Commit 9e7b004a authored by Stefan Berghofer's avatar Stefan Berghofer
Adapted to Isabelle2018
parent a1cc4c0a
...@@ -175,11 +175,8 @@ pvsbin/ ...@@ -175,11 +175,8 @@ pvsbin/
/lib/isabelle/map/ /lib/isabelle/map/
/lib/isabelle/real/ /lib/isabelle/real/
/lib/isabelle/set/ /lib/isabelle/set/
/lib/isabelle/ROOT
/lib/isabelle/Why3_BV.thy
/lib/isabelle/Why3_Number.thy /lib/isabelle/Why3_Number.thy
/lib/isabelle/Why3_Real.thy /lib/isabelle/Why3_Real.thy
/lib/isabelle/Why3_Set.thy
/lib/isabelle/why3.ML /lib/isabelle/why3.ML
/lib/isabelle/last_build /lib/isabelle/last_build
/lib/isabelle/bv /lib/isabelle/bv
...@@ -1261,7 +1261,7 @@ clean:: ...@@ -1261,7 +1261,7 @@ clean::
ISABELLEVERSIONSPECIFIC=ROOT why3.ML Why3_BV.thy Why3_Number.thy Why3_Real.thy Why3_Set.thy ISABELLEVERSIONSPECIFIC=why3.ML Why3_Number.thy Why3_Real.thy
ISABELLEVERSIONSPECIFICTARGETS=$(addprefix lib/isabelle/, $(ISABELLEVERSIONSPECIFIC)) ISABELLEVERSIONSPECIFICTARGETS=$(addprefix lib/isabelle/, $(ISABELLEVERSIONSPECIFIC))
ISABELLEVERSIONSPECIFICSOURCES=$(addsuffix .@ISABELLEVERSION@, $(ISABELLEVERSIONSPECIFICTARGETS)) ISABELLEVERSIONSPECIFICSOURCES=$(addsuffix .@ISABELLEVERSION@, $(ISABELLEVERSIONSPECIFICTARGETS))
...@@ -744,7 +744,7 @@ fi ...@@ -744,7 +744,7 @@ fi
# Default version used for generation of realization in the case Isabelle is not # Default version used for generation of realization in the case Isabelle is not
# detected or Why3 is compiled with disable-isabelle. # detected or Why3 is compiled with disable-isabelle.
ISABELLEVERSION=2017 ISABELLEVERSION=2018
if test "$enable_isabelle_libs" = no; then if test "$enable_isabelle_libs" = no; then
enable_isabelle_support=no enable_isabelle_support=no
...@@ -760,9 +760,9 @@ else ...@@ -760,9 +760,9 @@ else
ISABELLEDETECTEDVERSION=[`$ISABELLE version | sed -n -e 's|Isabelle\([^:]*\).*$|\1|p'`] ISABELLEDETECTEDVERSION=[`$ISABELLE version | sed -n -e 's|Isabelle\([^:]*\).*$|\1|p'`]
case $ISABELLEDETECTEDVERSION in case $ISABELLEDETECTEDVERSION in
2016-1*) 2018*)
enable_isabelle_support=yes enable_isabelle_support=yes
ISABELLEVERSION=2016-1 ISABELLEVERSION=2018
AC_MSG_RESULT($ISABELLEDETECTEDVERSION) AC_MSG_RESULT($ISABELLEDETECTEDVERSION)
2017*) 2017*)
...@@ -773,8 +773,8 @@ else ...@@ -773,8 +773,8 @@ else
AC_MSG_WARN(You need Isabelle 2016-1 or later; Isabelle discarded) AC_MSG_WARN(You need Isabelle 2017 or later; Isabelle discarded)
reason_isabelle_support=" (need version >= 2016-1)" reason_isabelle_support=" (need version >= 2017)"
esac esac
fi fi
...@@ -11,9 +11,9 @@ using ``Edit'' action in \texttt{why3 ide}. ...@@ -11,9 +11,9 @@ using ``Edit'' action in \texttt{why3 ide}.
\subsection{Installation} \subsection{Installation}
You need version Isabelle2016-1 or Isabelle2017. Former versions are not You need version Isabelle2017 or Isabelle2018. Former versions are not
supported. We assume below that your version is 2017, please replace supported. We assume below that your version is 2018, please replace
2017 by 2016-1 otherwise. 2018 by 2017 otherwise.
