Mise à jour terminée. Pour connaître les apports de la version 13.8.4 par rapport à notre ancienne version vous pouvez lire les "Release Notes" suivantes :
https://about.gitlab.com/releases/2021/02/11/security-release-gitlab-13-8-4-released/
https://about.gitlab.com/releases/2021/02/05/gitlab-13-8-3-released/
Commit 9f39433d authored by Andrei Paskevich's avatar Andrei Paskevich
WP: preserve absurd in boolean simplification
parent 0cefbf9d
...@@ -413,6 +413,9 @@ let t_True env = fs_app (find_ls ~pure:true env "True") [] (ty_bool env) ...@@ -413,6 +413,9 @@ let t_True env = fs_app (find_ls ~pure:true env "True") [] (ty_bool env)
let t_False env = fs_app (find_ls ~pure:true env "False") [] (ty_bool env) let t_False env = fs_app (find_ls ~pure:true env "False") [] (ty_bool env)
let mk_t_if env f = t_if f (t_True env) (t_False env) let mk_t_if env f = t_if f (t_True env) (t_False env)
let ls_absurd = create_lsymbol (id_fresh "absurd") [] None
let t_absurd = ps_app ls_absurd []
env : module_uc env : module_uc
rm : Spv.t Mreg.t (maps regions to pvsymbol sets) rm : Spv.t Mreg.t (maps regions to pvsymbol sets)
...@@ -518,7 +521,7 @@ and wp_desc env rm e q = match e.expr_desc with ...@@ -518,7 +521,7 @@ and wp_desc env rm e q = match e.expr_desc with
let t = t_var x.pv_pure in let t = t_var x.pv_pure in
wp_label e (t_case t (List.map branch bl)) wp_label e (t_case t (List.map branch bl))
| Eabsurd -> | Eabsurd ->
wp_label e t_false wp_label e t_absurd
| Eraise (x, None) -> | Eraise (x, None) ->
(* $wp(raise E, _, R) = R$ *) (* $wp(raise E, _, R) = R$ *)
let _, ql = q in let _, ql = q in
...@@ -689,18 +692,27 @@ let rec remove_at f = match f.t_node with ...@@ -689,18 +692,27 @@ let rec remove_at f = match f.t_node with
| _ -> | _ ->
t_map remove_at f t_map remove_at f
(* replace t_absurd with t_false *)
let rec unabsurd f = match f.t_node with
| Tapp (ls, []) when ls_equal ls ls_absurd ->
t_label_copy f t_false
| _ ->
t_map unabsurd f
let add_wp_decl ps f uc = let add_wp_decl ps f uc =
(* prepare a proposition symbol *)
let name = ps.ps_pure.ls_name in let name = ps.ps_pure.ls_name in
let s = "WP_" ^ name.id_string in let s = "WP_" ^ name.id_string in
let label = let label = ("expl:" ^ name.id_string) :: name.id_label in
("expl:" ^ name.id_string) :: ps.ps_pure.ls_name.id_label
in
let id = id_fresh ~label ?loc:name.id_loc s in let id = id_fresh ~label ?loc:name.id_loc s in
let f = bool_to_prop uc (remove_at f) in let pr = create_prsymbol id in
(* prepare the VC formula *)
let km = get_known (pure_uc uc) in let km = get_known (pure_uc uc) in
let f = remove_at f in
let f = bool_to_prop uc f in
let f = eval_match ~inline:inline_nonrec_linear km f in let f = eval_match ~inline:inline_nonrec_linear km f in
let f = unabsurd f in
(* printf "wp: f=%a@." print_term f; *) (* printf "wp: f=%a@." print_term f; *)
let d = create_prop_decl Pgoal pr f in let d = create_prop_decl Pgoal pr f in
add_pure_decl d uc add_pure_decl d uc
