Commit a14cd935 authored by MARCHE Claude's avatar MARCHE Claude
Merge branch 'claude'
Conflicts:
	drivers/smt-libv2.drv
parents ea4a727a b541c255
...@@ -152,6 +152,7 @@ LIB_MLW = ity expr dexpr ...@@ -152,6 +152,7 @@ LIB_MLW = ity expr dexpr
LIB_PARSER = ptree glob parser typing lexer LIB_PARSER = ptree glob parser typing lexer
LIB_TRANSFORM = simplify_formula inlining split_goal induction \ LIB_TRANSFORM = simplify_formula inlining split_goal induction \
detect_polymorphism \
eliminate_definition eliminate_algebraic \ eliminate_definition eliminate_algebraic \
eliminate_inductive eliminate_let eliminate_if \ eliminate_inductive eliminate_let eliminate_if \
libencoding discriminate encoding encoding_select \ libencoding discriminate encoding encoding_select \
import "cvc4_bare.drv" (** Why3 driver for CVC4 <= 1.3 *)
prelude "(set-logic AUFNIRA)"
A : Array
UF : Uninterpreted Function
NIRA : NonLinear Integer Reals Arithmetic
import "smt-libv2.drv"
import "discrimination.gen" import "discrimination.gen"
transformation "inline_trivial"
transformation "eliminate_builtin"
transformation "eliminate_definition"
transformation "eliminate_inductive"
transformation "eliminate_algebraic"
transformation "eliminate_epsilon"
transformation "simplify_formula"
(*transformation "simplify_trivial_quantification"*)
transformation "discriminate"
transformation "encoding_smt"
(** Error messages specific to CVC4 *)
outofmemory "(error \".*out of memory\")\\|Cannot allocate memory"
timeout "interrupted by timeout"
steps "smt::SmtEngine::resourceUnitsUsed, \\([0-9]+.?[0-9]*\\)" 1
(** Extra theories supported by CVC4 *)
(* Disabled:
CVC4 division seems to be neither the Euclidean one, nor the Computer one
theory int.EuclideanDivision
syntax function div "(div %1 %2)"
syntax function mod "(mod %1 %2)"
remove prop Mod_bound
remove prop Div_mod
remove prop Mod_1
remove prop Div_1
theory int.ComputerDivision
remove prop Div_mod
remove prop Mod_1
remove prop Div_1
prelude "(set-logic AUFBVNIRA)" (** Why3 driver for CVC4 >= 1.4 *)
(** A : Array
prelude "(set-logic AUFBVDTNIRA)"
A : Array
UF : Uninterpreted Function UF : Uninterpreted Function
DT : Datatypes (not needed at the end ...) BV : BitVectors
DT : Datatypes
NIRA : NonLinear Integer Reals Arithmetic NIRA : NonLinear Integer Reals Arithmetic
(* prelude "(set-logic ALL_SUPPORTED)" *) (* prelude "(set-logic ALL_SUPPORTED)"
does not seem to include DT
import "smt-libv2.drv" import "smt-libv2.drv"
(* temporarily disabled: too much experimental
transformation "detect_polymorphism"
transformation "eliminate_definition_if_poly"
transformation "eliminate_algebraic_if_poly"
(* regexp for steps *) transformation "simplify_formula"
steps "smt::SmtEngine::resourceUnitsUsed, \\([0-9]+.?[0-9]*\\)" 1 (*transformation "simplify_trivial_quantification"*)
transformation "discriminate_if_poly"
transformation "encoding_smt_if_poly"
(* regexp for steps should match things like
smt::SmtEngine::resourceUnitsUsed, 1041
but not in the same line as the "valid" answer
(* Disabled:
(* CVC4 division seems to be neither the Euclidean one, nor the Computer one *)
theory int.EuclideanDivision theory int.EuclideanDivision
syntax function div "(div %1 %2)" syntax function div "(div %1 %2)"