Isabelle must be installed before compiling \why. After compilation Isabelle must be installed before compiling \why. After compilation
and installation of \why, you must manually add the path and installation of \why, you must manually add the path
...@@ -22,7 +22,7 @@ and installation of \why, you must manually add the path ...@@ -22,7 +22,7 @@ and installation of \why, you must manually add the path
\end{verbatim} \end{verbatim}
into either the user file into either the user file
\begin{verbatim} \begin{verbatim}
.isabelle/Isabelle2017/etc/components .isabelle/Isabelle2018/etc/components
or the system-wide file or the system-wide file
theory number.Coprime
syntax predicate coprime "<app><const name=\"GCD.gcd_class.coprime\"/>%1%2</app>"
syntax predicate coprime "<app><const name=\"Rings.algebraic_semidom_class.coprime\"/>%1%2</app>"
...@@ -160,10 +160,6 @@ theory number.Prime ...@@ -160,10 +160,6 @@ theory number.Prime
syntax predicate prime "<app><const name=\"Factorial_Ring.normalization_semidom_class.prime\"/>%1</app>" syntax predicate prime "<app><const name=\"Factorial_Ring.normalization_semidom_class.prime\"/>%1</app>"
end end
theory algebra.Field theory algebra.Field
syntax function inv "<app><const name=\"Fields.inverse_class.inverse\"/>%1</app>" syntax function inv "<app><const name=\"Fields.inverse_class.inverse\"/>%1</app>"
syntax function (/) "<app><const name=\"Rings.divide_class.divide\"/>%1%2</app>" syntax function (/) "<app><const name=\"Rings.divide_class.divide\"/>%1%2</app>"
...@@ -7,3 +7,4 @@ filename "%t.xml" ...@@ -7,3 +7,4 @@ filename "%t.xml"
transformation "inline_trivial" transformation "inline_trivial"
import "isabelle-common.gen" import "isabelle-common.gen"
import "isabelle-2017.gen"
...@@ -8,6 +8,7 @@ transformation "inline_trivial" ...@@ -8,6 +8,7 @@ transformation "inline_trivial"
transformation "eliminate_builtin" transformation "eliminate_builtin"
transformation "simplify_trivial_quantification_in_goal" transformation "simplify_trivial_quantification_in_goal"
import "isabelle-2018.gen"
theory genealogy_Genealogy_Child_is_son_or_daughter_1 theory genealogy_Genealogy_Child_is_son_or_daughter_1
imports Why3 imports Why3.Why3
begin begin
why3_open "genealogy_Genealogy_Child_is_son_or_daughter_1.xml" why3_open "genealogy_Genealogy_Child_is_son_or_daughter_1.xml"
theory genealogy_Genealogy_Grandparent_is_grandfather_or_grandmother_1 theory genealogy_Genealogy_Grandparent_is_grandfather_or_grandmother_1
begin begin
why3_open "genealogy_Genealogy_Grandparent_is_grandfather_or_grandmother_1.xml" why3_open "genealogy_Genealogy_Grandparent_is_grandfather_or_grandmother_1.xml"
theory genealogy_Genealogy_Sibling_is_brother_or_sister_1 theory genealogy_Genealogy_Sibling_is_brother_or_sister_1
begin begin
why3_open "genealogy_Genealogy_Sibling_is_brother_or_sister_1.xml" why3_open "genealogy_Genealogy_Sibling_is_brother_or_sister_1.xml"
theory genealogy_Genealogy_Sibling_sym_1 theory genealogy_Genealogy_Sibling_sym_1
begin begin
why3_open "genealogy_Genealogy_Sibling_sym_1.xml" why3_open "genealogy_Genealogy_Sibling_sym_1.xml"
...@@ -32,7 +32,7 @@ ...@@ -32,7 +32,7 @@
