GitLab
What's new
7
Support
Community forum
Keyboard shortcuts
Why3
why3
a164de08
a164de08
Johannes Kanig
addressing FIXME comments in code
bd4383b4
5 additions
5 deletions
+5
-5
src/driver/call_provers.ml
+5
-5
a164de08
@@ -228,12 +228,11 @@ let parse_prover_run res_parser time out ret on_timelimit timelimit ~printer_map
let
actualcommand
command
timelimit
memlimit
steplimit
file
let
arglist
Cmdline
cmdline_split
command
in
let
use_stdin
ref
true
in
(* FIXME: use_stdin is never modified below ?? *)
let
on_timelimit
ref
false
in
let
cmd_regexp
Str
regexp
in
let
replace
s
match
Str
matched_group
s
"f"
file
"f"
use_stdin
false
file
"t"
on_timelimit
true
string_of_int
timelimit
"T"
string_of_int
succ
timelimit
"U"
string_of_int
2
timelimit
@@ -246,9 +245,10 @@ let actualcommand command timelimit memlimit steplimit file =
"S"
string_of_int
steplimit
_
failwith
"unknown specifier, use %%, %f, %t, %T, %U, %m, %l, %d or %S"
in
(* FIXME: are we sure that tuples are evaluated from left to right ? *)
map
Str
global_substitute
cmd_regexp
replace
arglist
use_stdin
on_timelimit
let
args
map
Str
global_substitute
cmd_regexp
replace
arglist
in
args
use_stdin
on_timelimit
let
call_on_file
command
timelimit
memlimit
steplimit
res_parser
