GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
a6122c07
a6122c07
MARCHE Claude
proofs monitoring and cancellation
403a2cb0
5
5 changed files
115 additions
36 deletions
+115
-36
doc/manpages.tex
doc/manpages.tex
+3
src/ide/gmain.ml
src/ide/gmain.ml
+34
-11
src/ide/replay.ml
src/ide/replay.ml
+2
src/ide/session.ml
src/ide/session.ml
+60
-24
src/ide/session.mli
src/ide/session.mli
+16
-1
doc/manpages.tex
a6122c07
@@ -293,6 +293,9 @@ the actions of the various menus and buttons of the interface.
\item
Clean
Removes any unsuccessful proof attempt for which there is
\item
Clean
another successful proof attempt for the same goal
\item
Interrupt
Cancels all the proof attempts currently scheduled
but not yet started.
\end
description
\end
description
\subsection
Menus
\subsection
Menus
src/ide/gmain.ml
a6122c07
@@ -229,6 +229,23 @@ let cleaning_box =
GPack
button_box
`VERTICAL
border_width
5
spacing
5
GPack
button_box
`VERTICAL
border_width
5
spacing
5
packing
cleaning_frame
add
packing
cleaning_frame
add
let
monitor_frame
GBin
frame
label
"Monitor"
packing
tools_window_vbox
pack
expand
false
let
monitor_box
GPack
vbox
homogeneous
false
packing
monitor_frame
add
let
monitor_waiting
GMisc
label
text
" Waiting: 0"
packing
monitor_box
add
let
monitor_scheduled
GMisc
label
text
"Scheduled: 0"
packing
monitor_box
add
let
monitor_running
GMisc
label
text
" Running: 0"
packing
monitor_box
add
(* horizontal paned *)
@@ -318,6 +335,7 @@ let image_of_result ~obsolete result =
Session
Undone
image_undone
Session
Undone
image_undone
Session
Scheduled
image_scheduled
Session
Scheduled
image_scheduled
Session
Running
image_running
Session
Running
image_running
Session
Interrupted
assert
false
Session
InternalFailure
_
image_failure
Session
InternalFailure
_
image_failure
Session
Done
r
match
r
Call_provers
pr_answer
Session
Done
r
match
r
Call_provers
pr_answer
Call_provers
Valid
Call_provers
Valid
@@ -361,6 +379,11 @@ module M = Session.Make
let
_
GMain
Timeout
id
GMain
Timeout
add
ms
callback
f
in
let
_
GMain
Timeout
id
GMain
Timeout
add
ms
callback
f
in
let
notify_timer_state
t
s
r
monitor_waiting
set_text
"Waiting: "
string_of_int
t
monitor_scheduled
set_text
"Scheduled: "
string_of_int
s
monitor_running
set_text
"Running: "
string_of_int
r
let
set_row_status
row
b
let
set_row_status
row
b
@@ -1377,16 +1400,6 @@ let () =
b
connect
pressed
callback
replay_obsolete_proofs
b
connect
pressed
callback
in
in
let () =
let b = GButton.button ~packing:tools_box#add ~label:"Cancel" () in
b#misc#set_tooltip_markup "Mark all proofs below the current selection as <b>obsolete</b>";
let i = GMisc.image ~pixbuf:(!image_cancel) () in
let () = b#set_image i#coerce in
let (_ : GtkSignal.id) =
b#connect#pressed ~callback:cancel_proofs
in ()
(* removing *)
(* removing *)
@@ -1477,6 +1490,15 @@ let () =
b
connect
pressed
callback
clean_selection
b
connect
pressed
callback
clean_selection
in
in
let
let
b
GButton
button
packing
monitor_box
add
label
"Interrupt"
in
b
misc
set_tooltip_markup
"Cancels all scheduled proof attempts"
let
i
GMisc
pixbuf
image_cancel
in
let
b
set_image
i
coerce
in
let
_
GtkSignal
id
b
connect
pressed
callback
cancel_scheduled_proofs
in
(* Bind events *)
(* Bind events *)
@@ -1514,7 +1536,8 @@ let select_row r =
Session
Done
r
r
Call_provers
pr_output
Session
Done
r
r
Call_provers
pr_output
Session
Scheduled
"proof scheduled by not running yet"
Session
Scheduled
Session
Running
"prover currently running"
Session
Running
Session
InternalFailure
e
Session
Interrupted
assert
false
Session
InternalFailure
e
let
b
Buffer
create
37
in
let
b
Buffer
create
37
in
bprintf
b
"%a"
Exn_printer
exn_printer
e
bprintf
