Commit a520e4ee authored by MARCHE Claude's avatar MARCHE Claude
ITP: makes replay work interactively in IDE
parent 8585e5ea
...@@ -573,7 +573,7 @@ let schedule_proof_attempt c id pr ~limit ~callback ~notification = ...@@ -573,7 +573,7 @@ let schedule_proof_attempt c id pr ~limit ~callback ~notification =
update_proof_node notification c id false update_proof_node notification c id false
| _ -> ()) | _ -> ())
in in
schedule_proof_attempt_r c id pr ~limit:limit ~callback schedule_proof_attempt_r c id pr ~limit ~callback
let schedule_transformation_r c id name args ~callback = let schedule_transformation_r c id name args ~callback =
let apply_trans () = let apply_trans () =
...@@ -773,21 +773,19 @@ let copy_detached ~copy c from_any = ...@@ -773,21 +773,19 @@ let copy_detached ~copy c from_any =
| _ -> raise (BadCopyDetached "copy_detached. Can only copy goal") | _ -> raise (BadCopyDetached "copy_detached. Can only copy goal")
let replay_proof_attempt c pr limit (id: proofNodeID) ~callback = let replay_proof_attempt c pr limit (parid: proofNodeID) id ~callback ~notification =
(* The replay can be done on a different machine so we need (* The replay can be done on a different machine so we need
to check more things before giving the attempt to the scheduler *) to check more things before giving the attempt to the scheduler *)
if not (Hprover.mem c.controller_provers pr) then if not (Hprover.mem c.controller_provers pr) then
callback (Uninstalled pr) callback id (Uninstalled pr)
else else
(Queue.add (c, id, pr, limit, callback) scheduled_proof_attempts; schedule_proof_attempt c parid pr ~limit ~callback ~notification
callback Scheduled;
run_timeout_handler ())
type report = type report =
| Result of Call_provers.prover_result * Call_provers.prover_result | Result of Call_provers.prover_result * Call_provers.prover_result
(** Result(new_result,old_result) *) (** Result(new_result,old_result) *)
| CallFailed of exn | CallFailed of exn
| Replay_interrupted
| Prover_not_installed | Prover_not_installed
| Edited_file_absent of string | Edited_file_absent of string
| No_former_result of Call_provers.prover_result | No_former_result of Call_provers.prover_result
...@@ -799,8 +797,10 @@ let print_report fmt (r: report) = ...@@ -799,8 +797,10 @@ let print_report fmt (r: report) =
Format.fprintf fmt "new_result = %a, old_result = %a@." Format.fprintf fmt "new_result = %a, old_result = %a@."
Call_provers.print_prover_result new_r Call_provers.print_prover_result new_r
Call_provers.print_prover_result old_r Call_provers.print_prover_result old_r
| CallFailed _ -> | CallFailed e ->
Format.fprintf fmt "Callfailed@." Format.fprintf fmt "Callfailed %a@." Exn_printer.exn_printer e
| Replay_interrupted ->
Format.fprintf fmt "Interrupted@."
| Prover_not_installed -> | Prover_not_installed ->
Format.fprintf fmt "Prover not installed@." Format.fprintf fmt "Prover not installed@."
| Edited_file_absent _ -> | Edited_file_absent _ ->
...@@ -818,21 +818,25 @@ let replay_print fmt (lr: (proofNodeID * Whyconf.prover * Call_provers.resource_ ...@@ -818,21 +818,25 @@ let replay_print fmt (lr: (proofNodeID * Whyconf.prover * Call_provers.resource_
in in
Format.fprintf fmt "%a@." (Pp.print_list Pp.newline pp_elem) lr Format.fprintf fmt "%a@." (Pp.print_list Pp.newline pp_elem) lr
let replay ~remove_obsolete ~use_steps c ~callback = let replay ~remove_obsolete ~use_steps c ~callback ~notification ~final_callback =
(* === Side functions used by replay === *) (* === Side functions used by replay === *)
let counting s count = let counting s count =
match s with match s with
| Interrupted -> count := !count - 1 | Scheduled | Running -> ()
| Done _ -> count := !count - 1 | Unedited | JustEdited -> assert false
| InternalFailure _ -> count := !count - 1 | Interrupted
| Done _
| InternalFailure _
| Uninstalled _ -> count := !count - 1 | Uninstalled _ -> count := !count - 1
| _ -> () in in
let craft_report s r id pr limits pa = let craft_report s r id pr limits pa =
| Interrupted -> assert false | Scheduled | Running -> ()
(* Never happen r := (id, pr, limits, CallFailed (User_interrupt)) :: !r *) | Unedited | JustEdited -> assert false
| Interrupted ->
r := (id, pr, limits, Replay_interrupted ) :: !r
| Done new_r -> | Done new_r ->
(match pa.Session_itp.proof_state with (match pa.Session_itp.proof_state with
| None -> (r := (id, pr, limits, No_former_result new_r) :: !r) | None -> (r := (id, pr, limits, No_former_result new_r) :: !r)
...@@ -840,9 +844,10 @@ let replay ~remove_obsolete ~use_steps c ~callback = ...@@ -840,9 +844,10 @@ let replay ~remove_obsolete ~use_steps c ~callback =
| InternalFailure e -> | InternalFailure e ->
r := (id, pr, limits, CallFailed (e)) :: !r r := (id, pr, limits, CallFailed (e)) :: !r
