two more programs for the nightly bench
parent 438e76ea
...@@ -169,7 +169,6 @@ why.conf ...@@ -169,7 +169,6 @@ why.conf
/examples/programs/dijkstra/ /examples/programs/dijkstra/
/examples/programs/distance/ /examples/programs/distance/
/examples/programs/sf/ /examples/programs/sf/
/examples/programs/vstte10_queens/
# modules # modules
/modules/string/ /modules/string/
...@@ -97,7 +97,7 @@ module M ...@@ -97,7 +97,7 @@ module M
solution board n } solution board n }
let queens (board: array int) n = let queens (board: array int) n =
{ length board = n } { 0 <= length board = n }
bt_queens board n 0 bt_queens board n 0
{ forall b:array int. length b = n -> is_board b n -> not (solution b n) } { forall b:array int. length b = n -> is_board b n -> not (solution b n) }
| Solution -> { solution board n } | Solution -> { solution board n }
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE why3session SYSTEM "why3session.dtd">
<why3session name="examples/programs/vstte10_queens/why3session.xml">
<file name="../vstte10_queens.mlw" verified="true" expanded="true">
<theory name="M" verified="true" expanded="true">
<goal name="eq_board_set" sum="5a0d75d0eac71d57f1acabc952568bfa" proved="true" expanded="true">
<proof prover="alt-ergo" timelimit="25" edited="" obsolete="false">
<result status="valid" time="0.02"/>
</proof>
</goal>
<goal name="eq_board_sym" sum="405f7d6fa7f1cd214d57be56a03a90c6" proved="true" expanded="true">
<result status="valid" time="0.03"/>
</proof>
</goal>
<goal name="eq_board_trans" sum="4f4b4df9a06df487228e3b7a5e299786" proved="true" expanded="true">
</proof>
</goal>
<goal name="eq_board_extension" sum="b146f07adfca2961090acaf226f1472b" proved="true" expanded="true">
</proof>
</goal>
<goal name="consistent_row_eq" sum="5cdbdd0e4d2d069953d7d298438e53eb" proved="true" expanded="true">
<result status="valid" time="0.05"/>
</proof>
</goal>
<goal name="is_consistent_eq" sum="0cdac2dc0783cb8971d9b2bc165b1dbb" proved="true" expanded="true">
<result status="valid" time="0.15"/>
</proof>
</goal>
<goal name="WP_parameter check_is_consistent" expl="correctness of parameter check_is_consistent" sum="650b8d34506ab14116907ee9a6c5293a" proved="true" expanded="true">
<transf name="split_goal" proved="true" expanded="true">
<goal name="WP_parameter check_is_consistent.1" expl="normal postcondition" sum="4cc7de5ca077c383b2e8c319e5fe2772" proved="true" expanded="true">
<proof prover="alt-ergo" timelimit="10" edited="" obsolete="false">
</proof>
</goal>
<goal name="WP_parameter check_is_consistent.2" expl="for loop initialization" sum="80722d6f340ea1606df6b1de6a061b02" proved="true" expanded="true">
</proof>
</goal>
<goal name="WP_parameter check_is_consistent.3" expl="for loop preservation" sum="1e68880955d1ba458aaac7db11bfadf1" proved="true" expanded="true">
<result status="valid" time="0.10"/>
</proof>
</goal>
<goal name="WP_parameter check_is_consistent.4" expl="normal postcondition" sum="19580c6a17a5572d4a5e3517d7284f33" proved="true" expanded="true">
</proof>
</goal>
</transf>
</goal>
<goal name="solution_eq_board" sum="d370041b6257114a528593f9179b707e" proved="true" expanded="true">
<goal name="solution_eq_board.1" sum="d370041b6257114a528593f9179b707e" proved="true" expanded="true">
<proof prover="z3" timelimit="10" edited="" obsolete="false">
<result status="valid" time="0.06"/>
</proof>
</goal>
</transf>
</goal>
<goal name="WP_parameter bt_queens" expl="correctness of parameter bt_queens" sum="efdafb18184a557c0bd125c5402c13b4" proved="true" expanded="true">
<goal name="WP_parameter bt_queens.1" expl="exceptional postcondition" sum="2a6ac1e487ce8b58509cbc4b3ca2a6ad" proved="true" expanded="true">
</proof>
</goal>
<goal name="WP_parameter bt_queens.2" expl="normal postcondition" sum="d310f725c1974ea14c328be34508ffdc" proved="true" expanded="true">
</proof>
</goal>
<goal name="WP_parameter bt_queens.3" expl="for loop initialization" sum="dd318c0d700fee0e567d4f117338842f" proved="true" expanded="true">
