Commit a82e8491 authored by Raphaël Rieu-Helft's avatar Raphaël Rieu-Helft
Start translation from Why3 AST to C AST
parent 69ac0842
...@@ -34,12 +34,12 @@ module C = struct ...@@ -34,12 +34,12 @@ module C = struct
| Ecast of ty * expr | Ecast of ty * expr
| Ecall of expr * expr list | Ecall of expr * expr list
| Econst of constant | Econst of constant
| Evar of string | Evar of ident
| Esize_expr of expr | Esize_expr of expr
| Esize_type of ty | Esize_type of ty
| Eindex of expr * expr (* Array access *) | Eindex of expr * expr (* Array access *)
| Edot of expr * string (* Field access with dot *) | Edot of expr * ident (* Field access with dot *)
| Earrow of expr * string (* Pointer access with arrow *) | Earrow of expr * ident (* Pointer access with arrow *)
and constant = and constant =
| Cint of string | Cint of string
...@@ -60,7 +60,7 @@ module C = struct ...@@ -60,7 +60,7 @@ module C = struct
| Sreturn of expr | Sreturn of expr
and definition = and definition =
| Dfun of name * body | Dfun of ident * proto * body
| Ddecl of names | Ddecl of names
| Dtypedef of ty * ident | Dtypedef of ty * ident
| Dstructural of names (* struct, union... *) | Dstructural of names (* struct, union... *)
...@@ -69,6 +69,153 @@ module C = struct ...@@ -69,6 +69,153 @@ module C = struct
type file = definition list type file = definition list
exception NotAValue
(* [assignify id] transforms a statement that computes a value into
a statement that assigns that value to id *)
let rec assignify id = function
| Snop -> raise NotAValue
| Sexpr e -> Sexpr (Ebinop (Bassign, Evar id, e))
| Sblock (ds, s) -> Sblock (ds, assignify id s)
| Sseq (s1, s2) -> Sseq (s1, assignify id s2)
| Sif (c,t,e) -> Sif (c, assignify id t, assignify id e)
| Swhile (c,s) -> Swhile (c, assignify id s) (* can this be a value ?*)
| Sfor (e0,e1,e2,s) -> Sfor (e0,e1,e2, assignify id s)
| Sbreak -> raise NotAValue
| Sreturn _ -> raise NotAValue
type info = Pdriver.printer_args = private {
env : Env.env;
prelude : Printer.prelude;
thprelude : Printer.prelude_map;
blacklist : Printer.blacklist;
syntax : Printer.syntax_map;
converter : Printer.syntax_map;
module Translate = struct
open Pdecl
open Ity
open Ty
open Expr
open Term
open Printer
exception Unsupported of string
let ty_of_ty info ty =
match ty.ty_node with
| Tyvar v ->
begin match query_syntax info.syntax v.tv_name
| Some s -> C.Tsyntax s
| None -> C.Tnamed (v.tv_name)
| Tyapp (ts, _tl) ->
begin match query_syntax info.syntax ts.ts_name
| Some s -> C.Tsyntax s (*TODO something with the %[tv][1-9] logic ?*)
| None -> assert false
let ty_of_ts info ts =
let ty_of_ity info ity =
match ity.ity_node with
| Ityvar (tv,_) ->
begin match query_syntax info.syntax tv.tv_name with
| None -> C.Tnamed (tv.tv_name)
| Ityapp (its,_,_) ->
ty_of_ts info its.its_ts
| Ityreg _ -> assert false
let pv_name pv = pv.pv_vs.vs_name
let rec expr info (e:expr) : C.body =
match e.e_node with
| Evar pv -> C.([], Sexpr(Evar (pv_name pv)))
| Econst c -> assert false (*TODO*)
| Eexec (ce, cty) ->
begin match ce.c_node with
| Cfun e -> expr info e
| Capp (rs, pvsl) ->
let args = List.filter (fun pv -> not pv.pv_ghost) pvsl in
C.([],
Sexpr(Ecall(Evar(rs.rs_name),
List.map (fun pv -> Evar(pv_name pv)) args)))
| _ -> assert false
| Eassign _ -> assert false
| Elet (ld,e) ->
begin match ld with
| LDvar (pv,le) ->
if pv.pv_ghost then expr info e
else
let t = ty_of_ity info pv.pv_ity in
let initblock = expr info le in
[ C.Ddecl (t, [pv_name pv, C.Enothing]) ],
C.Sseq (C.Sblock initblock, C.Sblock (expr info e))
| _ -> assert false
| Eif (c, t, e) ->
let t = expr info t in
let e = expr info e in
begin match expr info c with
| [], C.Sexpr c -> [], C.Sif(c,C.Sblock t, C.Sblock e)
| cblock ->
let cid = id_register (id_fresh "cond") in (* ? *)
[ C.Ddecl (C.Tsyntax "int", [cid, C.Enothing]) ],
C.Sseq (C.Sblock cblock, C.Sif (C.Evar cid, C.Sblock t, C.Sblock e))
| Ewhile (c,_,_,e) ->
let cd, cs = expr info c in
let b = expr info e in
begin match cs with
| C.Sexpr ce -> cd, C.Swhile (ce, C.Sblock b)
| _ ->
[C.Ddecl (C.Tsyntax "int", [cid, C.Enothing])],
C.Sseq (C.Sblock (cd, cs), C.Swhile (C.Evar cid, C.Sblock b))
| Etry _ | Eraise _ -> assert false (*TODO*)
| Efor _ -> assert false (*TODO*)
| Eassert _ -> [], C.Snop
| Eghost _ | Epure _ | Ecase _ | Eabsurd -> assert false
let pdecl info (pd:Pdecl.pdecl) : C.definition list =
match pd.pd_node with
| PDlet (LDsym (rs, ce)) ->
| Cfun e ->
let fname = rs.rs_name in
let rtype = match rs.rs_cty.cty_result.ity_node with
| Ityapp (its, _,_) ->
| _ -> assert false
in
let params = List.map
(fun pv -> ty_of_ty info pv.pv_vs.vs_ty, pv_name pv)
(List.filter (fun pv -> not pv.pv_ghost) rs.rs_cty.cty_args) in
[C.Dfun (fname, (rtype,params), expr info e)]
| _ -> assert false
| PDtype [{itd_its = ity}] ->
let id = ity.its_ts.ts_name in
[C.Dtypedef (ty_of_ts info ity.its_ts, id)]
| _ -> assert false
let translate (info:info) (m:Pmodule.pmodule) : C.file =
assert false
end end
let fg ?fname m = let fg ?fname m =