| Uninstalled _ -> r := (id, pr, limits, Prover_not_installed) :: !r; | Uninstalled _ -> r := (id, pr, limits, Prover_not_installed) :: !r;
| _ -> () in in
let update_node pa s = (*
let update_node pa s callback =
(pa.Session_itp.proof_state <- Some new_r; (pa.Session_itp.proof_state <- Some new_r;
...@@ -851,7 +856,8 @@ let replay ~remove_obsolete ~use_steps c ~callback = ...@@ -851,7 +856,8 @@ let replay ~remove_obsolete ~use_steps c ~callback =
pa.proof_obsolete <- true pa.proof_obsolete <- true
| Uninstalled _ -> | Uninstalled _ ->
| _ -> () in | _ -> assert false in
let update_uninstalled c remove_obsolete id s pr = let update_uninstalled c remove_obsolete id s pr =
...@@ -873,8 +879,8 @@ let replay ~remove_obsolete ~use_steps c ~callback = ...@@ -873,8 +879,8 @@ let replay ~remove_obsolete ~use_steps c ~callback =
(fun _ _ -> count := !count + 1) session; (fun _ _ -> count := !count + 1) session;
(* Replaying function *) (* Replaying function *)
let replay_pa pa = let replay_pa id pa =
let id = pa.parent in let parid = pa.parent in
let pr = pa.prover in let pr = pa.prover in
(* If use_steps, we give only steps as a limit *) (* If use_steps, we give only steps as a limit *)
let limit = let limit =
...@@ -883,16 +889,19 @@ let replay ~remove_obsolete ~use_steps c ~callback = ...@@ -883,16 +889,19 @@ let replay ~remove_obsolete ~use_steps c ~callback =
else else
pa.limit pa.limit
in in
replay_proof_attempt c pr limit id replay_proof_attempt c pr limit parid id
~callback:(fun s -> ~callback:(fun id s ->
counting s count; counting s count;
craft_report s report id pr limit pa; craft_report s report parid pr limit pa;
update_node pa s; (*
update_uninstalled c remove_obsolete id s pr; update_node pa s ~callback ~notification;
if !count = 0 then callback !report) in *)
update_uninstalled c remove_obsolete parid s pr;
callback id s;
if !count = 0 then final_callback !report)
~notification in
(* Calling replay on all the proof_attempts of the session *) (* Calling replay on all the proof_attempts of the session *)
Session_itp.session_iter_proof_attempt Session_itp.session_iter_proof_attempt replay_pa session
(fun _ pa -> replay_pa pa) session
end end
...@@ -236,6 +236,7 @@ type report = ...@@ -236,6 +236,7 @@ type report =
| Replay_interrupted
...@@ -255,7 +256,9 @@ val replay: ...@@ -255,7 +256,9 @@ val replay:
some cases: for example when prover is not installed *) some cases: for example when prover is not installed *)
use_steps:bool -> (** Replay use recorded number of proof steps if true *) use_steps:bool -> (** Replay use recorded number of proof steps if true *)
controller -> controller ->
callback: callback:(proofAttemptID -> proof_attempt_status -> unit) ->
notification:(any -> bool -> unit) ->
final_callback:
((proofNodeID * Whyconf.prover * Call_provers.resource_limit * report) list ((proofNodeID * Whyconf.prover * Call_provers.resource_limit * report) list
-> unit) -> -> unit) ->
unit unit
...@@ -934,10 +934,12 @@ let () = ...@@ -934,10 +934,12 @@ let () =
let replay_session () : unit = let replay_session () : unit =
let d = get_server_data () in let d = get_server_data () in
let callback = fun lr -> let callback = callback_update_tree_proof d.cont in
let final_callback lr =
P.notify (Message (Replay_Info (Pp.string_of C.replay_print lr))) in P.notify (Message (Replay_Info (Pp.string_of C.replay_print lr))) in
(* TODO make replay print *) (* TODO make replay print *)
C.replay ~use_steps:false d.cont ~callback:callback ~remove_obsolete:false C.replay ~use_steps:false ~remove_obsolete:false d.cont
~callback ~notification:notify_change_proved ~final_callback
(* ---------------- Mark obsolete ------------------ *) (* ---------------- Mark obsolete ------------------ *)
let mark_obsolete n = let mark_obsolete n =
...@@ -1036,7 +1038,7 @@ let () = ...@@ -1036,7 +1038,7 @@ let () =
| Save_file_req (name, text) -> | Save_file_req (name, text) ->
save_file name text; save_file name text;
| Get_task nid -> send_task nid | Get_task nid -> send_task nid
| Replay_req -> replay_session (); reload_session () | Replay_req -> replay_session ()
| Interrupt_req -> C.interrupt () | Interrupt_req -> C.interrupt ()
| Command_req (nid, cmd) -> | Command_req (nid, cmd) ->
begin begin
...@@ -65,7 +65,7 @@ type proof_attempt_node = { ...@@ -65,7 +65,7 @@ type proof_attempt_node = {
proof_script : string option; (* non empty for external ITP *) proof_script : string option; (* non empty for external ITP *)
val session_iter_proof_attempt: (proofNodeID -> proof_attempt_node -> unit) -> session -> unit val session_iter_proof_attempt: (proofAttemptID -> proof_attempt_node -> unit) -> session -> unit
(* [is_below s a b] true if a is below b in the session tree *) (* [is_below s a b] true if a is below b in the session tree *)
val is_below: session -> any -> any -> bool val is_below: session -> any -> any -> bool
