Commit a892b84a authored by MARCHE Claude's avatar MARCHE Claude
ITP: simple attempt to implement 'interrupt'. IMPORTANT ISSUE: running processes are not killed
parent cce76ebe
...@@ -686,7 +686,7 @@ let image_of_pa_status ~obsolete pa = ...@@ -686,7 +686,7 @@ let image_of_pa_status ~obsolete pa =
match pa with match pa with
| Controller_itp.Unedited -> !image_scheduled (* TODO !image_unedited *) | Controller_itp.Unedited -> !image_scheduled (* TODO !image_unedited *)
| Controller_itp.JustEdited -> !image_scheduled (* TODO !image_edited *) | Controller_itp.JustEdited -> !image_scheduled (* TODO !image_edited *)
| Controller_itp.Interrupted -> !image_scheduled (* TODO !image_interrrupted *) | Controller_itp.Interrupted -> !image_undone
| Controller_itp.Scheduled -> !image_scheduled | Controller_itp.Scheduled -> !image_scheduled
| Controller_itp.Running -> !image_running | Controller_itp.Running -> !image_running
| Controller_itp.InternalFailure _e -> !image_failure | Controller_itp.InternalFailure _e -> !image_failure
...@@ -506,6 +506,20 @@ let timeout_handler () = ...@@ -506,6 +506,20 @@ let timeout_handler () =
!observer scheduled (waiting_or_running - running) running; !observer scheduled (waiting_or_running - running) running;
true true
let interrupt () =
while not (Queue.is_empty prover_tasks_in_progress) do
let (_ses,_id,_pr,callback,_started,_call) =
Queue.pop prover_tasks_in_progress in
(* TODO: apply some Call_provers.interrupt_call call *)
callback Interrupted
done;
number_of_running_provers := 0;
while not (Queue.is_empty scheduled_proof_attempts) do
let (_c,_id,_pr,_limit,callback) = Queue.pop scheduled_proof_attempts in
done;
!observer 0 0 0
let run_timeout_handler () = let run_timeout_handler () =
if not !timeout_handler_running then if not !timeout_handler_running then
begin begin
...@@ -593,7 +607,8 @@ let run_strategy_on_goal ...@@ -593,7 +607,8 @@ let run_strategy_on_goal
| Done { Call_provers.pr_answer = Call_provers.Valid } -> | Done { Call_provers.pr_answer = Call_provers.Valid } ->
(* proof succeeded, nothing more to do *) (* proof succeeded, nothing more to do *)
callback STShalt callback STShalt
| Interrupted | InternalFailure _ | Interrupted | InternalFailure _ ->
callback STShalt
| Done _ -> | Done _ ->
(* proof did not succeed, goto to next step *) (* proof did not succeed, goto to next step *)
callback (STSgoto (g,pc+1)); callback (STSgoto (g,pc+1));
...@@ -159,6 +159,10 @@ val register_observer : (int -> int -> int -> unit) -> unit ...@@ -159,6 +159,10 @@ val register_observer : (int -> int -> int -> unit) -> unit
tasks, scheduled tasks, and running taks, each time these numbers tasks, scheduled tasks, and running taks, each time these numbers
change *) change *)
val interrupt : unit -> unit
(** discards all scheduled proof attempts or transformations, including
the one already running *)
val schedule_proof_attempt : val schedule_proof_attempt :
controller -> controller ->
proofNodeID -> proofNodeID ->
...@@ -96,3 +96,4 @@ type ide_request = ...@@ -96,3 +96,4 @@ type ide_request =
| Reload_req | Reload_req
| Replay_req | Replay_req
| Exit_req | Exit_req
| Interrupt_req
...@@ -103,3 +103,4 @@ type ide_request = ...@@ -103,3 +103,4 @@ type ide_request =
| Exit_req | Exit_req
| Interrupt_req
...@@ -294,6 +294,7 @@ let print_request fmt r = ...@@ -294,6 +294,7 @@ let print_request fmt r =
| Reload_req -> fprintf fmt "reload" | Reload_req -> fprintf fmt "reload"
| Replay_req -> fprintf fmt "replay" | Replay_req -> fprintf fmt "replay"
