Commit 9951e364 authored by Clément Fumex's avatar Clément Fumex
correct mistake in big_float_is_int axiom
parent 9ab5761b
...@@ -653,7 +653,7 @@ theory GenericFloat ...@@ -653,7 +653,7 @@ theory GenericFloat
(** big floats are ints *) (** big floats are ints *)
axiom big_float_is_int: forall m i. axiom big_float_is_int: forall m i.
is_finite i -> is_finite i ->
(i .<= (of_int m (- max_representable_integer)) /\ (i .<= (of_int m (- max_representable_integer)) \/
(of_int m max_representable_integer) .<= i) -> (of_int m max_representable_integer) .<= i) ->
is_int i is_int i
Supports Markdown
