Commit 9a615c12 authored by François Bobot's avatar François Bobot
encoding_arrays use builtin arrays in smtv1 extended
parent cfeddc81
......@@ -130,6 +130,7 @@ LIB_TRANSFORM = simplify_recursive_definition simplify_formula \
libencoding encoding_decorate encoding_bridge \
encoding_explicit encoding_sort \
encoding_instantiate simplify_array filter_trigger \
encoding_arrays \
introduction abstraction close_epsilon lift_epsilon
LIB_PRINTER = print_real alt_ergo why3 smt coq tptp simplify gappa
......@@ -20,6 +20,8 @@ transformation "eliminate_algebraic"
transformation "simplify_formula"
transformation "simplify_trivial_quantification"
transformation "encoding_array"
transformation "encoding_smt"
transformation "encoding_sort"
......@@ -129,6 +131,11 @@ theory int.EuclideanDivision
remove prop Div_1
theory transform.array.Array
syntax logic get "(select %1 %2)"
syntax logic get "(store %1 %2)"
Local Variables:
mode: why
......@@ -25,10 +25,17 @@ open Ident
open Ty
open Term
open Decl
open Theory
open Task
open Printer
let ident_printer =
(** Options of this printer *)
let use_trigger = Theory.register_meta_excl "Smt : trigger" []
let use_builtin_array = Theory.register_meta_excl "Smt : builtin array" []
let ident_printer =
let bls = ["and";" benchmark";" distinct";"exists";"false";"flet";"forall";
"if then else";"iff";"implies";"ite";"let";"logic";"not";"or";
"sat";"theory";"true";"unknown";"unsat";"xor";
......@@ -52,6 +59,8 @@ let print_var fmt {vs_name = id} =
type info = {
info_syn : string Mid.t;
info_rem : Sid.t;
use_trigger : bool;
barrays : (ty*ty) Mts.t;
let rec print_type info fmt ty = match ty.ty_node with
......@@ -155,7 +164,13 @@ let print_logic_binder info fmt v =
let print_type_decl info fmt = function
| ts, Tabstract when Sid.mem ts.ts_name info.info_rem -> false
| ts, Tabstract when ts.ts_args = [] ->
fprintf fmt ":extrasorts (%a)" print_ident ts.ts_name; true
begin try
let key,elt = Mts.find ts info.barrays in
fprintf fmt ":define_sorts ((%a (array %a %a)))"
(print_type info) key (print_type info) elt; true
with Not_found ->
fprintf fmt ":extrasorts (%a)" print_ident ts.ts_name; true end
| _, Tabstract -> unsupported
"smtv1 : type with argument are not supported"
| _, Talgebraic _ -> unsupported
......@@ -205,6 +220,21 @@ let print_decl info fmt d = match d.d_node with
let print_decl info fmt = catch_unsupportedDecl (print_decl info fmt)
let barrays task =
let sds = find_meta task Encoding_arrays.meta_mono_array in
let fold tdecl barrays =
match tdecl.td_node with
| Meta (_,[MAts tst;MAts tsk;MAts tse]) ->
let extract_ty ts =
if ts.ts_args <> [] then
unsupported "smtv1 : type with argument are not supported";
match ts.ts_def with
| Some ty -> ty
| None -> ty_app ts [] in
Mts.add tst (extract_ty tsk,extract_ty tse) barrays
| _ -> barrays in
Stdecl.fold fold sds.tds_set Mts.empty
let print_task pr thpr fmt task =
fprintf fmt "(benchmark why3@\n"
(*print_ident (Task.task_goal task).pr_name*);
......@@ -213,7 +243,10 @@ let print_task pr thpr fmt task =
print_th_prelude task fmt thpr;
let info = {
info_syn = get_syntax_map task;
info_rem = get_remove_set task }
