Commit 9d9770f8 authored by Andrei Paskevich's avatar Andrei Paskevich
Discriminate: provide direct get_syntax_map
parent 66d82e9f
......@@ -367,21 +367,30 @@ let () =
discriminate_if_poly
~desc:"Same@ as@ discriminate@ but@ only@ if@ polymorphism@ appear."
let li_add_ls acc = function
| [MAls ls; MAls nls] -> Mls.add nls ls acc
| _ -> assert false
let get_lsinst task =
Task.on_meta meta_lsinst li_add_ls Mls.empty task
let on_lsinst fn =
let add_ls acc = function
| _ -> assert false in
Trans.on_meta meta_lsinst (fun dls ->
fn (List.fold_left add_ls Mls.empty dls))
fn (List.fold_left li_add_ls Mls.empty dls))
let sm_add_ls sm0 sm = function
begin match Mid.find_opt ls.ls_name sm0 with
| Some s -> Mid.add nls.ls_name s sm
| None -> sm
| _ -> assert false
let get_syntax_map task =
let sm0 = Printer.get_syntax_map task in
Task.on_meta meta_lsinst (sm_add_ls sm0) sm0 task
let on_syntax_map fn =
let add_ls sm0 sm = function
| None -> sm
Printer.on_syntax_map (fun sm0 ->
fn (List.fold_left (fun sm dl -> add_ls sm0 sm dl) sm0 dls)))
fn (List.fold_left (sm_add_ls sm0) sm0 dls)))
......@@ -23,5 +23,8 @@ val ft_select_inst : (Env.env,Ty.Sty.t) Trans.flag_trans
val ft_select_lskept : (Env.env,Term.Sls.t) Trans.flag_trans
val ft_select_lsinst : (Env.env,Lsmap.t) Trans.flag_trans
val get_lsinst : Task.task -> Term.lsymbol Term.Mls.t
val get_syntax_map : Task.task -> Printer.syntax_map
val on_lsinst : (Term.lsymbol Term.Mls.t -> 'a Trans.trans) -> 'a Trans.trans
val on_syntax_map : (Printer.syntax_map -> 'a Trans.trans) -> 'a Trans.trans