syntax function mod "(mod %1 %2)" syntax function mod "(mod %1 %2)"
(* Why driver for SMTLIB2 syntax *) (* Why3 driver for SMT-LIB2 syntax, excluding bit-vectors *)
prelude ";;; this is a prelude for smt-lib v2" prelude ";;; generated by SMT-LIB2 driver"
Note: we do not insert any command "set-logic" because its
interpretation is specific to provers
A : Array
printer "smtv2" printer "smtv2"
filename "%f-%t-%g.smt2" filename "%f-%t-%g.smt2"
unknown "^\\(unknown\\|sat\\|Fail\\)" "" unknown "^\\(unknown\\|sat\\|Fail\\)" ""
outofmemory "^(error \".*out of memory\")\\|Cannot allocate memory"
fail "^(error \"\\(W\\(A\\(R\\(N\\(I\\(N[^G]\\|[^N]\\)\\|[^I]\\)\\|[^N]\\)\\|[^R]\\)\\|[^A]\\)\\|[^W]\\)\\(.*\\)\")" "Error: \\1"
time "why3cpulimit time : %s s" time "why3cpulimit time : %s s"
valid "^unsat" valid "^unsat"
(* À discuter *)
theory BuiltIn theory BuiltIn
syntax type int "Int" syntax type int "Int"
...@@ -36,7 +33,7 @@ end ...@@ -36,7 +33,7 @@ end
theory int.Int theory int.Int
prelude ";;; this is a prelude for smt-lib v2 integer arithmetic" prelude ";;; SMT-LIB2: integer arithmetic"
syntax function zero "0" syntax function zero "0"
syntax function one "1" syntax function one "1"
...@@ -74,7 +71,7 @@ end ...@@ -74,7 +71,7 @@ end
theory real.Real theory real.Real
prelude ";;; this is a prelude for smt-lib v2 real arithmetic" prelude ";;; SMT-LIB2: real arithmetic"
syntax function zero "0.0" syntax function zero "0.0"
syntax function one "1.0" syntax function one "1.0"
...@@ -135,7 +132,7 @@ theory bool.Ite ...@@ -135,7 +132,7 @@ theory bool.Ite
meta "encoding : lskept" function ite meta "encoding : lskept" function ite
end end
(* (* not uniformly interpreted by provers
theory real.Truncate theory real.Truncate
syntax function floor "(to_int %1)" syntax function floor "(to_int %1)"
remove prop Floor_down remove prop Floor_down
(** Why3 driver for Z3 <= 4.3.1 *)
prelude "(set-logic AUFNIRA)" prelude "(set-logic AUFNIRA)"
(** A : Array (* A : Array
DT : Datatypes (not needed at the end ...) NIRA : NonLinear Integer Reals Arithmetic
import "z3_bare.drv" import "smt-libv2.drv"
(* transformation "simplify_trivial_quantification" *)
(** Error messages specific to Z3 *)
(* stop reporting Z3 2.19 warnings as errors *)
fail "^(error \"\\(W\\(A\\(R\\(N\\(I\\(N[^G]\\|[^N]\\)\\|[^I]\\)\\|[^N]\\)\\|[^R]\\)\\|[^A]\\)\\|[^W]\\)\\(.*\\)\")" "Error: \1"
(** Extra theories supported by Z3 *)
(* div/mod of Z3 seems to be Euclidean Division *)
remove prop Div_mod
remove prop Mod_1
remove prop Div_1
theory real.FromInt
syntax function from_int "(to_real %1)"
remove prop Zero
remove prop One
remove prop Add
remove prop Sub
remove prop Mul
remove prop Neg
(* does not work: Z3 segfaults
theory real.Trigonometry
syntax function cos "(cos %1)"
syntax function sin "(sin %1)"
syntax function pi "pi"
syntax function tan "(tan %1)"
syntax function atan "(atan %1)"
(** Why3 driver for Z3 >= 4.3.2 *)
(* Do not set any logic, let z3 choose by itself
(* div/mod of Z3 seems to be Euclidean Division *) (* div/mod of Z3 seems to be Euclidean Division *)
...@@ -32,7 +63,6 @@ theory real.Trigonometry ...@@ -32,7 +63,6 @@ theory real.Trigonometry
end end
(* bitvector modules, is not in smt-libv2.drv since cvc4 and z3 don't (* bitvector modules, is not in smt-libv2.drv since cvc4 and z3 don't