info_rem = get_remove_set task;
use_trigger = false;
barrays = barrays task;
in
let decls = Task.task_decls task in
ignore (print_list_opt (add_flush newline2) (print_decl info) fmt decls);
(* Copyright (C) 2010- *)
(* Francois Bobot *)
(* Jean-Christophe Filliatre *)
(* Johannes Kanig *)
(* Andrei Paskevich *)
(* This software is free software; you can redistribute it and/or *)
(* modify it under the terms of the GNU Library General Public *)
(* License version 2.1, with the special exception on linking *)
(* described in file LICENSE. *)
(* This software is distributed in the hope that it will be useful, *)
(* but WITHOUT ANY WARRANTY; without even the implied warranty of *)
(* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. *)
open Util
open Ident
open Ty
open Term
open Task
open Theory
open Task
open Decl
open Encoding
(* Ce type est utiliser pour indiquer un underscore *)
let tv_dumb = create_tvsymbol (id_fresh "Dumb")
let ty_dumb = ty_var tv_dumb
(* TODO : transmettre les tags des logiques polymorphe vers les logiques
instantié. Un tag sur un logique polymorphe doit être un tag sur toute
la famille de fonctions *)
module OHTy = OrderedHash(struct
type t = ty
let tag = ty_hash
end)
module OHTyl = OrderedHashList(struct
type t = ty
let tag = ty_hash
end)
module Mtyl = Map.Make(OHTyl)
module Htyl = Hashtbl.Make(OHTyl)
(* The environnement of the transformation between two decl (* unmutable *) *)
type env = {
keep : ty Mty.t;
poly_ts : tysymbol;
edefined_lsymbol : lsymbol Mtyl.t Mls.t;
(* The environnement of the transformation during
the transformation of a formula *)
type menv = {
env : env;
mutable defined_lsymbol : lsymbol Mtyl.t Mls.t;
mutable undef_lsymbol : Sls.t;
let print_env fmt menv =
Format.fprintf fmt "defined_lsymbol (%a)@."
(Pp.print_iter2 Mls.iter Pp.semi Pp.comma Pretty.print_ls
(Pp.print_iter2 Mtyl.iter Pp.semi Pp.arrow
(Pp.print_list Pp.space Pretty.print_ty)
Pretty.print_ls)) menv.defined_lsymbol
(* let create_arrays th = *)
(* theory = th; *)
(* get = ns_find_ls th.th_export ["get"]; *)
(* set = ns_find_ls th.th_export ["set"]; *)
(* t = ty_app (ns_find_ts th.th_export ["t"]) []; *)
(* key = ty_app (ns_find_ts th.th_export ["key"]) []; *)
(* value = ty_app (ns_find_ts th.th_export ["value"]) []; *)
let find_arrays menv ty =
(* try *)
Mty.find ty menv.arrays
(* with Not_found when Sty.mem ty menv.keep -> *)
(* let key,value = *)
(* match ty.ty_node with *)
(* | Tyapp (_,[key;value]) -> key,value *)
(* | _ -> assert false in *)
(* let th_uc = create_theory (id_clone menv.clonable_theory.th_name) in *)
(* (\* temporary tsymbol *\) *)
(* let th_inst = create_inst ~ts:[menv.clonable_key,key; *)
(* menv.clonable_value,value] ~ls:[] *)
(* ~lemma:[] ~goal:[] in *)
(* let th_uc = clone_export th_uc menv.clonable th_inst in *)
(* let th = close_theory th_uc in *)
(* let arrays = create_arrays th in *)
(* menv.arrays <- Mty.add ty arrays menv.arrays; *)
(* menv.undef_arrays <- Sty.add ty menv.undef_arrays; *)
(* arrays *)
let projty menv ty = Mty.find_default ty ty menv.env.keep
let conv_vs menv tvar vsvar vs =
