Commit 9f605136 authored by Guillaume Melquiond's avatar Guillaume Melquiond
Improve benchmarks for example/multiprecision.
1. Output is in µs/ops.
2. The number of iterations is inversely proportional to the size of
   the arguments, to account for the inherent time complexity.
3. The compilation flags are taken from GMP, if available.
parent 41e5758e
...@@ -244,8 +244,8 @@ extract_and_test_wmp () { ...@@ -244,8 +244,8 @@ extract_and_test_wmp () {
echo "ok" echo "ok"
else else
echo "execution failed!" echo "execution failed!"
echo $dir/main.opt echo $dir/build/bench-tests
$dir/main.opt $dir/build/bench-tests
exit 1 exit 1
fi fi
else else
...@@ -10,6 +10,14 @@ else ...@@ -10,6 +10,14 @@ else
endif endif
endif endif
ifdef GMP_DIR
GMPFLAGS = $(shell sed -n -e 's/^CFLAGS = \(.*\)/\1/p' $(GMP_DIR)/Makefile)
else
GMPFLAGS = -O2 -pedantic -fomit-frame-pointer
endif
CFLAGS = $(GMPFLAGS) -Wall -Wno-unused-function -g -std=c11
all: why3 extract all: why3 extract
clean: clean:
...@@ -33,23 +41,23 @@ extract: why3 dir cfiles ...@@ -33,23 +41,23 @@ extract: why3 dir cfiles
CFILES = build/uint64gmp.c build/toom.c build/div.c build/logical.c build/mul.c build/sub.c build/add.c build/compare.c build/util.c build/int32.c CFILES = build/uint64gmp.c build/toom.c build/div.c build/logical.c build/mul.c build/sub.c build/add.c build/compare.c build/util.c build/int32.c
tests: extract check-gmp tests: extract check-gmp
gcc -O2 -Wall -Wno-unused-function -g -std=c11 -pedantic tests.c $(CFILES) -I$(GMP_DIR) -Irandom -L$(GMP_LIB) -fomit-frame-pointer -mtune=haswell -march=haswell -fno-tree-vectorize -lgmp -o build/tests gcc $(CFLAGS) tests.c $(CFILES) -I$(GMP_DIR) -Irandom -L$(GMP_LIB) -lgmp -o build/tests
gcc -O2 -Wall -Wno-unused-function -g -std=c11 -pedantic -DCOMPARE_MINI tests.c $(CFILES) -I$(GMP_DIR) -Irandom -Imini-gmp -fomit-frame-pointer -mtune=haswell -march=haswell -fno-tree-vectorize -o build/minitests gcc $(CFLAGS) -DCOMPARE_MINI tests.c $(CFILES) -I$(GMP_DIR) -Irandom -Imini-gmp -o build/minitests
./build/tests ./build/tests
./build/minitests ./build/minitests
bench-tests: extract bench-tests: extract
gcc -O2 -Wall -Wno-unused-function -g -std=c11 tests.c $(CFILES) -Ibench-include -Irandom -fomit-frame-pointer -fno-tree-vectorize -lgmp -o build/bench-tests gcc $(CFLAGS) tests.c $(CFILES) -Ibench-include -Irandom -lgmp -o build/bench-tests
build/why3%bench: extract check-gmp build/why3%bench: extract check-gmp
gcc -O2 -Wall -Wno-unused-function -g -std=c11 -DTEST_WHY3 -DTEST_`echo $* | tr [:lower:] [:upper:]` tests.c $(CFILES) -I$(GMP_DIR) -Irandom -L$(GMP_LIB) -fomit-frame-pointer -mtune=haswell -march=haswell -fno-tree-vectorize -lgmp -o $@ gcc $(CFLAGS) -DTEST_WHY3 -DTEST_`echo $* | tr [:lower:] [:upper:]` tests.c $(CFILES) -I$(GMP_DIR) -Irandom -L$(GMP_LIB) -lgmp -o $@
build/gmp%bench: extract check-gmp build/gmp%bench: extract check-gmp
gcc -O2 -Wall -Wno-unused-function -g -std=c11 -DTEST_GMP -DTEST_`echo $* | tr [:lower:] [:upper:]` tests.c $(CFILES) -I$(GMP_DIR) -Irandom -L$(GMP_LIB) -fomit-frame-pointer -mtune=haswell -march=haswell -fno-tree-vectorize -lgmp -o $@ gcc $(CFLAGS) -DTEST_GMP -DTEST_`echo $* | tr [:lower:] [:upper:]` tests.c $(CFILES) -I$(GMP_DIR) -Irandom -L$(GMP_LIB) -lgmp -o $@
