Commit 9b6d889c authored by David Hauzar's avatar David Hauzar
Transformation that for each declared abstract function and predicate
p labeled with label "model_projected" for that it exists a projection
function f creates declaration of new constant c and axiom stating that
c = f p
Projection functions are functions tagged with meta "model_projection".
Function f is projection function for abstract function and predicate p
if f is tagged with meta "model_projection" and has a single argument
of the same type as is the type of p.
This transformation is needed in situations when we want to display not
value of a variable, but value of a projection function applied to a variable.
Note that since Why3 supports namespaces (different projection functions
can have the same name) and input languages of solvers typically not,
Why3 renames projection functions to avoid name clashes.
This is why it is not possible to just store the name of the projection
function in a label and than query the solver directly for the value of
the projection.
Also, it means that this transformation should thus be executed before
this renaming.
parent ede14c73
...@@ -159,7 +159,7 @@ LIB_TRANSFORM = simplify_formula inlining split_goal induction \ ...@@ -159,7 +159,7 @@ LIB_TRANSFORM = simplify_formula inlining split_goal induction \
encoding_guards encoding_tags encoding_twin \ encoding_guards encoding_tags encoding_twin \
encoding_sort simplify_array filter_trigger \ encoding_sort simplify_array filter_trigger \
introduction abstraction close_epsilon lift_epsilon \ introduction abstraction close_epsilon lift_epsilon \
eliminate_epsilon \ eliminate_epsilon intro_projections_counterexmp \
eval_match instantiate_predicate smoke_detector \ eval_match instantiate_predicate smoke_detector \
reduction_engine compute induction_pr prop_curry reduction_engine compute induction_pr prop_curry
(* The Why3 Verification Platform / The Why3 Development Team *)
(* Copyright 2010-2015 -- INRIA - CNRS - Paris-Sud University *)
(* This software is distributed under the terms of the GNU Lesser *)
(* General Public License version 2.1, with the special exception *)
(* on linking described in file LICENSE. *)
open Ident
open Term
open Decl
(* Debugging functions *)
let debug = Debug.register_info_flag "intro_projections_counterexmp"
~desc:"Print@ debugging@ messages@ about@ introducing@ projections@ for@ counterexamples."
let rec debug_print_terms terms =
match terms with
| term::tail ->
Pretty.print_term Format.str_formatter term;
debug_print_terms tail
let debug_decl decl =
Pretty.print_decl Format.str_formatter decl;
let s = Format.flush_str_formatter () in
Debug.dprintf debug "Declaration %s @." s
(* Label for terms that should be in counterexample *)
let label_model = Ident.create_label "model"
(* Label for terms that should be projected in counterexample *)
let label_model_proj = Ident.create_label "model_projected"
(* Meta to tag projection functions *)
let meta_projection = Theory.register_meta "model_projection" [Theory.MTlsymbol]
~desc:"Declares@ the@ projection."
let intro_proj_for_ls map_projs ls_projected =
(* Returns list of declarations for projection of ls_projected
if it has a label "model_projected", otherwise returns [].
The declarations include:
- declaration of new constant with labels of ls_projected
and label "model"
- declaration of axiom saying that the new constant is equal to
ls_projected projected by its projection function
The projection function for ls_declared is stored in map_projs
with key ls_projected.ls_value
if not (Slab.mem label_model_proj ls_projected.ls_name.id_label) then
else
match ls_projected.ls_value with
| None -> []
| Some ty_projected ->
let create_proj_decls ls_projection =
(* Creates declarations for projection of ls_projected using
projection function ls_projection. *)
(* Create the projection *)
let t_projected = Term.t_app ls_projected [] ls_projected.ls_value in
let t_projection = Term.t_app ls_projection [t_projected] ls_projection.ls_value in
(* Create declaration of new constant *)
let name_new_constant = ls_projected.ls_name.id_string^"_proj_constant" in
let lab_new = Slab.add label_model Slab.empty in
let id_new = Ident.id_derive ~label:lab_new name_new_constant ls_projected.ls_name in
let ls_new_constant = Term.create_lsymbol id_new [] ls_projection.ls_value in
let decl_new_constant = Decl.create_param_decl ls_new_constant in
let t_new_constant = Term.t_app ls_new_constant [] ls_projection.ls_value in
(* Create the declaration of the axiom about the constant: t_new_constant = t_projection *)
let name_axiom = ls_projected.ls_name.id_string^"_proj_axiom" in
let id_axiom = Decl.create_prsymbol (Ident.id_fresh name_axiom) in
let fla_axiom = Term.t_equ t_new_constant t_projection in
let decl_axiom = Decl.create_prop_decl Decl.Paxiom id_axiom fla_axiom in
(* Add the declaration of new constant and the axiom *)
decl_new_constant::decl_axiom::[]
in
try
let ls_proj = Ty.Mty.find ty_projected map_projs in
with Not_found -> []
let introduce_projs map_projs decl =
match decl.d_node with
| Dparam ls_projected ->
(* Create declarations for a projection of ls_projected *)
let projection_decls = intro_proj_for_ls map_projs ls_projected in
decl::projection_decls
(* TODO
| Dlogic lslist ->
debug_decl decl;
let new_decls = List.fold_left (fun list (ls,_) -> list @ (intro_proj_for_ls map_projs ls)) [] lslist in
(* TODO *)
[decl]
| _ -> [decl]
let build_projections_map projs =
(* Build map from types (Ty.ty) to projections (Term.lsymbol).
The type t maps to the projection function f if f has a single
argument of the type t.
let build_map ls_proj proj_map =
match ls_proj.ls_args with
| [ty_proj_arg] ->
Ty.Mty.add ty_proj_arg ls_proj proj_map
| _ -> assert false
in
Sls.fold build_map projs Ty.Mty.empty
let meta_transform2 projs =
let map_projs = build_projections_map projs in
Trans.decl (introduce_projs map_projs) None
let intro_projections_counterexmp = Trans.on_tagged_ls meta_projection meta_transform2
let () = Trans.register_transform "intro_projections_counterexmp" intro_projections_counterexmp
~desc:"Introduce@ new@ constant@ symbol@ for@ every@ term@ with@ model@ \
label@ that@ has@ the@ same@ type@ as@ an@ argument@ of@ some@ function@ \
labeled@ with@ meta@ model_projectionin@ the@ goal."
Local Variables:
compile-command: "unset LANG; make -C ../.. byte"
End:
val intro_projections_counterexmp : Task.task Trans.trans
(** [intros G f] returns the declarations after introducing
new constant symbol for every term with model label that has the
same type as an argument of some function labeled with meta
model_projection in the goal [goal G : f] *)