let ty = projty menv (ty_inst tvar vs.vs_ty) in
let vs' = if ty_equal ty vs.vs_ty then vs else
create_vsymbol (id_clone vs.vs_name) ty in
Mvs.add vs (t_var vs') vsvar,vs'
(* Weakmemo only on the symbols *)
let clone_lsymbol p arg result = create_lsymbol (id_clone p.ls_name) arg result
let find_logic menv tvar p tl tyv =
if ls_equal p ps_equ then p else begin
(** project the type on : keep + {dumb} *)
let to_dumb {t_ty = ty} =
let ty = ty_inst tvar ty in
Mty.find_default ty ty_dumb menv.env.keep in
let inst_l = List.map to_dumb tl in
let inst_tyv = option_map to_dumb tyv in
let inst_l_tyv = option_apply inst_l (fun e -> e::inst_l) inst_tyv in
(* Format.eprintf "env : %ap : %a | arg : %a| tyl = %a | inst_l : %a@." *)
(* print_env menv *)
(* Pretty.print_ls p *)
(* (Pp.print_list Pp.comma Pretty.print_ty) p.ls_args *)
(* (Pp.print_list Pp.comma Pretty.print_ty) *)
(* (List.map (fun t -> ty_inst tvar t.t_ty) tl) *)
(* (Pp.print_list Pp.comma Pretty.print_ty) inst_l_tyv; *)
try
let insts = Mls.find p menv.defined_lsymbol in
Mtyl.find inst_l_tyv insts
with Not_found ->
let insts = Mls.find_default p Mtyl.empty menv.defined_lsymbol in
let to_new tyd ty = if ty_equal tyd ty_dumb then ty else tyd in
let arg = List.map2 to_new inst_l p.ls_args in
let value = option_map2 to_new inst_tyv p.ls_value in
let ls = if List.for_all2 ty_equal arg p.ls_args &&
option_eq ty_equal value p.ls_value
then p else clone_lsymbol p arg value in
let insts = Mtyl.add inst_l_tyv ls insts in
menv.defined_lsymbol <- Mls.add p insts menv.defined_lsymbol;
menv.undef_lsymbol <- Sls.add ls menv.undef_lsymbol;
ls
(* The convertion of term and formula *)
let rec rewrite_term menv tvar vsvar t =
let fnT = rewrite_term menv tvar in
let fnF = rewrite_fmla menv tvar in
(* Format.eprintf "@[<hov 2>Term : %a =>@\n@?" Pretty.print_term t; *)
let t = match t.t_node with
| Tconst _ -> t
| Tvar x -> Mvs.find x vsvar
| Tapp(p,tl) ->
let tl' = List.map (fnT vsvar) tl in
let p = find_logic menv tvar p tl (Some t) in
t_app p tl' (projty menv (ty_inst tvar t.t_ty))
| Tif(f, t1, t2) ->
t_if (fnF vsvar f) (fnT vsvar t1) (fnT vsvar t2)
| Tlet (t1, b) -> let u,t2,cb = t_open_bound_cb b in
let (vsvar',u) = conv_vs menv tvar vsvar u in
let t1 = fnT vsvar t1 in let t2 = fnT vsvar' t2 in
t_let t1 (cb u t2)
| Tcase _ | Teps _ | Tbvar _ ->
Printer.unsupportedTerm t
"Encoding instantiate : I can't encode this term" in
(* Format.eprintf "@[<hov 2>Term : => %a : %a@\n@?" *)
(* Pretty.print_term t Pretty.print_ty t.t_ty; *)
t
and rewrite_fmla menv tvar vsvar f =
(* Format.eprintf "@[<hov 2>Fmla : %a =>@\n@?" Pretty.print_fmla f; *)
match f.f_node with
| Fapp(p, tl) ->
let p = find_logic menv tvar p tl None in
f_app p tl'
| Fquant(q, b) ->
let vl, tl, f1, cb = f_open_quant_cb b in
let vsvar,vl = map_fold_left (conv_vs menv tvar) vsvar vl in
let f1 = fnF vsvar f1 in
(* Ici un trigger qui ne match pas assez de variables
peut être généré *)
let tl = tr_map (fnT vsvar) (fnF vsvar) tl in
let vl = List.rev vl in
f_quant q (cb vl tl f1)
| Flet (t1, b) -> let u,f2,cb = f_open_bound_cb b in
let t1 = fnT vsvar t1 and f2 = fnF vsvar' f2 in