build/minigmp%bench: extract build/minigmp%bench: extract
gcc -O2 -Wall -Wno-unused-function -g -std=c11 -DTEST_MINIGMP -DTEST_`echo $* | tr [:lower:] [:upper:]` tests.c $(CFILES) -I$(GMP_DIR) -Imini-gmp -Irandom -fomit-frame-pointer -mtune=haswell -march=haswell -fno-tree-vectorize -o $@ gcc $(CFLAGS) -DTEST_MINIGMP -DTEST_`echo $* | tr [:lower:] [:upper:]` tests.c $(CFILES) -I$(GMP_DIR) -Imini-gmp -Irandom -o $@
alltests: tests build/why3addbench build/why3mulbench build/why3toombench build/why3divbench build/gmpaddbench build/gmpmulbench build/gmptoombench build/gmpdivbench build/minigmpaddbench build/minigmpmulbench build/minigmpdivbench build/minigmptoombench alltests: tests build/why3addbench build/why3mulbench build/why3toombench build/why3divbench build/gmpaddbench build/gmpmulbench build/gmptoombench build/gmpdivbench build/minigmpaddbench build/minigmpmulbench build/minigmpdivbench build/minigmptoombench
...@@ -126,14 +126,14 @@ set xlabel "" ...@@ -126,14 +126,14 @@ set xlabel ""
set xlabel font "" textcolor lt -1 norotate set xlabel font "" textcolor lt -1 norotate
set x2label "" set x2label ""
set x2label font "" textcolor lt -1 norotate set x2label font "" textcolor lt -1 norotate
set xrange [ 200.000 : 600.000 ] noreverse nowriteback set xrange [ * : * ] noreverse nowriteback
set x2range [ 210.000 : 570.000 ] noreverse nowriteback set x2range [ * : * ] noreverse nowriteback
set ylabel "" set ylabel ""
set ylabel font "" textcolor lt -1 rotate by -270 set ylabel font "" textcolor lt -1 rotate by -270
set y2label "" set y2label ""
set y2label font "" textcolor lt -1 rotate by -270 set y2label font "" textcolor lt -1 rotate by -270
set yrange [ -0.100000 : 0.00000 ] noreverse nowriteback set yrange [ * : * ] noreverse nowriteback
set y2range [ -0.0984999 : -0.0110689 ] noreverse nowriteback set y2range [ * : * ] noreverse nowriteback
set zlabel "" set zlabel ""
set zlabel font "" textcolor lt -1 norotate set zlabel font "" textcolor lt -1 norotate
set zrange [ * : * ] noreverse nowriteback set zrange [ * : * ] noreverse nowriteback
...@@ -43,9 +43,9 @@ void mpn_dump(mp_ptr ap, mp_size_t an) { ...@@ -43,9 +43,9 @@ void mpn_dump(mp_ptr ap, mp_size_t an) {
void init_valid (mp_ptr ap, mp_ptr bp, mp_size_t an, mp_size_t bn) { void init_valid (mp_ptr ap, mp_ptr bp, mp_size_t an, mp_size_t bn) {
for (int i = 0; i <= an; i++) for (int i = 0; i < an; i++)
ap[i] = genrand64_int64(); ap[i] = genrand64_int64();
for (int i = 0; i <= bn; i++) for (int i = 0; i < bn; i++)
bp[i] = genrand64_int64(); bp[i] = genrand64_int64();
while (bp[bn-1]==0) while (bp[bn-1]==0)
bp[bn-1] = genrand64_int64(); bp[bn-1] = genrand64_int64();
...@@ -56,6 +56,7 @@ int main () { ...@@ -56,6 +56,7 @@ int main () {
mp_ptr ap, bp, rp, refp, rq, rr, refq, refr; mp_ptr ap, bp, rp, refp, rq, rr, refq, refr;
mp_size_t max_n, max_add, max_mul, max_toom, max_div, an, bn, rn; mp_size_t max_n, max_add, max_mul, max_toom, max_div, an, bn, rn;
#ifdef BENCH #ifdef BENCH
int nb, nb_iter;
struct timeval begin, end; struct timeval begin, end;
double elapsed; double elapsed;
#endif #endif
...@@ -71,7 +72,11 @@ int main () { ...@@ -71,7 +72,11 @@ int main () {