have the same name for the function to_int *) have the same name for the function to_int *)
...@@ -2,17 +2,19 @@ ...@@ -2,17 +2,19 @@
<!DOCTYPE why3session PUBLIC "-//Why3//proof session v5//EN" <!DOCTYPE why3session PUBLIC "-//Why3//proof session v5//EN"
"http://why3.lri.fr/why3session.dtd"> "http://why3.lri.fr/why3session.dtd">
<why3session shape_version="4"> <why3session shape_version="4">
<prover id="0" name="CVC3" version="2.4.1" timelimit="2" memlimit="0"/> <prover id="0" name="Alt-Ergo" version="0.99.1" timelimit="5" memlimit="1000"/>
<prover id="1" name="Alt-Ergo" version="0.95.1" timelimit="2" memlimit="0"/> <prover id="1" name="Alt-Ergo" version="0.95.1" timelimit="2" memlimit="0"/>
<prover id="2" name="Z3" version="2.19" timelimit="2" memlimit="0"/> <prover id="2" name="CVC3" version="2.4.1" timelimit="2" memlimit="0"/>
<prover id="3" name="Gappa" version="1.1.1" timelimit="5" memlimit="0"/> <prover id="3" name="CVC4" version="1.4" timelimit="5" memlimit="1000"/>
<file name="../12475.why"> <prover id="4" name="Z3" version="4.3.2" timelimit="5" memlimit="1000"/>
<file name="../12475.why" expanded="true">
<theory name="Stmt" sum="468c7dbd45c8c0959e1b169a3ca1bbe3" expanded="true"> <theory name="Stmt" sum="468c7dbd45c8c0959e1b169a3ca1bbe3" expanded="true">
<goal name="toto" expanded="true"> <goal name="toto" expanded="true">
<proof prover="0"><result status="valid" time="0.00"/></proof> <proof prover="0"><result status="valid" time="0.01" steps="3"/></proof>
<proof prover="1"><result status="valid" time="0.01"/></proof> <proof prover="1"><result status="valid" time="0.01"/></proof>
<proof prover="2"><result status="valid" time="0.02"/></proof> <proof prover="2"><result status="valid" time="0.00"/></proof>
<proof prover="3"><result status="unknown" time="0.00"/></proof> <proof prover="3"><result status="valid" time="0.01"/></proof>
<proof prover="4"><result status="valid" time="0.00"/></proof>
</goal> </goal>
</theory> </theory>
</file> </file>
This diff is collapsed.
(* This file is generated by Why3's Coq 8.4 driver *) (* This file is generated by Why3's Coq driver *)
(* Beware! Only edit allowed sections below *) (* Beware! Only edit allowed sections below *)
Require Import BuiltIn. Require Import BuiltIn.
Require Reals.R_sqrt. Require Reals.R_sqrt.
...@@ -33,7 +33,7 @@ Axiom sqr_le_sqrt : forall (x:R) (y:R), ((Reals.RIneq.Rsqr x) <= y)%R -> ...@@ -33,7 +33,7 @@ Axiom sqr_le_sqrt : forall (x:R) (y:R), ((Reals.RIneq.Rsqr x) <= y)%R ->
(x <= (Reals.R_sqrt.sqrt y))%R. (x <= (Reals.R_sqrt.sqrt y))%R.
Require Import Why3. Require Import Why3.
Ltac ae := why3 "Alt-Ergo,0.95.1," timelimit 3. Ltac ae := why3 "Alt-Ergo,0.99.1," timelimit 3.
(* Why3 goal *) (* Why3 goal *)
Theorem CauchySchwarz : forall (x1:R) (x2:R) (y1:R) (y2:R), ((dot x1 x2 y1 Theorem CauchySchwarz : forall (x1:R) (x2:R) (y1:R) (y2:R), ((dot x1 x2 y1
...@@ -30,7 +30,7 @@ Definition norm (x1:R) (x2:R): R := (Reals.R_sqrt.sqrt (norm2 x1 x2)). ...@@ -30,7 +30,7 @@ Definition norm (x1:R) (x2:R): R := (Reals.R_sqrt.sqrt (norm2 x1 x2)).
Axiom norm_pos : forall (x1:R) (x2:R), (0%R <= (norm x1 x2))%R. Axiom norm_pos : forall (x1:R) (x2:R), (0%R <= (norm x1 x2))%R.