<prover id="27" name="Eprover" version="2.0" timelimit="5" steplimit="0" memlimit="1000"/> <prover id="27" name="Eprover" version="2.0" timelimit="5" steplimit="0" memlimit="1000"/>
<prover id="28" name="Z3" version="4.4.1" timelimit="5" steplimit="1" memlimit="4000"/> <prover id="28" name="Z3" version="4.4.1" timelimit="5" steplimit="1" memlimit="4000"/>
<prover id="29" name="Alt-Ergo" version="1.30" timelimit="1" steplimit="0" memlimit="1000"/> <prover id="29" name="Alt-Ergo" version="1.30" timelimit="1" steplimit="0" memlimit="1000"/>
<prover id="30" name="Isabelle" version="2016-1" timelimit="100" steplimit="1" memlimit="1000"/> <prover id="30" name="Isabelle" version="2018" timelimit="100" steplimit="1" memlimit="4000"/>
<prover id="31" name="CVC4" version="1.5" timelimit="1" steplimit="0" memlimit="1000"/> <prover id="31" name="CVC4" version="1.5" timelimit="1" steplimit="0" memlimit="1000"/>
<prover id="32" name="Alt-Ergo" version="2.2.0" timelimit="1" steplimit="0" memlimit="1000"/> <prover id="32" name="Alt-Ergo" version="2.2.0" timelimit="1" steplimit="0" memlimit="1000"/>
<prover id="33" name="Z3" version="4.6.0" timelimit="1" steplimit="0" memlimit="1000"/> <prover id="33" name="Z3" version="4.6.0" timelimit="1" steplimit="0" memlimit="1000"/>
chapter Why3
session Why3 = "HOL-Word" +
options [document = false]
theories Why3
...@@ -34,7 +34,7 @@ function make_theory() ...@@ -34,7 +34,7 @@ function make_theory()
BNAME=`basename "$1"` BNAME=`basename "$1"`
if [ ! -e "$1.thy" ]; then if [ ! -e "$1.thy" ]; then
echo -e "theory $BNAME\nimports Why3\nbegin\n\nwhy3_open \"$BNAME.xml\"\n" > "$1.thy" echo -e "theory $BNAME\nimports Why3.Why3\nbegin\n\nwhy3_open \"$BNAME.xml\"\n" > "$1.thy"
sed \ sed \
-e 's/<lemma name="\([^"]*\)"[^>]*>/why3_vc \1\n\n/g' \ -e 's/<lemma name="\([^"]*\)"[^>]*>/why3_vc \1\n\n/g' \
-e 's/<[^l][^>]*>//g' \ -e 's/<[^l][^>]*>//g' \
This diff is collapsed.
theory Why3_Number theory Why3_Number
imports imports
Why3_Int Why3_Int
"~~/src/HOL/Number_Theory/Primes" "HOL-Computational_Algebra.Primes"
begin begin
section {* Parity properties *} section {* Parity properties *}
...@@ -108,7 +108,7 @@ why3_vc even_divides .. ...@@ -108,7 +108,7 @@ why3_vc even_divides ..
why3_vc odd_divides .. why3_vc odd_divides ..
why3_vc divides_spec why3_vc divides_spec
by (metis divides_factorl dvd_div_mult_self) by (metis divides_factorl dvd_div_mult_self)
why3_end why3_end
...@@ -140,17 +140,17 @@ why3_vc gcd_opp by simp ...@@ -140,17 +140,17 @@ why3_vc gcd_opp by simp
why3_vc gcd_euclid why3_vc gcd_euclid
using gcd_add_mult [of a "- q" b] using gcd_add_mult [of a "- q" b]
by (simp add: sign_simps) by (simp add: algebra_simps)
why3_vc Gcd_computer_mod why3_vc Gcd_computer_mod
using assms gcd_add_mult [of b "- 1" "a mod b"] using assms gcd_add_mult [of b "- 1" "a mod b"]
by (simp add: cmod_def zabs_def gcd_red_int [symmetric] sgn_if sign_simps del: gcd_mod2) by (simp add: cmod_def zabs_def gcd_red_int [symmetric] sgn_if algebra_simps del: gcd_mod_right)
(simp add: zmod_zminus2_eq_if gcd_red_int [of a b] del: gcd_mod2) (simp add: zmod_zminus2_eq_if gcd_red_int [of a b] del: gcd_mod_right)
why3_vc Gcd_euclidean_mod why3_vc Gcd_euclidean_mod
