Commit 973f8b48 authored by Andrei Paskevich's avatar Andrei Paskevich
theories/map.why: remove Select_eq and Select_neq, subsumed by the definition
parent 578c2fca
...@@ -174,9 +174,6 @@ theory HighOrd ...@@ -174,9 +174,6 @@ theory HighOrd
end end
theory map.Map theory map.Map
syntax function get "(%1[%2])" syntax function get "(%1[%2])"
syntax function set "(%1[%2 <- %3])" syntax function set "(%1[%2 <- %3])"
remove prop Select_eq
remove prop Select_neq
end end
...@@ -32,16 +32,11 @@ theory HighOrd ...@@ -32,16 +32,11 @@ theory HighOrd
end end
syntax function get "%1(%2)"
syntax function ([]) "%1(%2)" syntax function ([]) "%1(%2)"
syntax function set "(%1 WITH [(%2) |-> %3])" syntax function set "(%1 WITH [(%2) |-> %3])"
syntax function ([<-]) "(%1 WITH [(%2) |-> %3])" syntax function ([<-]) "(%1 WITH [(%2) |-> %3])"
end end
theory Bool theory Bool
...@@ -161,11 +161,6 @@ theory map.Map ...@@ -161,11 +161,6 @@ theory map.Map
meta "encoding:ignore_polymorphism_ls" function ([]) meta "encoding:ignore_polymorphism_ls" function ([])
meta "encoding:ignore_polymorphism_ls" function set meta "encoding:ignore_polymorphism_ls" function set
meta "encoding:ignore_polymorphism_ls" function ([<-]) meta "encoding:ignore_polymorphism_ls" function ([<-])
meta "encoding:ignore_polymorphism_pr" prop Select_eq
meta "encoding:ignore_polymorphism_pr" prop Select_neq
end end
theory map.Const theory map.Const
...@@ -51,11 +51,6 @@ theory map.Map ...@@ -51,11 +51,6 @@ theory map.Map
end end
import "discrimination.gen" import "discrimination.gen"
...@@ -8,34 +8,15 @@ theory Map ...@@ -8,34 +8,15 @@ theory Map
type map 'a 'b = 'a -> 'b type map 'a 'b = 'a -> 'b
(* FIXME: add meta "material_type_arg" type func, 1 for (->) *)
(* FIXME: remove Select_eq, Select_neq, and Const ? *)
(* FIXME: we cannot remove the defining axiom for set in a driver. *)
(** if ['b] is an infinite type, then [map 'a 'b] is infinite *)
function get (f: map 'a 'b) (x: 'a) : 'b = f x function get (f: map 'a 'b) (x: 'a) : 'b = f x
function set (f: map 'a 'b) (x: 'a) (v: 'b) : map 'a 'b = function set (f: map 'a 'b) (x: 'a) (v: 'b) : map 'a 'b =
fun y -> if y = x then v else f y fun y -> if y = x then v else f y
(** syntactic sugar *) (** syntactic sugar *)
function ([]) (f: map 'a 'b) (x: 'a) : 'b = get f x function ([]) (f: map 'a 'b) (x: 'a) : 'b = f x
function ([<-]) (f: map 'a 'b) (x: 'a) (v: 'b) : map 'a 'b = set f x v function ([<-]) (f: map 'a 'b) (x: 'a) (v: 'b) : map 'a 'b = set f x v
lemma Select_eq :
forall m : map 'a 'b. forall a1 a2 : 'a.
forall b : 'b [m[a1 <- b][a2]].
a1 = a2 -> m[a1 <- b][a2] = b
lemma Select_neq :
a1 <> a2 -> m[a1 <- b][a2] = m[a2]
end end
theory Const theory Const
