Commit 95e8fba7 authored by Andrei Paskevich's avatar Andrei Paskevich
whyml: e_loop and e_for
parent 1b24d75d
......@@ -92,6 +92,14 @@ let create_plsymbol id args value =
pl_effect = effect;
let ity_of_ty_opt ty = ity_of_ty (Util.def_option ty_bool ty)
let fake_pls = Wls.memoize 17 (fun ls ->
{ pl_ls = ls;
pl_args = List.map (fun ty -> vty_value (ity_of_ty ty)) ls.ls_args;
pl_value = vty_value (ity_of_ty_opt ls.ls_value);
pl_effect = eff_empty })
(** specification *)
type pre = term (* precondition *)
......@@ -137,30 +145,28 @@ let varmap_union = Mid.set_union
let add_pv_vars pv m = Mid.add pv.pv_vs.vs_name pv.pv_vtv.vtv_vars m
let add_vs_vars vs m = add_pv_vars (restore_pv vs) m
let spec_vars varm variant pre post xpost _effect result =
(* sanity check *)
if pre.t_ty <> None then raise (FmlaExpected pre);
let check_post ity post =
let ty = ty_of_ity ity in
if not (ty_equal ty (t_type post)) then
raise (Ty.TypeMismatch (ty, t_type post))
in
begin match result with
| Some vtv -> check_post vtv.vtv_ity post
| None -> ()
(* FIXME? Should we check that the bound variable does not occur
in the postcondition formula when result is an arrow? *)
end;
(* FIXME? Should we check that every raised exception is in xpost? *)
Mexn.iter (fun xs t -> check_post xs.xs_ity t) xpost;
(* compute rec_vars and ps.ps_vars *)
let add_term t s = Mvs.set_union t.t_vars s in
let add_variant { v_term = t; v_rel = ps } s =
let fmla_vars f vsset =
if f.t_ty <> None then raise (FmlaExpected f);
Mvs.set_union vsset f.t_vars
let post_vars ity f vsset =
Ty.ty_equal_check (ty_of_ity ity) (t_type f);
let xpost_vars = Mexn.fold (fun xs -> post_vars xs.xs_ity)
let variant_vars varl vsset =
let add_variant s { v_term = t; v_rel = ps } =
ignore (Util.option_map (fun ps -> ps_app ps [t;t]) ps);
add_term t s in
let vsset = add_term post (add_term pre Mvs.empty) in
let vsset = Mexn.fold (fun _ -> add_term) xpost vsset in
let vsset = List.fold_right add_variant variant vsset in
Mvs.set_union s t.t_vars in
List.fold_left add_variant vsset varl
let vsset = fmla_vars pre Mvs.empty in
let vsset = post_vars result post vsset in
let vsset = xpost_vars xpost vsset in
let vsset = variant_vars variant vsset in
Mvs.fold (fun vs _ m -> add_vs_vars vs m) vsset varm
let spec_arrow pvl effect vty =
......@@ -174,8 +180,8 @@ let spec_arrow pvl effect vty =
let rec check_c tyc =
let varm = check_v tyc.c_result in
let result = match tyc.c_result with
| SpecV v -> Some v
| SpecA _ -> None in
| SpecV v -> v.vtv_ity
| SpecA _ -> ity_unit in
spec_vars varm [] tyc.c_pre tyc.c_post tyc.c_xpost tyc.c_effect result
and check_v = function
......@@ -283,16 +289,7 @@ let ppat_plapp pls ppl vtv =
ppat_vtv = vtv;
ppat_effect = if vtv.vtv_ghost then eff_ghostify eff else eff; }
let ppat_lapp ls ppl vtv =
let pls = {
pl_ls = ls;
pl_effect = eff_empty; }
in
let ppat_lapp ls ppl vtv = ppat_plapp (fake_pls ls) ppl vtv
let ppat_or p1 p2 =
ity_equal_check p1.ppat_vtv.vtv_ity p2.ppat_vtv.vtv_ity;
......@@ -411,6 +408,12 @@ let make_ppattern pp vtv =
type assertion_kind = Aassert | Aassume | Acheck
type for_direction = To | DownTo
type for_bounds = pvsymbol * for_direction * pvsymbol
type invariant = term option
type expr = {
e_node : expr_node;
e_vty : vty;
......@@ -432,6 +435,8 @@ and expr_node =
| Eassign of expr * region * pvsymbol
| Eghost of expr
| Eany of type_c
| Eloop of invariant * variant list * expr
| Efor of pvsymbol * for_bounds * invariant * expr
| Eraise of xsymbol * expr
| Etry of expr * (xsymbol * pvsymbol * expr) list
| Eassert of assertion_kind * term