by (simp add: emod_def zabs_def gcd_red_int [symmetric] sign_simps del: gcd_mod2) by (simp add: emod_def zabs_def gcd_red_int [symmetric] algebra_simps del: gcd_mod_right)
why3_vc gcd_mult using assms why3_vc gcd_mult using assms
by (simp add: gcd_mult_distrib_int [symmetric]) by (simp add: gcd_mult_distrib_int [symmetric])
...@@ -224,12 +224,12 @@ proof ...@@ -224,12 +224,12 @@ proof
assume "n dvd p" assume "n dvd p"
with `1 < n \<and> n < p` with `1 < n \<and> n < p`
have "1 < nat n" "nat n < nat p" "nat n dvd nat p" have "1 < nat n" "nat n < nat p" "nat n dvd nat p"
by (simp_all add: transfer_nat_int_relations) by (simp_all add: nat_dvd_iff)
then have "\<exists>d. prime d \<and> d * d \<le> nat p \<and> d dvd (nat p)" then have "\<exists>d. prime d \<and> d * d \<le> nat p \<and> d dvd (nat p)"
by (rule small_divisors_aux) by (rule small_divisors_aux)
with `2 \<le> p` obtain d with `2 \<le> p` obtain d
where d: "prime (int d)" "int d * int d \<le> p" "int d dvd p" where d: "prime (int d)" "int d * int d \<le> p" "int d dvd p"
by (auto simp add: int_dvd_iff le_nat_iff) by (auto simp add: int_dvd_int_iff [symmetric] le_nat_iff)
from `prime (int d)` have "2 \<le> int d" by (simp add: prime_ge_2_int) from `prime (int d)` have "2 \<le> int d" by (simp add: prime_ge_2_int)
then have "2 \<le> int d" by simp then have "2 \<le> int d" by simp
with `2 \<le> int d` have "2 * 2 \<le> int d * int d" with `2 \<le> int d` have "2 * 2 \<le> int d * int d"
...@@ -261,7 +261,7 @@ section {* Coprime numbers *} ...@@ -261,7 +261,7 @@ section {* Coprime numbers *}
why3_open "number/Coprime.xml" why3_open "number/Coprime.xml"
why3_vc coprime_def .. why3_vc coprime_def by (rule coprime_iff_gcd_eq_1)
why3_vc prime_coprime why3_vc prime_coprime
proof - proof -
...@@ -287,7 +287,7 @@ proof - ...@@ -287,7 +287,7 @@ proof -
qed qed
then show "coprime n p" then show "coprime n p"
by (auto simp add: coprime_int) by (auto simp add: coprime_iff_gcd_eq_1)
qed qed
next next
assume H: "\<forall>n. 1 \<le> n \<and> n < p \<longrightarrow> coprime n p" assume H: "\<forall>n. 1 \<le> n \<and> n < p \<longrightarrow> coprime n p"
...@@ -297,7 +297,7 @@ proof - ...@@ -297,7 +297,7 @@ proof -
assume H': "1 < n \<and> n < p" "n dvd p" assume H': "1 < n \<and> n < p" "n dvd p"
then have "1 \<le> n \<and> n < p" by simp then have "1 \<le> n \<and> n < p" by simp
with H have "coprime n p" by simp with H have "coprime n p" by simp
with H' show False by (simp add: coprime_int) with H' show False by (simp add: coprime_iff_gcd_eq_1)
qed qed
qed qed
then show ?thesis by (simp add: prime_def) then show ?thesis by (simp add: prime_def)
...@@ -307,7 +307,7 @@ why3_vc Gauss ...@@ -307,7 +307,7 @@ why3_vc Gauss
proof - proof -
from assms from assms
have "coprime a b" "a dvd c * b" by (simp_all add: mult.commute) have "coprime a b" "a dvd c * b" by (simp_all add: mult.commute)
then show ?thesis by (rule coprime_dvd_mult) then show ?thesis by (simp add: coprime_dvd_mult_left_iff)
qed qed
why3_vc Euclid why3_vc Euclid
...@@ -317,8 +317,8 @@ why3_vc Euclid ...@@ -317,8 +317,8 @@ why3_vc Euclid
why3_vc gcd_coprime why3_vc gcd_coprime
proof - proof -