Import R_sqrt. Import R_sqrt.
Open Scope R_scope. Open Scope R_scope.
...@@ -107,7 +107,7 @@ exec = "cvc4-1.4" ...@@ -107,7 +107,7 @@ exec = "cvc4-1.4"
version_switch = "--version" version_switch = "--version"
version_regexp = "This is CVC4 version \\([^ \n\r]+\\)" version_regexp = "This is CVC4 version \\([^ \n\r]+\\)"
version_ok = "1.4" version_ok = "1.4"
driver = "drivers/cvc4.drv" driver = "drivers/cvc4_14.drv"
# --random-seed=42 is not needed as soon as --random-freq=0.0 by default # --random-seed=42 is not needed as soon as --random-freq=0.0 by default
# to try: --inst-when=full-last-call # to try: --inst-when=full-last-call
# --rlimit=%S : cvc4 1.4 DOES NOT accept -1 as argument # --rlimit=%S : cvc4 1.4 DOES NOT accept -1 as argument
...@@ -338,6 +338,7 @@ version_ok = "201310" ...@@ -338,6 +338,7 @@ version_ok = "201310"
# Z3 4.3.2 does not support option global option -rs anymore. # Z3 4.3.2 does not support option global option -rs anymore.
# use settings given by "z3 -p" instead # use settings given by "z3 -p" instead
# Z3 4.3.2 supports Datatypes
[ATP z3] [ATP z3]
name = "Z3" name = "Z3"
exec = "z3" exec = "z3"
...@@ -347,7 +348,7 @@ version_switch = "-version" ...@@ -347,7 +348,7 @@ version_switch = "-version"
version_regexp = "Z3 version \\([^ \n\r]+\\)" version_regexp = "Z3 version \\([^ \n\r]+\\)"
version_ok = "4.3.3" version_ok = "4.3.3"
version_ok = "4.3.2" version_ok = "4.3.2"
driver = "drivers/z3_bare.drv" # Do not set any logic, let z3 choose by itself driver = "drivers/z3_432.drv"
command = "%l/why3-cpulimit %t %m -s %e -smt2 sat.random_seed=42 nlsat.randomize=false smt.random_seed=42 %f" command = "%l/why3-cpulimit %t %m -s %e -smt2 sat.random_seed=42 nlsat.randomize=false smt.random_seed=42 %f"
[ATP z3] [ATP z3]
...@@ -803,4 +803,3 @@ let make_record_pattern kn fll ty = ...@@ -803,4 +803,3 @@ let make_record_pattern kn fll ty =
| None -> pat_wild (ty_inst s (Opt.get pj.ls_value)) | None -> pat_wild (ty_inst s (Opt.get pj.ls_value))
in in
pat_app cs (List.map get_arg pjl) ty pat_app cs (List.map get_arg pjl) ty
...@@ -336,6 +336,7 @@ let sprint_decl (fn : 'a -> Format.formatter -> decl -> 'a * string list) = ...@@ -336,6 +336,7 @@ let sprint_decl (fn : 'a -> Format.formatter -> decl -> 'a * string list) =
exception UnsupportedType of ty * string exception UnsupportedType of ty * string
exception UnsupportedTerm of term * string exception UnsupportedTerm of term * string
exception UnsupportedPattern of pattern * string
exception UnsupportedDecl of decl * string exception UnsupportedDecl of decl * string
exception NotImplemented of string exception NotImplemented of string
exception Unsupported of string exception Unsupported of string
...@@ -344,6 +345,7 @@ exception Unsupported of string ...@@ -344,6 +345,7 @@ exception Unsupported of string
let unsupportedType e s = raise (UnsupportedType (e,s)) let unsupportedType e s = raise (UnsupportedType (e,s))
let unsupportedTerm e s = raise (UnsupportedTerm (e,s)) let unsupportedTerm e s = raise (UnsupportedTerm (e,s))
let unsupportedPattern p s = raise (UnsupportedPattern (p,s))
let unsupportedDecl e s = raise (UnsupportedDecl (e,s)) let unsupportedDecl e s = raise (UnsupportedDecl (e,s))
