Commit 9e698189 authored by Clément Fumex's avatar Clément Fumex
add session_itp.ml
parent 46a498a5
open Stdlib
module Hprover = Whyconf.Hprover
let debug = Debug.register_info_flag "session_itp"
~desc:"Pring@ debugging@ messages@ about@ Why3@ session@ \
creation,@ reading@ and@ writing."
type transID = int
type proofNodeID = int
type proof_parent = Trans of transID | Theory of Theory.theory
type proof_attempt = {
prover : Whyconf.prover;
timelimit : int;
memlimit : int;
stepslimit : int;
proof_state : Call_provers.prover_result option; (* None means that the call was not done
or never returned *)
proof_obsolete : bool;
proof_script : string option; (* non empty for external ITP *)
type proof_attempt_node = {
proofa_parent : proofNodeID;
proofa_attempt : proof_attempt;
type proof_node = {
proofn_task : Task.task;
proofn_parent : proof_parent;
proofn_attempts : proof_attempt_node Hprover.t;
mutable proofn_transformations : transID list;
type trans_arg =
| TAint of int
| TAstring of string
| TAterm of Term.term
| TAty of Ty.ty
| TAtysymbol of Ty.tysymbol
type transformation_node = {
transf_name : string;
transf_args : trans_arg list;
transf_subtasks : proofNodeID list;
transf_parent : proofNodeID;
type theory = {
theory_name : Ident.ident;
theory_checksum : Termcode.checksum option;
theory_goals : proofNodeID list;
type file = {
file_name : string;
file_format : string option;
file_theories : theory list;
type session = {
task_table : proof_node Hint.t;
mutable next_proofNodeID : int;
trans_table : transformation_node Hint.t;
mutable next_transID : int;
session_files : file Hstr.t;
mutable session_shape_version : int;
session_prover_ids : int Hprover.t;
session_file_name : string;
let gen_transID (s : session) =
let id = s.next_transID in
s.next_transID <- id + 1;
id
let gen_proofNodeID (s : session) =
let id = s.next_proofNodeID in
s.next_proofNodeID <- id + 1;
id
let empty_session ?shape_version (file : string) =
let shape_version = match shape_version with
| Some v -> v
| None -> Termcode.current_shape_version
in
{ task_table = Hint.create 97;
next_proofNodeID = 0;
trans_table = Hint.create 97;
next_transID = 0;
session_files = Hstr.create 3;
session_shape_version = shape_version;
session_prover_ids = Hprover.create 7;
session_file_name = file;
exception BadID
let graft_proof_attempt (s : session) (id : proofNodeID) (pa : proof_attempt) =
try
let pn = Hint.find s.task_table id in
let node = { proofa_parent = id; proofa_attempt = pa } in
Hprover.replace pn.proofn_attempts pa.prover node
with Not_found -> raise BadID
let mk_proof_node (s : session) (tid : int) (t : Task.task) =
let id = gen_proofNodeID s in
let pn = { proofn_task = t; proofn_parent = Trans tid;
proofn_attempts = Hprover.create 3;
proofn_transformations = []} in
Hint.add s.task_table id pn;
id
let graft_transf (s : session) (id : proofNodeID) (name : string) (l : trans_arg list) (tl : Task.task list) =
try
let tid = gen_transID s in
let sub_tasks = List.map (mk_proof_node s tid) tl in
let tn = { transf_name = name;
transf_args = l;
transf_subtasks = sub_tasks;
transf_parent = id; } in
Hint.replace s.trans_table tid tn;
pn.proofn_transformations <- tid::pn.proofn_transformations
(* saving state on disk *)
open Format
let db_filename = "why3session.xml"
let shape_filename = "why3shapes"
let compressed_shape_filename = "why3shapes.gz"
let session_dir_for_save = ref "."
let save_string = Pp.html_string
(* session opening *)
exception LoadError of Xml.element * string
(** LoadError (xml,messg) *)
exception SessionFileError of string
let bool_attribute field r def =
try
match List.assoc field r.Xml.attributes with
| "true" -> true
| "false" -> false
| _ -> assert false
with Not_found -> def
let int_attribute_def field r def =
try
int_of_string (List.assoc field r.Xml.attributes)
with Not_found | Invalid_argument _ -> def
let int_attribute field r =
try
(* TODO: use real error *)
eprintf "[Error] missing required attribute '%s' from element '%s'@."
field r.Xml.name;
assert false
let string_attribute_def field r def=
try
let string_attribute_opt field r =
try
Some (List.assoc field r.Xml.attributes)
with Not_found -> None
let string_attribute field r =
try
with Not_found ->
field r.Xml.name;
assert false
let load_result r =
match r.Xml.name with
| "result" ->
let status = string_attribute "status" r in
let answer =
match status with
| "valid" -> Call_provers.Valid
| "invalid" -> Call_provers.Invalid
| "unknown" -> Call_provers.Unknown ("", None)
| "timeout" -> Call_provers.Timeout
| "outofmemory" -> Call_provers.OutOfMemory
| "failure" -> Call_provers.Failure ""
| "highfailure" -> Call_provers.HighFailure
| "steplimitexceeded" -> Call_provers.StepLimitExceeded
| "stepslimitexceeded" -> Call_provers.StepLimitExceeded
| s ->
Warning.emit
"[Warning] Session.load_result: unexpected status '%s'@." s;
in
let time =
try float_of_string (List.assoc "time" r.Xml.attributes)
with Not_found -> 0.0
in
let steps =
try int_of_string (List.assoc "steps" r.Xml.attributes)
with Not_found -> -1
in
Some {
Call_provers.pr_answer = answer;
Call_provers.pr_time = time;
Call_provers.pr_output = "";
Call_provers.pr_status = Unix.WEXITED 0;
Call_provers.pr_steps = steps;
Call_provers.pr_model = Model_parser.default_model;
| "undone" -> None
| "unedited" -> None
| s ->
Warning.emit "[Warning] Session.load_result: unexpected element '%s'@."
