Commit a97ec002 authored by Francois Bobot's avatar Francois Bobot
correct the make -j :
Multi-target is required for ocamlyacc but is counterproductive for ocamlc.
This is due to ocamldep which declare .cmi as dependencies only when
a .mli file exists.
That work one day because %.cmi was wrongly spelled %cmi, after the
spelling correction that doesn't work anymore. Until now :)
The last commit is also an improvement for -j
parent 3e5341b3
...@@ -804,7 +804,7 @@ clean:: ...@@ -804,7 +804,7 @@ clean::
%.cmi: %.mli %.cmi: %.mli
$(if $(QUIET),@echo 'Ocamlc $<' &&) $(OCAMLC) -c $(BFLAGS) $< $(if $(QUIET),@echo 'Ocamlc $<' &&) $(OCAMLC) -c $(BFLAGS) $<
%.cmo %.cmi: %.ml %.cmo: %.ml
%.cmx: %.ml %.cmx: %.ml
Supports Markdown