(* Format.eprintf "u.vs_ty : %a == t1.t_ty : %a@." *)
(* Pretty.print_ty u.vs_ty Pretty.print_ty t1.t_ty; *)
assert (u.vs_ty == t1.t_ty);
f_let t1 (cb u f2)
| _ -> f_map (fun _ -> assert false) (fnF vsvar) f
module Ssubst =
Set.Make(struct type t = ty Mtv.t
let compare = Mtv.compare OHTy.compare end)
(* Generation of all the possible instantiation of a formula *)
let gen_tvar su =
(* Try to apply one subst on all the other subst generated until then
(ie. in su), that give newly generated subst (ie to put in su)*)
let aux subst su =
(* filter the possible application of substitution *)
let disj_union m1 m2 = Mtv.union (fun _ ty1 ty2 ->
if ty_equal ty1 ty2 then Some ty1 else raise Exit) m1 m2 in
let fold subst1 acc =
try Ssubst.add (disj_union subst1 subst) acc with Exit -> acc in
Ssubst.fold fold su su in
Ssubst.fold aux su (Ssubst.singleton (Mtv.empty))
let ty_quant env =
let rec add_vs s ty =
let s = ty_fold add_vs s ty in
| Tyapp(app,_) when ts_equal app env.poly_ts ->
Mty.fold (fun uty _ s -> Ssubst.add (ty_match Mtv.empty ty uty) s)
env.keep s
| _ -> s in
f_fold_ty add_vs Ssubst.empty
(* The Core of the transformation *)
let fold_map task_hd ((env:env),task) =
match task_hd.task_decl.td_node with
| Use _ | Clone _ | Meta _ -> env,add_tdecl task task_hd.task_decl
| Decl d -> match d.d_node with
| Dtype [_,Tabstract] -> (env,task)
(* Nothing here since the type kept are already defined and the other
will be lazily defined *)
| Dtype _ -> Printer.unsupportedDecl
d "encoding_decorate : I can work only on abstract\
type which are not in recursive bloc."
| Dlogic l ->
let fn = function
| _, Some _ ->
d "encoding_decorate : I can't encode definition. \
Perhaps you could use eliminate_definition"
| _, None -> () in
(* Noting here since the logics are lazily defined *)
List.iter fn l; (env,task)
| Dind _ -> Printer.unsupportedDecl
d "encoding_decorate : I can't work on inductive"
(* let fn (pr,f) = pr, fnF f in *)
(* let fn (ps,l) = ps, List.map fn l in *)
(* [create_ind_decl (List.map fn l)] *)
| Dprop (k,pr,f) ->
let tvl = ty_quant env f in
let tvarl = gen_tvar tvl in
let tvarl_len = Ssubst.cardinal tvarl in
let menv = {
env = env;
defined_lsymbol = env.edefined_lsymbol;
undef_lsymbol = Sls.empty;
} in
let conv_f tvar task =
(* Format.eprintf "f0 : %a@. env : %a@." Pretty.print_fmla *)
(* (f_ty_subst tvar Mvs.empty f) *)
(* print_env menv; *)
let f = rewrite_fmla menv tvar Mvs.empty f in
(* Format.eprintf "f : %a@. env : %a@." Pretty.print_fmla f *)
let pr =
if tvarl_len = 1 then pr
else create_prsymbol (id_clone pr.pr_name) in
(* Format.eprintf "undef ls : %a, ts : %a@." *)
(* (Pp.print_iter1 Sls.iter Pp.comma Pretty.print_ls) *)
(* menv.undef_lsymbol *)
(* (Pp.print_iter1 Sts.iter Pp.comma Pretty.print_ts) *)
(* menv.undef_tsymbol; *)
let task = Sls.fold
(fun ls task -> add_logic_decl task [ls,None])
menv.undef_lsymbol task in
let task = add_prop_decl task k pr f in
task
in
let task = Ssubst.fold conv_f tvarl task in
{env with edefined_lsymbol = menv.defined_lsymbol}, task
let ty_all_quant =
let rec add_vs s ty = match ty.ty_node with
| Tyvar vs -> Stv.add vs s
| _ -> ty_fold add_vs s ty in