have "gcd a (b * c) = gcd (b * c) a" by (simp add: gcd.commute) have "gcd a (b * c) = gcd (b * c) a" by (simp add: gcd.commute)
also from assms have "coprime b a" by (simp add: gcd.commute) also from assms have "coprime a b" by (simp add: gcd.commute coprime_iff_gcd_eq_1)
then have "gcd (b * c) a = gcd c a" by (simp add: gcd_mult_cancel) then have "gcd (b * c) a = gcd c a" by (simp add: gcd_mult_left_left_cancel)
finally show ?thesis by (simp add: gcd.commute) finally show ?thesis by (simp add: gcd.commute)
qed qed
theory Why3_Real theory Why3_Real
imports Complex_Main "~~/src/HOL/Decision_Procs/Approximation" Why3_Setup imports
Why3_Setup
Complex_Main
"HOL-Decision_Procs.Approximation"
begin begin
section {* Real numbers and the basic unary and binary operators *} section {* Real numbers and the basic unary and binary operators *}
...@@ -22,7 +25,7 @@ why3_vc Comm by simp ...@@ -22,7 +25,7 @@ why3_vc Comm by simp
why3_vc Assoc1 by simp why3_vc Assoc1 by simp
why3_vc Mul_distr_l by (simp add: Fields.linordered_field_class.sign_simps) why3_vc Mul_distr_l by (simp add: algebra_simps)
why3_vc Mul_distr_r by (simp add: Rings.comm_semiring_class.distrib) why3_vc Mul_distr_r by (simp add: Rings.comm_semiring_class.distrib)
theory Why3_Set
imports Why3_Setup Why3_Map "~~/src/HOL/Library/FSet"
begin
section {* Potentially infinite sets *}
definition choose_elt :: "('a \<Rightarrow> bool) \<Rightarrow> 'a" where
"choose_elt S = (\<some>x. S x)"
definition complement :: "('a \<Rightarrow> bool) \<Rightarrow> 'a \<Rightarrow> bool" where
"complement S v = Not (S v)"
why3_open "set/Set.xml"
constants
empty = bot
add = insert
remove = Set.remove
union = sup
inter = inf
diff = minus
complement = complement
choose = choose_elt
all = top
why3_vc add_spec by (auto simp add: mem_def)
why3_vc diff_def by simp
why3_vc diff_spec by (simp add: mem_def)
why3_vc inter_def by simp
why3_vc mem_empty by (simp add: const_def mem_def set.Set.is_empty_def)
why3_vc union_def by simp
why3_vc add_remove
using assms
by (simp add: fun_upd_idem_iff mem_def)
why3_vc inter_spec by (simp add: mem_def)
why3_vc remove_add by auto
why3_vc union_spec
why3_vc choose_spec
by (metis assms choose_elt_def mem_def set.Set.is_empty_def tfl_some)
why3_vc remove_spec
why3_vc subset_diff
by (simp add: diff_spec subset_def)
why3_vc subset_refl
by (simp add: subset_def)
why3_vc subset_trans
by (meson H1 H2 subset_def)
why3_vc subset_remove
by (simp add: remove_spec subset_def)
why3_vc complement_def
by (simp add: complement_def)
why3_vc extensionality
using assms
by (auto simp add: infix_eqeq_def mem_def)
why3_end
section {* Finite sets *}
definition fremove :: "'a \<Rightarrow> 'a fset \<Rightarrow> 'a fset" where
"fremove x A = A - {|x|}"
definition fchoose :: "'a fset \<Rightarrow> 'a" where
"fchoose S = (\<some>x. x |\<in>| S)"
definition ext_eq :: "'a fset \<Rightarrow> 'a fset \<Rightarrow> bool" where
"ext_eq S1 S2 = (S1 = S2)"
definition is_empty :: "'a fset \<Rightarrow> bool" where
"is_empty S = (S = fempty)"
why3_open "set/Fset.xml"
constants
mem = fmember
empty = bot
add = finsert
remove = fremove
union = sup
inter = inf
diff = minus
choose = fchoose
all = top
infix_eqeq = ext_eq
subset = fsubset_eq