</proof>
</goal>
<goal name="WP_parameter bt_queens.4" expl="for loop preservation" sum="78dd8b8c60afd7e97ffcd6f038cdda81" proved="true" expanded="true">
<proof prover="cvc3" timelimit="10" edited="" obsolete="false">
<result status="valid" time="1.08"/>
</proof>
</goal>
<goal name="WP_parameter bt_queens.5" expl="normal postcondition" sum="4394063341332481cf8bfa9f973e760d" proved="true" expanded="true">
<result status="valid" time="0.12"/>
</proof>
</goal>
</transf>
</goal>
<goal name="WP_parameter queens" expl="correctness of parameter queens" sum="1518431140950e60159267f1ed47140d" proved="true" expanded="true">
<goal name="WP_parameter queens.1" expl="precondition" sum="9176784c479b4a2ff97029b001dad298" proved="true" expanded="true">
<goal name="WP_parameter queens.1.1" expl="correctness of parameter queens" sum="8539b23d3510fd4f1de63ea1997ce50d" proved="true" expanded="true">
<proof prover="alt-ergo" timelimit="10" edited="" obsolete="true">
</proof>
</goal>
<goal name="WP_parameter queens.1.2" expl="correctness of parameter queens" sum="8ade4db49784f57307243eebbcb198d5" proved="true" expanded="true">
</proof>
</goal>
<goal name="WP_parameter queens.1.3" expl="correctness of parameter queens" sum="3de11924bbf3959c8f7fdc4cdf27f0cb" proved="true" expanded="true">
</proof>
</goal>
<goal name="WP_parameter queens.1.4" expl="correctness of parameter queens" sum="2d57043056ef40059532b1cb570c9882" proved="true" expanded="true">
</proof>
</goal>
</transf>
</goal>
<goal name="WP_parameter queens.2" expl="normal postcondition" sum="36d4e9c3b144d3d58c150fa7126ef877" proved="true" expanded="true">
</proof>
</goal>
<goal name="WP_parameter queens.3" expl="exceptional postcondition" sum="0bb3a16f6adf6b874b658f9dea10cbdb" proved="true" expanded="true">
</proof>
</goal>
</transf>
</goal>
</theory>
</file>
</why3session>
module SetZeros
use import int.Int
use import module array.Array
let set_zeros (a : array int) =
for i = 0 to a.length - 1 do
invariant { forall j: int. 0 <= j < i -> a[j] = 0 }
a[i] <- 0
done
{ forall j: int. 0 <= j < a.length -> a[j] = 0 }
let harness () =
let a0 = make 42 1 in
set_zeros a0;
assert { length a0 = 42 };
assert { a0[12] = 0 }
Local Variables:
compile-command: "unset LANG; make -C ../.. examples/programs/zeros.gui"
End:
<why3session name="examples/programs/zeros/why3session.xml">
<file name="../zeros.mlw" verified="true" expanded="true">
<theory name="SetZeros" verified="true" expanded="true">
<goal name="WP_parameter set_zeros" expl="correctness of parameter set_zeros" sum="738a61fe56ee3528c88f7f6ad392b4ec" proved="true" expanded="true">
<goal name="WP_parameter set_zeros.1" expl="normal postcondition" sum="5ebaf8196c461842d3818d0f00c7b897" proved="true" expanded="true">
</proof>
</goal>
<goal name="WP_parameter set_zeros.2" expl="for loop initialization" sum="262d92c8877fa84a114fda64ce36167b" proved="true" expanded="true">
<result status="valid" time="0.01"/>
</proof>
</goal>
<goal name="WP_parameter set_zeros.3" expl="for loop preservation" sum="db37970e847fa3b97df4a7062a16ffea" proved="true" expanded="true">
</proof>
<proof prover="alt-ergo" timelimit="10" edited="zeros.mlw-SetZeros-WP_parameter set_zeros_1.why" obsolete="false">
<result status="unknown" time="0.02"/>
</proof>
</proof>
</goal>
<goal name="WP_parameter set_zeros.4" expl="normal postcondition" sum="e37d7aade59a72a7fadbab4f042fdec6" proved="true" expanded="true">
</proof>
</goal>
</transf>
</goal>
<goal name="WP_parameter harness" expl="correctness of parameter harness" sum="063941a2fece0c3d9083e25e9187d847" proved="true" expanded="true">
<goal name="WP_parameter harness.1" expl="assertion" sum="d48c1f007a0cb3fcb8c7c2072af4f1b2" proved="true" expanded="true">
</proof>
</goal>
<goal name="WP_parameter harness.2" expl="assertion" sum="6cd977227d738cbea667ca77e1839b1c" proved="true" expanded="true">
</proof>
</goal>
</transf>
</goal>
</theory>
</file>
</why3session>