b
"%a"
Exn_printer
exn_printer
e
Buffer
contents
b
Buffer
contents
b
src/ide/replay.ml
a6122c07
@@ -119,6 +119,8 @@ module M = Session.Make
None
timeout_handler
Some
float
ms
1000
f
None
timeout_handler
Some
float
ms
1000
f
Some
_
failwith
"Replay.timeout: already one handler installed"
Some
_
failwith
let
notify_timer_state
_
_
_
src/ide/session.ml
a6122c07
@@ -96,6 +96,7 @@ let lookup_transformation env =
type
proof_attempt_status
type
Undone
Undone
Scheduled
(** external proof attempt is scheduled *)
Scheduled
Interrupted
Running
(** external proof attempt is in progress *)
Running
Done
of
Call_provers
prover_result
(** external proof done *)
Done
of
Call_provers
prover_result
InternalFailure
of
exn
(** external proof aborted by internal error *)
InternalFailure
of
exn
@@ -113,6 +114,9 @@ module type OBSERVER = sig
val
timeout
ms
int
unit
bool
unit
val
timeout
ms
int
unit
bool
unit
val
idle
unit
bool
unit
val
idle
unit
bool
unit
val
notify_timer_state
int
int
int
unit
module
Make
O
OBSERVER
struct
module
Make
O
OBSERVER
struct
@@ -277,7 +281,7 @@ let save_result fmt r =
let
save_status
fmt
s
let
save_status
fmt
s
match
s
match
s
Undone
Scheduled
Running
Undone
Scheduled
Running
Interrupted
fprintf
fmt
"<undone/>@
\n
fprintf
fmt
"<undone/>@
\n
InternalFailure
msg
InternalFailure
msg
fprintf
fmt
"<internalfailure reason=
%s
\n
fprintf
fmt
%s
\n
@@ -390,6 +394,13 @@ let set_proof_state ~obsolete a res =
type
action
Action_proof_attempt
of
bool
int
int
in_channel
option
string
Driver
driver
unit
Task
task
Action_delayed
of
unit
unit
let
actions_queue
Queue
create
(* timeout handler *)
type
timeout_action
type
timeout_action
@@ -436,24 +447,26 @@ let timeout_handler () =
let
continue
let
continue
match
l
match
l
eprintf
"Info: timeout_handler stopped@."
eprintf
false
false
_
true
_
true
in
in
O
notify_timer_state
Queue
length
actions_queue
Queue
length
proof_attempts_queue
length
l
timeout_handler_activated
continue
continue
timeout_handler_running
false
false
continue
continue
let
run_timeout_handler
let
run_timeout_handler
if
then
else
if
then
else
begin
begin
true
true
eprintf
"Info: timeout_handler started@."
eprintf
O
timeout
ms
100
timeout_handler
O
timeout
ms
100
timeout_handler
@@ -464,13 +477,6 @@ let schedule_any_timeout callback =
(* idle handler *)
(* idle handler *)
type
action
of
bool
int
int
in_channel
option
string
Driver
driver
unit
Task
task
Action_delayed
of
unit
unit
let
actions_queue
Queue
create
let
idle_handler_activated
ref
false
let
ref
false
let
idle_handler
let
idle_handler
@@ -500,31 +506,56 @@ let idle_handler () =
true
true
Queue
Empty
Queue
Empty
false
false
eprintf
"Info: idle_handler stopped@."
eprintf
false
false
e
e
Format
eprintf
"@[Exception raise in Session.idle_handler:@ %a@.@]"
Format
eprintf
Exn_printer
exn_printer
e
Exn_printer
exn_printer
e
eprintf
"Session.idle_handler stopped@."
eprintf
false
false
let
run_idle_handler
let
run_idle_handler
if
then
else
if
then
else
begin
begin
true
true
eprintf
"Info: idle_handler started@."
eprintf
O
idle
idle_handler
O
idle
idle_handler
(* main scheduling functions *)
let
let
new_queue
Queue
create
in
try
while
true
do
match
Queue
pop
actions_queue
_debug
,_
timelimit
,_
memlimit
,_
old
,_
command
_driver
callback
,_
goal
callback
Interrupted
Action_delayed
_
as
a
Queue
push
a
new_queue
done
Queue
Empty
Queue
transfer
new_queue
actions_queue
try
while
true
do
let
callback
,_
Queue
pop
in
callback
Interrupted
done
Queue
Empty
let
schedule_proof_attempt
debug
timelimit
memlimit
old
let
debug
timelimit
memlimit
old
command
driver
callback
goal
command
driver
callback
goal
eprintf
"Scheduling a new proof attempt@."
