new library module Stack
parent 88fd5518
...@@ -155,4 +155,6 @@ why.conf ...@@ -155,4 +155,6 @@ why.conf
/examples/programs/binary_search/ /examples/programs/binary_search/
/examples/programs/same_fringe/ /examples/programs/same_fringe/
# modules
/modules/stack/
...@@ -5,6 +5,7 @@ filename "%f-%t-%g.p" ...@@ -5,6 +5,7 @@ filename "%f-%t-%g.p"
valid "Proof found" valid "Proof found"
invalid "Completion found" invalid "Completion found"
invalid "SZS status CounterSatisfiable"
timeout "Ran out of time" timeout "Ran out of time"
timeout "Resource limit exceeded" timeout "Resource limit exceeded"
timeout "CPU time limit exceeded" timeout "CPU time limit exceeded"
(* Polymorphic mutable stacks *)
module Stack
use import list.List
use import list.Length
mutable type t 'a model list 'a
parameter create : unit -> {} t 'a { result = Nil }
parameter push : x:'a -> s:t 'a -> {} unit writes s { s = Cons x (old s) }
exception Empty
parameter pop :
s:t 'a ->
'a
writes s raises Empty
{ match old s with Nil -> false | Cons x t -> result = x and s = t end }
| Empty -> { s = old s = Nil }
parameter top :
s:t 'a ->
'a
reads s raises Empty
{ match s with Nil -> false | Cons x _ -> result = x end }
| Empty -> { s = Nil }
parameter clear : s:t 'a -> {} unit writes s { s = Nil }
parameter copy : s:t 'a -> {} t 'a { result = s }
parameter is_empty : s:t 'a -> {} bool reads s { result=True <-> s = Nil }
parameter length : s:t 'a -> {} int reads s { result = length s }
module Test
use import int.Int
use module Stack
let test0 () =
let s = Stack.create () : Stack.t 'a in
assert { s = Nil };
let b = Stack.is_empty s in
assert { b = True };
let n = Stack.length s in
assert { n = 0 }
let test1 () =
let s = Stack.create () in
Stack.push 1 s;
let x = Stack.top s in assert { x = 1 };
Stack.push 2 s;
let x = Stack.top s in assert { x = 2 };
Local Variables:
compile-command: "unset LANG; make -C .. modules/stack"
End:
...@@ -1055,12 +1055,15 @@ let rec type_v env = function ...@@ -1055,12 +1055,15 @@ let rec type_v env = function
let env, bl = add_binders env bl in let env, bl = add_binders env bl in
tarrow bl (type_c env c) tarrow bl (type_c env c)
and type_c env c = { and type_c env c =
c_result_type = type_v env c.ic_result_type; let ef = effect env c.ic_effect in
c_effect = effect env c.ic_effect; let q = c.ic_post in
c_pre = c.ic_pre; (* saturate effect with exceptions appearing in q *)
c_post = c.ic_post; let ef = List.fold_left (fun ef (e, _) -> E.add_raise e ef) ef (snd q) in
} { c_result_type = type_v env c.ic_result_type;
c_effect = ef;
c_pre = c.ic_pre;
c_post = q; }
and add_binders env bl = and add_binders env bl =
map_fold_left add_binder env bl map_fold_left add_binder env bl