let notImplemented s = raise (NotImplemented s) let notImplemented s = raise (NotImplemented s)
let unsupported s = raise (Unsupported s) let unsupported s = raise (Unsupported s)
...@@ -383,6 +385,9 @@ let () = Exn_printer.register (fun fmt exn -> match exn with ...@@ -383,6 +385,9 @@ let () = Exn_printer.register (fun fmt exn -> match exn with
| UnsupportedTerm (e,s) -> | UnsupportedTerm (e,s) ->
fprintf fmt "@[@[<hov 3> This expression isn't supported:@\n%a@]@\n %s@]" fprintf fmt "@[@[<hov 3> This expression isn't supported:@\n%a@]@\n %s@]"
Pretty.print_term e s Pretty.print_term e s
| UnsupportedPattern (p,s) ->
fprintf fmt "@[@[<hov 3> This pattern isn't supported:@\n%a@]@\n %s@]"
Pretty.print_pat p s
| UnsupportedDecl (d,s) -> | UnsupportedDecl (d,s) ->
fprintf fmt "@[@[<hov 3> This declaration isn't supported:@\n%a@]@\n %s@]" fprintf fmt "@[@[<hov 3> This declaration isn't supported:@\n%a@]@\n %s@]"
Pretty.print_decl d s Pretty.print_decl d s
...@@ -108,6 +108,7 @@ exception NotImplemented of string ...@@ -108,6 +108,7 @@ exception NotImplemented of string
val unsupportedType : ty -> string -> 'a val unsupportedType : ty -> string -> 'a
val unsupportedTerm : term -> string -> 'a val unsupportedTerm : term -> string -> 'a
val unsupportedPattern : pattern -> string -> 'a
val unsupportedDecl : decl -> string -> 'a val unsupportedDecl : decl -> string -> 'a
val notImplemented : string -> 'a val notImplemented : string -> 'a
...@@ -106,7 +106,11 @@ val task_decls : task -> decl list ...@@ -106,7 +106,11 @@ val task_decls : task -> decl list
val task_goal : task -> prsymbol val task_goal : task -> prsymbol
val task_goal_fmla : task -> term val task_goal_fmla : task -> term
val task_separate_goal : task -> tdecl * task val task_separate_goal : task -> tdecl * task
(** [task_separate_goal t] returns a pair [(g,t')] where [g] is the
goal of the task [t] and [t'] is the rest. raises [GoalNotFound]
if task [t] has no goal *)
(** {2 selectors} *) (** {2 selectors} *)
...@@ -130,4 +134,3 @@ exception GoalNotFound ...@@ -130,4 +134,3 @@ exception GoalNotFound
exception GoalFound exception GoalFound
exception SkipFound exception SkipFound
exception LemmaFound exception LemmaFound
...@@ -111,6 +111,7 @@ val ty_match : ty Mtv.t -> ty -> ty -> ty Mtv.t ...@@ -111,6 +111,7 @@ val ty_match : ty Mtv.t -> ty -> ty -> ty Mtv.t
val ty_inst : ty Mtv.t -> ty -> ty val ty_inst : ty Mtv.t -> ty -> ty
val ty_freevars : Stv.t -> ty -> Stv.t val ty_freevars : Stv.t -> ty -> Stv.t
val ty_closed : ty -> bool val ty_closed : ty -> bool
(** [ty_closed ty] returns true when [ty] is not polymorphic *)
val ty_equal_check : ty -> ty -> unit val ty_equal_check : ty -> ty -> unit
...@@ -150,4 +151,3 @@ val oty_cons : ty list -> ty option -> ty list ...@@ -150,4 +151,3 @@ val oty_cons : ty list -> ty option -> ty list
val oty_match : ty Mtv.t -> ty option -> ty option -> ty Mtv.t val oty_match : ty Mtv.t -> ty option -> ty option -> ty Mtv.t
val oty_inst : ty Mtv.t -> ty option -> ty option val oty_inst : ty Mtv.t -> ty option -> ty option
val oty_freevars : Stv.t -> ty option -> Stv.t val oty_freevars : Stv.t -> ty option -> Stv.t
...@@ -158,12 +158,59 @@ let rec print_term info fmt t = match t.t_node with ...@@ -158,12 +158,59 @@ let rec print_term info fmt t = match t.t_node with
