Commit 95c6f628 authored by MARCHE Claude's avatar MARCHE Claude
feature wish #49 granted
config --detect now displays the known versions of provers
parent 76c4e1d4
...@@ -61,9 +61,9 @@ type prover_autodetection_data = ...@@ -61,9 +61,9 @@ type prover_autodetection_data =
execs : string list; execs : string list;
version_switch : string; version_switch : string;
version_regexp : string; version_regexp : string;
versions_ok : Str.regexp list; versions_ok : (string * Str.regexp) list;
versions_old : Str.regexp list; versions_old : (string * Str.regexp) list;
versions_bad : Str.regexp list; versions_bad : (string * Str.regexp) list;
(** If none it's a fake prover (very bad version) *) (** If none it's a fake prover (very bad version) *)
prover_command : string option; prover_command : string option;
prover_command_steps : string option; prover_command_steps : string option;
...@@ -84,7 +84,7 @@ let prover_keys = ...@@ -84,7 +84,7 @@ let prover_keys =
let load_prover kind (id,section) = let load_prover kind (id,section) =
check_exhaustive section prover_keys; check_exhaustive section prover_keys;
let reg_map = List.rev_map why3_regexp_of_string in let reg_map = List.rev_map (fun s -> (s,why3_regexp_of_string s)) in
let prover = { kind = kind; let prover = { kind = kind;
prover_id = id; prover_id = id;
prover_name = get_string section "name"; prover_name = get_string section "name";
...@@ -158,7 +158,7 @@ type env = ...@@ -158,7 +158,7 @@ type env =
unknown version (neither good or bad) unknown version (neither good or bad)
| None there is a good version *) | None there is a good version *)
prover_unknown_version : prover_unknown_version :
(int * string * config_prover) option Hstr.t; (prover_autodetection_data * int * string * config_prover) option Hstr.t;
(* string -> priority * prover *) (* string -> priority * prover *)
prover_shortcuts : (int * prover) Hstr.t; prover_shortcuts : (int * prover) Hstr.t;
mutable possible_prover_shortcuts : (filter_prover * string) list; mutable possible_prover_shortcuts : (filter_prover * string) list;
...@@ -254,15 +254,15 @@ let ask_prover_version env exec_name version_switch = ...@@ -254,15 +254,15 @@ let ask_prover_version env exec_name version_switch =
Hstr2.add env.prover_output (exec_name,version_switch) res; Hstr2.add env.prover_output (exec_name,version_switch) res;
res res
let check_version version schema = Str.string_match schema version 0 let check_version version (_,schema) = Str.string_match schema version 0
let known_version env exec_name = let known_version env exec_name =
Hstr.replace env.prover_unknown_version exec_name None Hstr.replace env.prover_unknown_version exec_name None
let unknown_version env exec_name prover_id prover_config priority = let unknown_version env exec_name prover_id prover_config data priority =
if not (Hstr.mem env.prover_unknown_version exec_name) if not (Hstr.mem env.prover_unknown_version exec_name)
then Hstr.replace env.prover_unknown_version exec_name then Hstr.replace env.prover_unknown_version exec_name
(Some (priority,prover_id,prover_config)) (Some (data,priority,prover_id,prover_config))
let empty_alt s = if s = "" then "alt" else s let empty_alt s = if s = "" then "alt" else s
...@@ -516,22 +516,29 @@ let detect_exec env data acc exec_name = ...@@ -516,22 +516,29 @@ let detect_exec env data acc exec_name =
if level > 0 then record_prover_for_auto_mode prover level; if level > 0 then record_prover_for_auto_mode prover level;
add_prover_with_uniq_id prover_config acc add_prover_with_uniq_id prover_config acc
end end
else (unknown_version env exec_name data.prover_id prover_config priority; else (unknown_version env exec_name data.prover_id prover_config data priority;
acc) acc)
let detect_prover env acc data = let detect_prover env acc data =
List.fold_left (detect_exec env data) acc data.execs List.fold_left (detect_exec env data) acc data.execs
let pp_versions =
Pp.print_list Pp.comma
(Pp.print_pair_delim Pp.nothing Pp.nothing Pp.nothing Pp.string Pp.nothing)
(** add the prover unknown *) (** add the prover unknown *)
let detect_unknown env detected = let detect_unknown env detected =
Hstr.fold (fun _ pc acc -> Hstr.fold (fun _ pc acc ->
match pc with match pc with
| None -> acc | None -> acc
| Some (priority,prover_id,prover_config) -> | Some (prover_data,priority,prover_id,prover_config) ->
let prover = prover_config.prover in let prover = prover_config.prover in
Warning.emit "Warning: prover %s version %s is not known to be \ Warning.emit "@[Prover %s version %s is not known to be supported.@\n\
supported.@." Known versions for this prover:@ %a@\n\
prover.Wc.prover_name prover.prover_version; Known old versions for this prover:@ %a@]@."
pp_versions prover_data.versions_ok
pp_versions prover_data.versions_old;
(* Pb: Even if it match the first prover section (normally (* Pb: Even if it match the first prover section (normally
highest priority) since it is unknown it has the lower highest priority) since it is unknown it has the lower
priority for its id as shortcut. Perhaps we don't want priority for its id as shortcut. Perhaps we don't want
...@@ -43,6 +43,8 @@ val print_pair_delim : ...@@ -43,6 +43,8 @@ val print_pair_delim :
(Format.formatter -> unit -> unit) -> (Format.formatter -> unit -> unit) ->
(Format.formatter -> 'a -> unit) -> (Format.formatter -> 'a -> unit) ->
(Format.formatter -> 'b -> unit) -> Format.formatter -> 'a * 'b -> unit (Format.formatter -> 'b -> unit) -> Format.formatter -> 'a * 'b -> unit
(** [print_pair_delim left_delim middle_delim right_delim] *)
val print_pair : val print_pair :
