no default loadpath if config file exists
parent e24f33af
...@@ -184,7 +184,7 @@ let load_main dirname section = ...@@ -184,7 +184,7 @@ let load_main dirname section =
{ libdir = get_string ~default:default_main.libdir section "libdir"; { libdir = get_string ~default:default_main.libdir section "libdir";
datadir = get_string ~default:default_main.datadir section "datadir"; datadir = get_string ~default:default_main.datadir section "datadir";
loadpath = List.map (absolute_filename dirname) loadpath = List.map (absolute_filename dirname)
(get_stringl ~default:default_main.loadpath section "loadpath"); (get_stringl ~default:[] section "loadpath");
timelimit = get_int ~default:default_main.timelimit section "timelimit"; timelimit = get_int ~default:default_main.timelimit section "timelimit";
memlimit = get_int ~default:default_main.memlimit section "memlimit"; memlimit = get_int ~default:default_main.memlimit section "memlimit";
running_provers_max = get_int ~default:default_main.running_provers_max running_provers_max = get_int ~default:default_main.running_provers_max