Queue
push
Queue
push
debug
timelimit
memlimit
old
command
driver
debug
timelimit
memlimit
old
command
driver
callback
goal
callback
goal
@@ -1484,8 +1515,9 @@ let save_session () =
let
redo_external_proof
timelimit
g
a
let
redo_external_proof
timelimit
g
a
(* check that the state is not Scheduled or Running *)
let
running
match
a
proof_state
let
previous_result
previous_obs
a
proof_state
a
proof_obsolete
in
Scheduled
Running
true
let
running
match
previous_result
Scheduled
Running
Interrupted
true
Done
_
Undone
InternalFailure
_
false
Done
_
Undone
InternalFailure
_
false
in
in
if
running
then
if
running
then
@@ -1495,7 +1527,11 @@ let redo_external_proof ~timelimit g a =
Undetected_prover
_
Undetected_prover
_
Detected_prover
p
Detected_prover
p
let
callback
result
let
callback
result
set_proof_state
obsolete
false
a
result
match
result
Interrupted
set_proof_state
obsolete
previous_obs
a
previous_result
_
set_proof_state
obsolete
false
a
result
in
in
let
old
if
a
edited_as
then
None
else
let
old
if
a
edited_as
then
None
else
begin
begin
@@ -1660,7 +1696,7 @@ let same_result r1 r2 =
let
check_external_proof
g
a
let
g
a
let
running
match
a
proof_state
let
running
match
a
proof_state
Scheduled
Running
true
Scheduled
Running
Interrupted
true
Done
_
Undone
InternalFailure
_
false
Done
_
Undone
InternalFailure
_
false
in
in
if
running
then
if
running
then
@@ -1676,7 +1712,7 @@ let check_external_proof g a =
let
p_name
p
prover_name
p
prover_version
in
let
p_name
p
prover_name
p
prover_version
in
let
callback
result
let
callback
result
match
result
match
result
Scheduled
Running
Scheduled
Running
Interrupted
Undone
assert
false
Undone
assert
false
InternalFailure
msg
InternalFailure
msg
push_report
g
p_name
CallFailed
msg
push_report
g
p_name
CallFailed
msg
@@ -1849,7 +1885,7 @@ let ft_of_pa a =
let
edit_proof
default_editor
project_dir
a
let
edit_proof
default_editor
project_dir
a
let
running
match
a
proof_state
let
running
match
a
proof_state
Scheduled
Running
true
Scheduled
Running
Interrupted
true
Undone
Done
_
InternalFailure
_
false
Undone
Done
_
InternalFailure
_
false
in
in
if
running
then
if
running
then
src/ide/session.mli
a6122c07
@@ -57,6 +57,7 @@ val lookup_transformation : Env.env -> string -> transformation_data
type
private
type
private
Undone
Undone
Scheduled
Scheduled
Interrupted
Running
Running
Done
of
Call_provers
prover_result
Done
of
Call_provers
prover_result
InternalFailure
of
exn
InternalFailure
of
exn
@@ -89,6 +90,11 @@ module type OBSERVER = sig
there is nothing else to do. When the given function returns
true, it must be rescheduled *)
val
notify_timer_state
int
int
int
unit
(** this function is called when timer state changes.
The first arg is the number of tasks waiting.
The second arg is the number of scheduled proof tasks.
The third arg is the number of running proof tasks *)
(** {2 Main functor} *)
@@ -228,7 +234,16 @@ module Make(O: OBSERVER) : sig
val
run_prover
context_unproved_goals_only
bool
val
run_prover
bool
timelimit
int
prover_data
any
unit
timelimit
int
prover_data
any
unit
(** [run_prover p a] runs prover [p] on all goals under [a] *)
the proof attempts are only scheduled for running, and they
will be started asynchronously when processors are available
val
unit
unit
(** cancels all currently scheduled proof attempts.
note that the already running proof attempts are not
stopped, the corresponding processes must terminate
by their own. *)
val
transform
bool
val
transform
bool
transformation_data
any
unit
transformation_data
any
unit
