Une MAJ de sécurité est nécessaire sur notre version actuelle. Elle sera effectuée lundi 02/08 entre 12h30 et 13h. L'interruption de service devrait durer quelques minutes (probablement moins de 5 minutes).
Commit a3109482 authored by Andrei Paskevich's avatar Andrei Paskevich
Env: separate library memoization tables per Env.env
parent f34fcfd3
......@@ -40,7 +40,7 @@ module Wenv = Weakhtbl.Make(struct type t = env let tag = env_tag end)
(** Environment construction and utilisation *)
let create_env = let c = ref (-1) in fun lp -> {
env_path = List.fold_right Sstr.add lp Sstr.empty;
env_path = Sstr.of_list lp;
env_tag = (incr c; Weakhtbl.create_tag !c)
......@@ -59,18 +59,18 @@ module Hpath = Hashtbl.Make(struct
end)
type 'a language = {
memo : 'a Hpath.t;
push : pathname -> 'a -> unit;
memo : 'a Hpath.t Wenv.t;
push : env -> pathname -> 'a -> unit;
regf : format_info -> unit format_parser -> unit;
regb : (pathname -> unit) -> unit;
regb : (env -> pathname -> unit) -> unit;
mutable fmts : unit format_parser Mstr.t;
mutable bins : (pathname -> unit) list;
mutable bins : (env -> pathname -> unit) list;
mutable info : format_info list;
let base_language = {
memo = Hpath.create 17;
push = (fun _ _ -> ());
memo = Wenv.create 3;
push = (fun _ _ _ -> ());
regf = (fun _ _ -> ());
regb = (fun _ -> ());
fmts = Mstr.empty;
......@@ -80,19 +80,17 @@ let base_language = {
exception LibraryConflict of pathname
let store lang path c =
lang.push path c;
Hpath.add lang.memo path c
let store lang path c = match path with
let store lang env path c =
let ht = try Wenv.find lang.memo env with Not_found ->
let ht = Hpath.create 17 in Wenv.set lang.memo env ht; ht in
match path with
| "why3" :: _ ->
begin try
let d = Hpath.find lang.memo path in
if c != d then raise (LibraryConflict path)
with Not_found -> store lang path c end
if Hpath.find ht path != c then raise (LibraryConflict path)
with Not_found -> lang.push env path c; Hpath.add ht path c end
| _ ->
assert (path = [] || not (Hpath.mem lang.memo path));
store lang path c
assert (path = [] || not (Hpath.mem ht path));
let register_format lang (ff,_,_ as inf) fp =
lang.regf inf fp;
......@@ -104,8 +102,8 @@ let add_builtin lang bp =
lang.bins <- bp :: lang.bins
let register_language parent convert = {
push = (fun path c -> store parent path (convert c));
push = (fun env path c -> store parent env path (convert c));
regf = (fun inf fp -> register_format parent inf fp);
regb = (fun bp -> add_builtin parent bp);
fmts = Mstr.empty;
......@@ -116,13 +114,13 @@ let register_language parent convert = {
let extension_table = ref Mstr.empty
let register_format ~desc lang ff extl fp =
let fp env path fn ch = store lang path (fp env path fn ch) in
let fp env path fn ch = store lang env path (fp env path fn ch) in
register_format lang (ff,extl,desc) fp;
let add_ext m e = Mstr.add e ff m in
extension_table := List.fold_left add_ext !extension_table extl
let bp path = store lang ("why3" :: path) (bp path) in
let bp env path = store lang env ("why3" :: path) (bp path) in
add_builtin lang bp
let list_formats lang =
......@@ -154,9 +152,8 @@ let get_parser lang ff =
let read_channel ?format lang env file ch =
let ff = get_format ?format file in
let fp = get_parser lang ff in
fp env [] file ch;
Hpath.find lang.memo []
get_parser lang ff env [] file ch;
Hpath.find (Wenv.find lang.memo env) []
let read_lib_file ?format lang env path file =
......@@ -167,7 +164,7 @@ let read_lib_file ?format lang env path file =
let read_file ?format lang env file =
read_lib_file ?format lang env [] file;
(** Library file parsing *)
......@@ -196,7 +193,7 @@ exception CircularDependency of pathname
let read_library lang env = function
| "why3" :: path ->
let read bp = try bp path with Not_found -> () in
let read bp = try bp env path with Not_found -> () in
List.iter read lang.bins
| path ->
let file = locate_library env path in
......@@ -217,9 +214,9 @@ let read_library lang env path =
let path = if path = [] then ["why3"] else path in
try Hpath.find lang.memo path with Not_found ->
try Hpath.find (Wenv.find lang.memo env) path with Not_found ->
read_library lang env path;
raise (LibraryNotFound path)
let read_theory env path s =
