TOOLS) bench:: bin/why3.@OCAMLBEST@ bin/why3ml.@OCAMLBEST@ bin/why3config.@OCAMLBEST@ plugins $(TOOLS)
$(MAKE) test-api $(MAKE) test-api
...@@ -930,18 +1006,6 @@ bench:: bin/why3.@OCAMLBEST@ bin/why3ml.@OCAMLBEST@ bin/why3config.@OCAMLBEST@ p ...@@ -930,18 +1006,6 @@ bench:: bin/why3.@OCAMLBEST@ bin/why3ml.@OCAMLBEST@ bin/why3config.@OCAMLBEST@ p
"bin/why3.@OCAMLBEST@" \ "bin/why3.@OCAMLBEST@" \
"bin/why3ml.@OCAMLBEST@" "bin/why3ml.@OCAMLBEST@"
BENCH_PLUGINS_CMO := helloworld.cmo
BENCH_PLUGINS_CMO := $(addprefix bench/plugins/,$(BENCH_PLUGINS_CMO))
BENCH_PLUGINS_CMXS := $(BENCH_PLUGINS_CMO:.cmo=.cmxs)
comp_bench_plugins:: $(BENCH_PLUGINS_CMO) $(BENCH_PLUGINS_CMXS)
# bench_plugins:: $(BENCH_PLUGINS_CMO) $(BENCH_PLUGINS_CMXS) byte $(TOOLS)
# bin/why3.byte -D bench/plugins/helloworld.drv \
# tests/test-jcf.why -T Test -G G
# bin/why3.$(OCAMLBEST) -D bench/plugins/helloworld.drv \
# test targets # test targets
...@@ -992,47 +1056,6 @@ bts12244: src/why3.cma ...@@ -992,47 +1056,6 @@ bts12244: src/why3.cma
ocaml -I src/ $(INCLUDES) $(EXTCMA) src/why3.cma examples/bts12244.ml ocaml -I src/ $(INCLUDES) $(EXTCMA) src/why3.cma examples/bts12244.ml
## Examples : Plugins ##
PLUGDIR = examples/plugins/
PLUG_FILES = genequlin
PLUGMODULES = $(addprefix $(PLUGDIR), $(PLUG_FILES))
PLUGCMXS = $(addsuffix .cmxs, $(PLUGMODULES))
# ifeq (@enable_plug_support@,yes)
# byte: src/plug-plugin/whytac.cma
# opt: src/plug-plugin/whytac.cmxs
# endif
# $(PLUGCMO): src/why3.cma
# $(PLUGCMXS): src/why3.cmxa
.PHONY: examples_plugins.byte examples_plugins.opt
examples_plugins.byte : $(PLUGCMO)
examples_plugins.opt : $(PLUGCMXS)
# depend and clean targets
.depend.plug: $(PLUGGENERATED)
$(OCAMLDEP) -slash -I src -I $(PLUGDIR) $(PLUGML) | sed "s/cmx/cmxs/" > $@
clean::
rm -f $(PLUGDIR)/*.cm[iox] $(PLUGDIR)/*.o
rm -f $(PLUGDIR)/*.cma $(PLUGDIR)/*.cmxs
rm -f $(PLUGDIR)/*.annot $(PLUGDIR)/*~
rm -f $(PLUGGENERATED)
rm -f .depend.plug
# documentation # documentation
...@@ -68,7 +68,7 @@ let scanf s = ...@@ -68,7 +68,7 @@ let scanf s =
(** the main function *) (** the main function *)
let read_channel env filename cin = let read_channel env path filename cin =
(** Find the int theory and the needed operation *) (** Find the int theory and the needed operation *)
let th_int = Env.find_theory env ["int"] "Int" in let th_int = Env.find_theory env ["int"] "Int" in
let leq = ns_find_ls th_int.th_export ["infix <"] in let leq = ns_find_ls th_int.th_export ["infix <"] in
...@@ -76,17 +76,17 @@ let read_channel env filename cin = ...@@ -76,17 +76,17 @@ let read_channel env filename cin =
let mult_symbol = Theory.ns_find_ls th_int.Theory.th_export ["infix *"] in let mult_symbol = Theory.ns_find_ls th_int.Theory.th_export ["infix *"] in
let zero = t_const (ConstInt "0") in let zero = t_int_const "0" in
(** create a contraint : polynome <= constant *) (** create a contraint : polynome <= constant *)
let create_lit lvar k lits _ = let create_lit lvar k lits _ =
let left = List.fold_left (fun acc e -> let left = List.fold_left (fun acc e ->
let const = string_of_int ((Random.int k) - (k/2)) in let const = string_of_int ((Random.int k) - (k/2)) in
let monome = t_app mult_symbol [e;t_const(ConstInt const)] let monome = t_app mult_symbol [e;t_int_const const]
(Some Ty.ty_int) in (Some Ty.ty_int) in
t_app plus_symbol [acc;monome] (Some Ty.ty_int)) zero lvar in t_app plus_symbol [acc;monome] (Some Ty.ty_int)) zero lvar in
let rconst = string_of_int ((Random.int k) - (k/2)) in let rconst = string_of_int ((Random.int k) - (k/2)) in
t_and_simp lits (t_app leq [left;t_const(ConstInt rconst)] None) in t_and_simp lits (t_app leq [left;t_int_const rconst] None) in
(** create a set of constraints *) (** create a set of constraints *)
let create_fmla nvar m k = let create_fmla nvar m k =
...@@ -107,7 +107,7 @@ let read_channel env filename cin = ...@@ -107,7 +107,7 @@ let read_channel env filename cin =
end; end;
(** Create the theory *) (** Create the theory *)
let th_uc_loc = Loc.user_position filename 1 0 0 in let th_uc_loc = Loc.user_position filename 1 0 0 in
let th_uc = create_theory (id_user "EqLin" th_uc_loc) in let th_uc = create_theory ~path (id_user "EqLin" th_uc_loc) in
let th_uc = Theory.use_export th_uc th_int in let th_uc = Theory.use_export th_uc th_int in
(** Read one line and add it to the theory *) (** Read one line and add it to the theory *)
let fold th_uc s = let fold th_uc s =
...@@ -130,6 +130,4 @@ let read_channel env filename cin = ...@@ -130,6 +130,4 @@ let read_channel env filename cin =
(** Return the map with the theory *) (** Return the map with the theory *)
Mstr.singleton "EqLin" (close_theory th_uc) Mstr.singleton "EqLin" (close_theory th_uc)
let () = Env.register_format "EquLin" ["equlin"] read_channel let () = Env.register_format "EquLin" ["equlin"] read_channel
...@@ -18,6 +18,8 @@ ...@@ -18,6 +18,8 @@
open Format open Format
open Why3
open Pp open Pp
open Ident open Ident
open Ty open Ty