s;
None
let load_option attr g =
try Some (List.assoc attr g.Xml.attributes)
let load_ident elt =
let name = string_attribute "name" elt in
let label = List.fold_left
(fun acc label ->
match label with
| {Xml.name = "label"} ->
let lab = string_attribute "name" label in
Ident.Slab.add (Ident.create_label lab) acc
| _ -> acc
) Ident.Slab.empty elt.Xml.elements in
let preid =
try
let load_exn attr g = List.assoc attr g.Xml.attributes in
let file = load_exn "locfile" elt in
let lnum = int_of_string (load_exn "loclnum" elt) in
let cnumb = int_of_string (load_exn "loccnumb" elt) in
let cnume = int_of_string (load_exn "loccnume" elt) in
let pos = Loc.user_position file lnum cnumb cnume in
Ident.id_user ~label name pos
Ident.id_fresh ~label name in
Ident.id_register preid
type load_ctxt = {
old_provers : (Whyconf.prover * int * int * int) Mint.t ;
let read_file_session_and_shapes dir xml_filename =
try
Filename.concat dir compressed_shape_filename
in
if Sys.file_exists compressed_shape_filename then
(* if Compress.compression_supported then
Session.ReadShapesCompress.read_xml_and_shapes
xml_filename compressed_shape_filename
else *)
begin
Warning.emit "[Warning] could not read goal shapes because \
Why3 was not compiled with compress support@.";
Xml.from_file xml_filename, false
else
let shape_filename = Filename.concat dir shape_filename in
(* if Sys.file_exists shape_filename then
ReadShapesNoCompress.read_xml_and_shapes xml_filename shape_filename
else*)
begin
Warning.emit "[Warning] could not find goal shapes file@.";
with e ->
Warning.emit "[Warning] failed to read goal shapes: %s@."
(Printexc.to_string e);
let load_file session old_provers f = old_provers
(* match f.Xml.name with
| "file" ->
let ctxt = { old_provers = old_provers ; keygen = keygen } in
let fn = string_attribute "name" f in
let fmt = load_option "format" f in
let expanded = bool_attribute "expanded" f false in
let mf = raw_add_file ~keygen:ctxt.keygen ~expanded session fn fmt in
mf.file_theories <-
List.rev
(List.fold_left
(load_theory ctxt mf) [] f.Xml.elements);
mf.file_verified <- file_verified mf;
old_provers
| "prover" ->
(* The id is just for the session file *)
let id = string_attribute "id" f in
begin
try
let id = int_of_string id in
let name = string_attribute "name" f in
let version = string_attribute "version" f in
let altern = string_attribute_def "alternative" f "" in
let timelimit = int_attribute_def "timelimit" f 5 in
let steplimit = int_attribute_def "steplimit" f 1 in
let memlimit = int_attribute_def "memlimit" f 1000 in
let p = {C.prover_name = name;
prover_version = version;
prover_altern = altern} in
Mint.add id (p,timelimit,steplimit,memlimit) old_provers
with Failure _ ->
Warning.emit "[Warning] Session.load_file: unexpected non-numeric prover id '%s'@." id;
old_provers
| s ->
Warning.emit "[Warning] Session.load_file: unexpected element '%s'@." s;
old_provers
let build_session (s : session) xml =
match xml.Xml.name with
| "why3session" ->
let shape_version = int_attribute_def "shape_version" xml 1 in
s.session_shape_version <- shape_version;
Debug.dprintf debug "[Info] load_session: shape version is %d@\n" shape_version;
(* just to keep the old_provers somewhere *)
let old_provers =
List.fold_left (load_file s) Mint.empty xml.Xml.elements
in
Mint.iter
(fun id (p,_,_,_) ->
Debug.dprintf debug "prover %d: %a@." id Whyconf.print_prover p;
Hprover.replace s.session_prover_ids p id)
old_provers;
Debug.dprintf debug "[Info] load_session: done@\n"
| s ->
Warning.emit "[Warning] Session.load_session: unexpected element '%s'@."
s
let load_session (file : string) =
let session = empty_session file in
let use_shapes =
(* If the xml is present we read it, otherwise we consider it empty *)
if Sys.file_exists file then
try
Termcode.reset_dict ();
let dir = Filename.dirname file in
let xml,use_shapes = read_file_session_and_shapes dir file in
try
build_session session xml.Xml.content;
use_shapes
with Sys_error msg ->
failwith ("Open session: sys error " ^ msg)
| Sys_error msg ->
(* xml does not exist yet *)
raise (SessionFileError msg)
| Xml.Parse_error s ->
Warning.emit "XML database corrupted, ignored (%s)@." s;
raise (SessionFileError "XML corrupted")
else false
in
session, use_shapes