| Exit_req -> fprintf fmt "exit" | Exit_req -> fprintf fmt "exit"
| Interrupt_req -> fprintf fmt "interrupt"
let print_msg fmt m = let print_msg fmt m =
match m with match m with
...@@ -1020,6 +1021,7 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct ...@@ -1020,6 +1021,7 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct
save_file name text; save_file name text;
| Get_task nid -> send_task nid | Get_task nid -> send_task nid
| Replay_req -> replay_session (); resend_the_tree () | Replay_req -> replay_session (); resend_the_tree ()
| Interrupt_req -> C.interrupt ()
| Command_req (nid, cmd) -> | Command_req (nid, cmd) ->
begin begin
let snid = get_proof_node_id nid in let snid = get_proof_node_id nid in
...@@ -1028,6 +1030,7 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct ...@@ -1028,6 +1030,7 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct
| Query s -> P.notify (Message (Query_Info (nid, s))) | Query s -> P.notify (Message (Query_Info (nid, s)))
| Prove (p, limit) -> schedule_proof_attempt nid p limit | Prove (p, limit) -> schedule_proof_attempt nid p limit
| Strategies st -> run_strategy_on_task nid st | Strategies st -> run_strategy_on_task nid st
| Interrupt -> C.interrupt ()
| Help_message s -> P.notify (Message (Help s)) | Help_message s -> P.notify (Message (Help s))
| QError s -> P.notify (Message (Query_Error (nid, s))) | QError s -> P.notify (Message (Query_Error (nid, s)))
| Other (s, _args) -> | Other (s, _args) ->
...@@ -129,6 +129,7 @@ let convert_request_constructor (r: ide_request) = ...@@ -129,6 +129,7 @@ let convert_request_constructor (r: ide_request) =
| Reload_req -> String "Reload_req" | Reload_req -> String "Reload_req"
| Replay_req -> String "Replay_req" | Replay_req -> String "Replay_req"
| Exit_req -> String "Exit_req" | Exit_req -> String "Exit_req"
| Interrupt_req -> String "Interrupt_req"
let print_request_to_json (r: ide_request): Json_base.value = let print_request_to_json (r: ide_request): Json_base.value =
let cc = convert_request_constructor in let cc = convert_request_constructor in
...@@ -192,6 +193,8 @@ let print_request_to_json (r: ide_request): Json_base.value = ...@@ -192,6 +193,8 @@ let print_request_to_json (r: ide_request): Json_base.value =
Obj ["ide_request", cc r] Obj ["ide_request", cc r]
| Exit_req -> | Exit_req ->
| Interrupt_req ->
let convert_constructor_message (m: message_notification) = let convert_constructor_message (m: message_notification) =
...@@ -232,6 +232,7 @@ type command = ...@@ -232,6 +232,7 @@ type command =
| Transform of string * Trans.gentrans * string list | Transform of string * Trans.gentrans * string list
| Prove of Whyconf.config_prover * Call_provers.resource_limit | Prove of Whyconf.config_prover * Call_provers.resource_limit
| Strategies of string | Strategies of string
| Interrupt
| Help_message of string | Help_message of string
| Query of string | Query of string
| QError of string | QError of string
...@@ -250,6 +251,7 @@ let interp_others commands config cmd args = ...@@ -250,6 +251,7 @@ let interp_others commands config cmd args =
| _ -> "1" | _ -> "1"
in in
Strategies s Strategies s
| "interrupt" -> Interrupt
| "help" -> | "help" ->
let text = Pp.sprintf let text = Pp.sprintf
"Please type a command among the following (automatic completion available)@\n\ "Please type a command among the following (automatic completion available)@\n\
...@@ -43,6 +43,7 @@ type command = ...@@ -43,6 +43,7 @@ type command =
| Interrupt