f_fold_ty add_vs Stv.empty
let monomorphise_goal =
Trans.goal (fun pr f ->
let stv = ty_all_quant f in
let mty,ltv = Stv.fold (fun tv (mty,ltv) ->
let ts = create_tysymbol (id_clone tv.tv_name) [] None in
Mtv.add tv (ty_app ts []) mty,ts::ltv) stv (Mtv.empty,[]) in
let f = f_ty_subst mty Mvs.empty f in
let acc = [create_prop_decl Pgoal pr f] in
let acc = List.fold_left
(fun acc ts -> (create_ty_decl [ts,Tabstract]) :: acc)
acc ltv in
acc)
let meta_kept_array = register_meta "encoding : kept_array" [MTtysymbol]
let collect_arrays poly_ts tds =
let extract ts tys =
assert (ts.ts_args = []); (* UnsupportedTySymbol : TODO *)
Mty.add (match ts.ts_def with
| None -> Printer.unsupportedType (ty_app ts [])
"Encoding_arrays : apply only on alias for array"
| Some ({ty_node = Tyapp (app,_)} as ty)
when not (ts_equal app poly_ts) ->
Printer.unsupportedType ty "Encoding_arrays : apply only on array"
| Some ty -> ty)
ts tys in
Sts.fold extract tds Mty.empty
let meta_mono_array = register_meta "encoding_arrays : mono_arrays"
[MTtysymbol;MTtysymbol;MTtysymbol]
(* Some general env creation function *)
let create_env env task thpoly tds =
let pget = ns_find_ls thpoly.th_export ["get"] in
let pset = ns_find_ls thpoly.th_export ["set"] in
let pt = ns_find_ts thpoly.th_export ["t"] in
(* let pkey = ns_find_ts thpoly.th_export ["key"] in *)
(* let pvalue = ns_find_ts thpoly.th_export ["value"] in *)
(* Clonable theories of arrays *)
let thclone = Env.find_theory env ["transform";"array"] "Array" in
let cget = ns_find_ls thclone.th_export ["get"] in
let cset = ns_find_ls thclone.th_export ["set"] in
let ct = ns_find_ts thclone.th_export ["t"] in
let ckey = ns_find_ts thclone.th_export ["key"] in
let celt = ns_find_ts thclone.th_export ["elt"] in
let clone_arrays ty _ (task,lsdefined) =
let key,elt =
| Tyapp (_,[key;elt]) -> key,elt
(** create needed alias for the instantiation *)
let add_ty task ty =
| Tyapp (ts,[]) -> task,ts
| _ ->
let ts = create_tysymbol (id_fresh "alias for clone") [] (Some ty) in
add_ty_decl task [ts,Tabstract],ts in
let task,tskey = add_ty task key in
let task,tselt = add_ty task elt in
let ts_name = "bta_"^(Pp.string_of Pretty.print_ty ty) in
let ts = create_tysymbol (id_fresh ts_name) [] None in
let task = add_ty_decl task [ts,Tabstract] in
let th_inst = create_inst ~ts:[ct,ts; ckey,tskey; celt,tselt] ~ls:[]
let task = Task.clone_export task thclone th_inst in
(** Recover the subtitution *)
let sls = match task with
| Some {task_decl = {td_node = Clone(_,{sm_ls=sls})}} -> sls
(** type *)
let tsy = ty_app ts [] in
(** add get to lsdefined *)
(** Warning result is the first element *)
let add s = Mtyl.add [ty_dumb;tsy;ty_dumb] (Mls.find cget sls) s in
let lsdefined = Mls.change pget
(function | None -> Some (add Mtyl.empty) | Some s -> Some (add s))
lsdefined in
(** add set to lsdefined *)
let add s = Mtyl.add [tsy;tsy;ty_dumb;ty_dumb] (Mls.find cset sls) s in
let lsdefined = Mls.change pset
lsdefined in
((task,lsdefined),tsy) in
(** Collect the arrays and the theory cloned *)
let keep = collect_arrays pt tds in
(** add the type which compose keep *)