......@@ -573,8 +578,8 @@ let e_app_real e pv =
let create_fun_defn id lam =
let e = lam.l_expr in
let result = match e.e_vty with
| VTvalue v -> Some v
| VTarrow _ -> None in
| VTvalue v -> v.vtv_ity
| VTarrow _ -> ity_unit in
let varm = spec_vars e.e_vars lam.l_variant
lam.l_pre lam.l_post lam.l_xpost e.e_effect result in
let del_pv m pv = Mid.remove pv.pv_vs.vs_name m in
......@@ -665,14 +670,7 @@ let e_plapp pls el ity =
let argl = List.rev el in
app [] Mid.empty false eff_empty ity_subst_empty vtvl argl
let e_lapp ls el ity =
let pls = {
pl_ls = ls;
in
e_plapp pls el ity
let e_lapp ls el ity = e_plapp (fake_pls ls) el ity
let e_void = e_lapp (fs_tuple 0) [] ity_unit
......@@ -813,6 +811,41 @@ let e_lazy_and e1 e2 =
let e_lazy_or e1 e2 =
if eff_is_empty e2.e_effect then e_binop Tor e1 e2 else e_if e1 e_true e2
let e_loop inv variant e =
let vtv = vtv_of_expr e in
ity_equal_check vtv.vtv_ity ity_unit;
let vsset = Util.option_fold (fun s f -> fmla_vars f s) Mvs.empty inv in
let vars = Mvs.fold (fun vs _ m -> add_vs_vars vs m) vsset e.e_vars in
check_postexpr e e.e_effect vars;
let vty = VTvalue (vtv_unmut vtv) in
mk_expr (Eloop (inv,variant,e)) vty e.e_effect vars
let e_for_real pv bounds inv e =
let pvfrom,_,pvto = bounds in
ity_equal_check pv.pv_vtv.vtv_ity ity_int;
ity_equal_check pvfrom.pv_vtv.vtv_ity ity_int;
ity_equal_check pvto.pv_vtv.vtv_ity ity_int;
let ghost = pv.pv_vtv.vtv_ghost || pvfrom.pv_vtv.vtv_ghost ||
pvto.pv_vtv.vtv_ghost || vtv.vtv_ghost in
let eff = if ghost then eff_ghostify e.e_effect else e.e_effect in
let vars = Util.option_fold (fun m f -> add_t_vars f m) e.e_vars inv in
(* FIXME? We check that no variable in the loop body, _including_
the index variable, is not invalidated because of a region reset.
We ignore the loop bounds, since they are computed just once. *)
check_postexpr e eff vars;
let vars = Mid.remove pv.pv_vs.vs_name vars in
let vars = add_pv_vars pvfrom (add_pv_vars pvto vars) in
let vty = VTvalue (vty_value ~ghost ity_unit) in
mk_expr (Efor (pv,bounds,inv,e)) vty eff vars
let e_for pv efrom dir eto inv e =
let apply pvto pvfrom = e_for_real pv (pvfrom,dir,pvto) inv e in
let apply pvto = on_value (apply pvto) efrom in
on_value apply eto
(* FIXME? We don't call check_postexpr to verify that raising
an exception is ok after the computation of e, because with
the current semantics of whyml it always is. However, this
......@@ -858,15 +891,15 @@ let e_try e0 bl =
in
branch vtv0.vtv_ghost eff_empty Mid.empty bl
let e_absurd ity =
let vty = VTvalue (vty_value ity) in
mk_expr Eabsurd vty eff_empty Mid.empty
let e_assert ak f =
let vars = add_t_vars f Mid.empty in
let vty = VTvalue (vty_value ity_unit) in
mk_expr (Eassert (ak, f)) vty eff_empty vars
let e_absurd ity =
(* Compute the fixpoint on recursive definitions *)
let vars_equal vs1 vs2 =
......@@ -934,6 +967,10 @@ let rec expr_subst psm e = match e.e_node with
| Etry (e,bl) ->
let branch (xs,pv,e) = xs, pv, expr_subst psm e in
e_try (expr_subst psm e) (List.map branch bl)
| Eloop (inv,var,e) ->
e_loop inv var (expr_subst psm e)
| Efor (pv,bounds,inv,e) ->
e_for_real pv bounds inv (expr_subst psm e)
| Elogic _ | Evalue _ | Earrow _ | Eany _ | Eabsurd | Eassert _ -> e
and create_rec_defn defl =
......@@ -145,6 +145,12 @@ val make_ppattern : pre_ppattern -> vty_value -> pvsymbol Mstr.t * ppattern
type expr = private {
e_node : expr_node;
e_vty : vty;
......@@ -166,6 +172,8 @@ and expr_node = private
| Eghost of expr
| Eany of type_c
......@@ -250,5 +258,10 @@ val e_not : expr -> expr
