Commit 9e1326ec authored by MARCHE Claude's avatar MARCHE Claude
fix a comment
parent 4b810a5b
...@@ -99,7 +99,7 @@ and decl_node = private ...@@ -99,7 +99,7 @@ and decl_node = private
| Dtype of tysymbol (** abstract types and aliases *) | Dtype of tysymbol (** abstract types and aliases *)
| Ddata of data_decl list (** recursive algebraic types *) | Ddata of data_decl list (** recursive algebraic types *)
| Dparam of lsymbol (** abstract functions and predicates *) | Dparam of lsymbol (** abstract functions and predicates *)
| Dlogic of logic_decl list (** recursive functions and predicates *) | Dlogic of logic_decl list (** defined functions and predicates (possibly recursively) *)
| Dind of ind_list (** (co)inductive predicates *) | Dind of ind_list (** (co)inductive predicates *)
| Dprop of prop_decl (** axiom / lemma / goal *) | Dprop of prop_decl (** axiom / lemma / goal *)
...@@ -198,4 +198,3 @@ val make_record_update : ...@@ -198,4 +198,3 @@ val make_record_update :
val make_record_pattern : val make_record_pattern :
known_map -> (lsymbol * pattern) list -> ty -> pattern known_map -> (lsymbol * pattern) list -> ty -> pattern