| Tif (f1,t1,t2) -> | Tif (f1,t1,t2) ->
fprintf fmt "@[(ite %a@ %a@ %a)@]" fprintf fmt "@[(ite %a@ %a@ %a)@]"
(print_fmla info) f1 (print_term info) t1 (print_term info) t2 (print_fmla info) f1 (print_term info) t1 (print_term info) t2
| Tcase _ -> unsupportedTerm t | Tcase _ -> unsupportedTerm t
"smtv2 : you must eliminate match" "smtv2: you must eliminate match"
| Tcase(t,bl) ->
let subject = create_vsymbol (id_fresh "subject") (t_type t) in
fprintf fmt "@[(let ((%a @[%a@]))@ %a)@]"
print_var subject (print_term info) t
(print_branches info subject print_term) bl;
forget_var subject
| Teps _ -> unsupportedTerm t | Teps _ -> unsupportedTerm t
"smtv2 : you must eliminate epsilon" "smtv2: you must eliminate epsilon"
| Tquant _ | Tbinop _ | Tnot _ | Ttrue | Tfalse -> raise (TermExpected t) | Tquant _ | Tbinop _ | Tnot _ | Ttrue | Tfalse -> raise (TermExpected t)
and print_branches info subject pr fmt bl =
match bl with
| [] -> assert false
| br::bl ->
let (p,t) = t_open_branch br in
let constr,args =
try
match p.pat_node with
| Papp(cs,args) ->
let vars = List.map
(function { pat_node = Pvar v} -> v
| _ -> raise Exit) args
in cs,vars
| _ -> raise Exit
with Exit ->
"smtv2: you must compile nested pattern-matching"
in
match bl with
| [] -> print_branch info subject pr fmt (constr,args,t)
| _ ->
fprintf fmt "@[(ite (is-%a %a) %a %a)@]"
print_ident constr.ls_name print_var subject
(print_branch info subject pr) (constr,args,t)
(print_branches info subject pr) bl
and print_branch info subject pr fmt (cs,vars,t) =
let i = ref 0 in
let print_proj fmt v =
incr i;
fprintf fmt "(%a (%a_proj_%d %a))" print_var v print_ident cs.ls_name
!i print_var subject
in
match vars with
| [] -> pr info fmt t
| _ -> fprintf fmt "@[(let (%a) %a)@]"
(print_list space print_proj) vars
(pr info) t
and print_fmla info fmt f = match f.t_node with and print_fmla info fmt f = match f.t_node with
| Tapp ({ ls_name = id }, []) -> | Tapp ({ ls_name = id }, []) ->
print_ident fmt id print_ident fmt id
...@@ -215,8 +262,16 @@ and print_fmla info fmt f = match f.t_node with ...@@ -215,8 +262,16 @@ and print_fmla info fmt f = match f.t_node with
fprintf fmt "@[(let ((%a %a))@ %a)@]" print_var v fprintf fmt "@[(let ((%a %a))@ %a)@]" print_var v
(print_term info) t1 (print_fmla info) f2; (print_term info) t1 (print_fmla info) f2;
forget_var v forget_var v
| Tcase _ -> unsupportedTerm f | Tcase _ -> unsupportedTerm f
"smtv2 : you must eliminate match" "smtv2 : you must eliminate match"
| Tcase(t,bl) ->
(print_branches info subject print_fmla) bl;
forget_var subject
| Tvar _ | Tconst _ | Teps _ -> raise (FmlaExpected f) | Tvar _ | Tconst _ | Teps _ -> raise (FmlaExpected f)
and print_expr info fmt = and print_expr info fmt =
...@@ -269,11 +324,36 @@ let print_prop_decl info fmt k pr f = match k with ...@@ -269,11 +324,36 @@ let print_prop_decl info fmt k pr f = match k with
fprintf fmt "@[(check-sat)@]@\n" fprintf fmt "@[(check-sat)@]@\n"
| Plemma| Pskip -> assert false | Plemma| Pskip -> assert false
let print_constructor_decl info fmt (ls,args) =
match args with
| [] -> fprintf fmt "(%a)" print_ident ls.ls_name
| _ ->
fprintf fmt "@[(%a@ " print_ident ls.ls_name;