is_empty = is_empty
types
set = fset
why3_vc add_spec by simp
why3_vc add_remove
using assms
by (auto simp add: fremove_def)
why3_vc remove_add by (simp add: fremove_def)
why3_vc empty_def by (simp add: is_empty_def)
why3_vc inter_spec by simp
why3_vc union_spec by simp
why3_vc remove_spec by (auto simp add: fremove_def)
why3_vc subset_diff by auto
why3_vc subset_refl by simp
using assms
by simp
why3_vc subset_remove by (auto simp add: fremove_def)
why3_vc subset_eq
using assms ext_eq_def fcard_seteq by fastforce
why3_vc subset_spec by auto
why3_vc infix_eqeq_spec
by (metis ext_eq_def fsubset_antisym subset_spec)
using assms
by (auto simp add: ext_eq_def)
why3_vc cardinal1
proof (cases s rule: fset_strong_cases)
case 1
with assms
show ?thesis by (simp add: fcard_fempty)
next
case (2 s' x)
show ?thesis
proof (cases s' rule: fset_strong_cases)
case 1
with `s = finsert x s'` assms
show ?thesis by (simp add: fchoose_def)
next
case (2 s'' y)
show ?thesis by (auto simp add: fcard_finsert_if fchoose_def
split: if_split_asm)
qed
qed
why3_vc cardinal_add
using assms
by (simp add: fcard_finsert_disjoint)
why3_vc cardinal_empty by (simp add: is_empty_def)
why3_vc cardinal_nonneg by simp
why3_vc cardinal_remove
proof -
from assms
have "1 \<le> fcard s"
by (cases s rule: fset_strong_cases)
(auto simp add: fcard_finsert_disjoint)
with assms show ?thesis
qed
why3_vc cardinal_subset
using assms
by (simp add: fcard_mono)
why3_vc diff_spec by simp
why3_vc choose_spec
using assms
using Why3_Set.is_empty_def
by (metis (full_types) ex_fin_conv fchoose_def someI_ex)
why3_vc is_empty_spec
by (simp add: Why3_Set.is_empty_def)
why3_end
...@@ -20,7 +20,7 @@ da4b981eb0a086bafef4994a856470521dc76f3a real/PowerInt.xml ...@@ -20,7 +20,7 @@ da4b981eb0a086bafef4994a856470521dc76f3a real/PowerInt.xml
7543f13d887b95912e75f4286bb897ce6fa1c2a1 number/Gcd.xml 7543f13d887b95912e75f4286bb897ce6fa1c2a1 number/Gcd.xml
d009220356ef6e55d1b92a43cec115ec1400b8e1 number/Parity.xml d009220356ef6e55d1b92a43cec115ec1400b8e1 number/Parity.xml
cf7bb9cfeed1b1dbb9ce5ed909508e24684ea7cb number/Prime.xml cf7bb9cfeed1b1dbb9ce5ed909508e24684ea7cb number/Prime.xml
c65c034efcb501c5828bc93ccd8ea479c0b096f1 number/Coprime.xml d6303a372876fe72982dcfbff168c8e8566bb439 number/Coprime.xml
017b0bfd1148c566644b949d9d0eecd6dbae7b2b set/Set.xml 017b0bfd1148c566644b949d9d0eecd6dbae7b2b set/Set.xml
01b883e67d69549f63707ce4ebfc3a2d3e474876 set/Fset.xml 01b883e67d69549f63707ce4ebfc3a2d3e474876 set/Fset.xml
6cf45ce21a7f543a525d4ad16344d5646fc5cb59 map/Map.xml 6cf45ce21a7f543a525d4ad16344d5646fc5cb59 map/Map.xml
...@@ -713,8 +713,8 @@ fun add_axioms s [t] = ...@@ -713,8 +713,8 @@ fun add_axioms s [t] =
fold_map Specification.axiom fold_map Specification.axiom
(map_index (fn (i, t) => (map_index (fn (i, t) =>
((fact_binding (s ^ "_" ^ string_of_int (i + 1)), []), t)) ts) #> ((fact_binding (s ^ "_" ^ string_of_int (i + 1)), []), t)) ts) #>
apfst (pair (fact_binding s)) #> apfst (pair (fact_binding s) #> rpair [] #> single) #>
uncurry Global_Theory.store_thms #> snd; uncurry Global_Theory.add_thmss #> snd;
fun dest_record thy [((s, _), args, [((cname, _), cargs)])] = fun dest_record thy [((s, _), args, [((cna