val e_raise : xsymbol -> expr -> ity -> expr
val e_try : expr -> (xsymbol * pvsymbol * expr) list -> expr
val e_absurd : ity -> expr
val e_loop : invariant -> variant list -> expr -> expr
val e_for :
pvsymbol -> expr -> for_direction -> expr -> invariant -> expr -> expr
val e_assert : assertion_kind -> term -> expr
......@@ -184,6 +184,22 @@ and print_type_c fmt tyc =
print_post tyc.c_post
(* TODO: print_xpost *)
let print_invariant fmt = function
| Some f -> fprintf fmt "invariant@ { %a }@ " Pretty.print_term f
| None -> ()
let print_variant fmt varl =
let print_rel fmt = function
| Some ps -> fprintf fmt "@ [%a]" Pretty.print_ls ps
| None -> () in
let print_var fmt { v_term = t; v_rel = ps } =
fprintf fmt " %a%a" Pretty.print_term t print_rel ps in
fprintf fmt "variant@ {%a }@ " (print_list comma print_var) varl
let print_variant fmt = function
| varl -> print_variant fmt varl
(* expressions *)
let print_ppat fmt ppat = print_pat fmt ppat.ppat_pattern
......@@ -265,6 +281,14 @@ and print_enode pri fmt e = match e.e_node with
| Ecase (e0,bl) ->
fprintf fmt "match %a with@\n@[<hov>%a@]@\nend"
print_expr e0 (print_list newline print_branch) bl
fprintf fmt "loop@ %a%a@\n@[<hov>%a@]@\nend"
print_invariant inv print_variant var print_expr e
| Efor (pv,(pvfrom,dir,pvto),inv,e) ->
fprintf fmt "for@ %a@ =@ %a@ %s@ %a@ %ado\n@[<hov>%a@]@\ndone"
print_pv pv print_pv pvfrom
(if dir = To then "to" else "downto") print_pv pvto
print_invariant inv print_expr e
| Eraise (xs,e) ->
fprintf fmt "raise (%a %a)" print_xs xs print_expr e
| Etry (e,bl) ->
......@@ -289,11 +313,12 @@ and print_xbranch fmt (xs, pv, e) =
and print_rec fst fmt { rec_ps = ps ; rec_lambda = lam } =
let print_arg fmt pv = fprintf fmt "(%a)" print_pvty pv in
fprintf fmt "@[<hov 2>%s (%a) %a =@ { %a }@ %a@ { %a }@]"
fprintf fmt "@[<hov 2>%s (%a) %a =@ { %a }@ %a%a@ { %a }@]"
(if fst then "let rec" else "with")
print_psty ps
(print_list space print_arg) lam.l_args
print_term lam.l_pre
print_variant lam.l_variant
print_expr lam.l_expr
print_post lam.l_post
......@@ -355,7 +380,7 @@ let print_data_decl fst fmt (ts,csl) =
forget_tvs_regs ()
let print_val_decl fmt { val_name = lv ; val_spec = tyv } =
fprintf fmt "@[<hov 2>val %a : @[%a@]@]" print_lv lv print_type_v tyv;
fprintf fmt "@[<hov 2>val (%a) : @[%a@]@]" print_lv lv print_type_v tyv;
(* FIXME: don't forget global regions *)
forget_tvs_regs ()
......@@ -587,6 +587,9 @@ let create_post lenv x ty f =
let create_pre lenv f =
Typing.type_fmla (get_theory lenv.mod_uc) lenv.log_denv lenv.log_vars f
let create_variant lenv t =
Typing.type_term (get_theory lenv.mod_uc) lenv.log_denv lenv.log_vars t
let add_local x lv lenv = match lv with
| LetA _ ->
{ lenv with let_vars = Mstr.add x lv lenv.let_vars }
......@@ -749,7 +752,7 @@ and expr_lam lenv (bl, var, p, e, q, xq) =
let ty = match e.e_vty with
| VTarrow _ -> ty_unit
| VTvalue vtv -> ty_of_ity vtv.vtv_ity in
let mk_variant (t,r) = { v_term = create_pre lenv t; v_rel = r } in
let mk_variant (t,r) = { v_term = create_variant lenv t; v_rel = r } in
{ l_args = pvl;
l_variant = List.map mk_variant var;
l_pre = create_pre lenv p;
......@@ -36,7 +36,7 @@ module N
val gr : ref int
let test () =
foo gr gr
foo gr {| contents = 4 |}
let myfun r = { r = r }
'L:
......@@ -44,7 +44,7 @@ module N
| Node {| contents = v |} f -> v + on_forest f
| Leaf -> raise (Exit Leaf)
end { at r 'L = t }
with on_forest f = match f with
with on_forest f variant { f } = match f with
| Cons t f -> let ee = Leaf in on_tree t + on_forest f + on_tree ee
| Nil -> 1
Supports Markdown