//gmp_randseed_ui(rands, 42); //gmp_randseed_ui(rands, 42);
/* Re-interpret reps argument as a size argument. */ /* Re-interpret reps argument as a size argument. */
#ifdef BENCH
init_genrand64(0);
#else
init_genrand64((unsigned long long)time(NULL)); init_genrand64((unsigned long long)time(NULL));
#endif
max_n = 1000; max_n = 1000;
max_add = 50; max_add = 50;
max_mul = 20; max_mul = 20;
...@@ -90,7 +95,7 @@ int main () { ...@@ -90,7 +95,7 @@ int main () {
#ifdef TEST_ADD #ifdef TEST_ADD
printf ("#an bn t(s)\n"); printf ("#an bn t(µs)\n");
#endif #endif
for (an = 2; an <= max_add; an += 1) for (an = 2; an <= max_add; an += 1)
...@@ -99,10 +104,12 @@ int main () { ...@@ -99,10 +104,12 @@ int main () {
init_valid (ap, bp, an, bn); init_valid (ap, bp, an, bn);
elapsed = 0; elapsed = 0;
for (int iter = 0; iter != 1000; ++iter) { nb_iter = 1000;
for (int iter = 0; iter != nb_iter; ++iter) {
nb = 10000 / an;
gettimeofday(&begin, NULL); gettimeofday(&begin, NULL);
for (int i = 0; i != 100; ++i) for (int i = 0; i != nb; ++i)
#endif #endif
...@@ -117,10 +124,11 @@ int main () { ...@@ -117,10 +124,11 @@ int main () {
gettimeofday(&end, NULL); gettimeofday(&end, NULL);
elapsed += elapsed +=
(end.tv_sec - begin.tv_sec) (end.tv_sec - begin.tv_sec) * 1000000.0
+ ((end.tv_usec - begin.tv_usec)/1000000.0); + (end.tv_usec - begin.tv_usec);
printf ("%d %d %f\n", an, bn, elapsed); elapsed = elapsed / (nb * nb_iter);
printf ("%d %d %g\n", an, bn, elapsed);
if (an==bn) if (an==bn)
printf ("\n"); //for gnuplot printf ("\n"); //for gnuplot
#endif #endif
...@@ -155,7 +163,7 @@ int main () { ...@@ -155,7 +163,7 @@ int main () {
#endif #endif
#ifdef TEST_MUL #ifdef TEST_MUL
#endif #endif
for (an = 2; an <= max_mul; an += 1) for (an = 2; an <= max_mul; an += 1)
...@@ -164,10 +172,12 @@ int main () { ...@@ -164,10 +172,12 @@ int main () {
for (int iter = 0; iter != 500; ++iter) { nb_iter = 500;
for (int i = 0; i != 100; ++i) nb = 5000 / an;
#endif #endif
#if defined(TEST_GMP) || defined(TEST_MINIGMP) #if defined(TEST_GMP) || defined(TEST_MINIGMP)
...@@ -181,10 +191,11 @@ int main () { ...@@ -181,10 +191,11 @@ int main () {
#endif #endif
...@@ -210,7 +221,7 @@ int main () { ...@@ -210,7 +221,7 @@ int main () {
#ifdef TEST_TOOM #ifdef TEST_TOOM
#endif #endif
for (bn = 35; bn <= max_toom; bn += 2) for (bn = 35; bn <= max_toom; bn += 2)
...@@ -221,10 +232,12 @@ int main () { ...@@ -221,10 +232,12 @@ int main () {
for (int i = 0; i != 100; ++i) nb = 5000 / bn;
for (int i = 0, maxi = nb; i != maxi; ++i)
#endif #endif
...@@ -238,10 +251,11 @@ int main () { ...@@ -238,10 +251,11 @@ int main () {
#endif #endif
...@@ -267,7 +281,7 @@ int main () { ...@@ -267,7 +281,7 @@ int main () {
#ifdef TEST_DIV #ifdef TEST_DIV
#endif #endif
for (an = 2; an <= max_div; an += 1) for (an = 2; an <= max_div; an += 1)
...@@ -280,13 +294,15 @@ int main () { ...@@ -280,13 +294,15 @@ int main () {
#ifdef TEST_MINIGMP #ifdef TEST_MINIGMP
mpn_copyi(refr, ap, an); mpn_copyi(refr, ap, an);
#endif #endif
for (int i = 0; i != 100; ++i) nb = 1500 / an;
#endif #endif
#ifdef TEST_GMP #ifdef TEST_GMP
...@@ -303,10 +319,11 @@ int main () { ...@@ -303,10 +319,11 @@ int main () {
#endif #endif