let task = Mty.fold (fun ty _ task ->
let add_ts task ts = add_ty_decl task [ts,Tabstract] in
let task = ty_s_fold add_ts task ty in
(* let task = add_ts task ts in *)
task (* the meta is yet here *)) keep task in
let (task,lsdefined),keep = Mty.mapi_fold clone_arrays keep (task,Mls.empty)
in task,{
keep = keep;
poly_ts = pt;
edefined_lsymbol = lsdefined;
let create_trans_complete env thpoly tds_kept =
let init_task = use_export None builtin_theory in
let init_task,env = create_env env init_task thpoly tds_kept in
Trans.fold_map fold_map env init_task
let encoding_arrays env =
let thpoly = Env.find_theory env ["array"] "Array" in
Trans.on_used_theory thpoly (fun used ->
if not used then Trans.identity
else Trans.on_tagged_ts meta_kept_array (create_trans_complete env thpoly))
(* This one take use the tag but also all the type which appear in the goal *)
let is_ty_mono ~only_mono ty =
try
let rec check () ty = match ty.ty_node with
| Tyvar _ -> raise Exit
| Tyapp _ -> ty_fold check () ty in
check () ty;
true
with Exit when not only_mono -> false
(* select the type array which appear as argument of set and get.
set and get must be in sls *)
let find_mono_array ~only_mono sls sty f =
let add sty ls tyl =
match tyl with
| ty::_ when Sls.mem ls sls && is_ty_mono ~only_mono ty ->
Sty.add ty sty
| _ -> sty in
f_fold_sig add sty f
let create_meta_ty ty =
let name = id_fresh "meta_ty" in
let ts = create_tysymbol name [] (Some ty) in
(create_meta meta_kept_array [MAts ts])
let create_meta_ty = Wty.memoize 17 create_meta_ty
let create_meta_tyl sty d =
Sty.fold (flip $ cons create_meta_ty) sty [create_decl d]
let mono_in_goal sls pr f =
let sty = (try find_mono_array ~only_mono:true sls Sty.empty f
with Exit -> assert false) (*monomorphise goal should have been used*) in
create_meta_tyl sty (create_prop_decl Pgoal pr f)
let mono_in_goal sls = Trans.tgoal (mono_in_goal sls)
let trans_array th_array =
let set = ns_find_ls th_array.th_export ["set"] in
let get = ns_find_ls th_array.th_export ["get"] in
let sls = Sls.add set (Sls.add get Sls.empty) in
mono_in_goal sls
let trans_array env =
let th_array = Env.find_theory env ["array"] "Array" in
Trans.on_used_theory th_array (fun used ->
if not used then Trans.identity else trans_array th_array
let trans_array env = Trans.compose (trans_array env) (encoding_arrays env)
let () = Trans.register_env_transform "encoding_array" trans_array
Local Variables:
compile-command: "unset LANG; make -j -C ../.. byte"
End:
val meta_mono_array : Theory.meta
......@@ -352,24 +352,6 @@ let conv_to_tty env ts tyl proj_ty =
else let args = ty_args_from_tty tyl in
(* Free type in terms and formulae *)
let rec t_fold_ty fty s t =
let s = t_fold (t_fold_ty fty) (f_fold_ty fty) s t in
let s = fty s t.t_ty in
match t.t_node with
| Teps fb ->
let vs,_ = f_open_bound fb in
fty s vs.vs_ty
| _ -> s
and f_fold_ty fty s f =
let s = f_fold (t_fold_ty fty) (f_fold_ty fty) s f in
match f.f_node with
| Fquant (_,fq) ->
let (vsl,_,_) = f_open_quant fq in
List.fold_left (fun s vs -> fty s vs.vs_ty) s vsl
| _ -> s
let ty_quant =
......@@ -533,7 +515,7 @@ let create_meta_ty ty =
