Attention une mise à jour du serveur va être effectuée le vendredi 16 avril entre 12h et 12h30. Cette mise à jour va générer une interruption du service de quelques minutes.
Commit 94be8e9b authored by MARCHE Claude's avatar MARCHE Claude
editors and a simplify bug by andrei
parent eaeb5d85
......@@ -27,7 +27,7 @@ transformation "remove_triggers"
trigger they can't appear since = can't appear *)
(*transformation "filter_trigger_builtin"*)
transformation "encoding_tptp"
(* transformation "encoding_tptp" *)
theory BuiltIn
syntax logic (=) "(EQ %1 %2)"
......@@ -9,6 +9,7 @@ type prover_data =
command : string;
driver_name : string;
driver : Driver.driver;
mutable editor : string;
type t =
......@@ -20,6 +21,7 @@ type t =
mutable verbose : int;
mutable max_running_processes : int;
mutable provers : prover_data list;
mutable default_editor : string;
let default =
......@@ -31,6 +33,7 @@ let default =
verbose = 0;
max_running_processes = 2;
provers = [];
default_editor = "";
let conf_file = Filename.concat (Rc.get_home_dir ()) ".why.conf"
......@@ -41,6 +44,7 @@ let save_prover fmt p =
fprintf fmt "version = \"%s\"@\n" p.prover_version;
fprintf fmt "command = \"%s\"@\n" p.command;
fprintf fmt "driver = \"%s\"@\n" p.driver_name;
fprintf fmt "editor = \"%s\"@\n" p.editor;
fprintf fmt "@."
let save_config config =
......@@ -54,6 +58,7 @@ let save_config config =
fprintf fmt "time_limit = %d@\n" config.time_limit;
fprintf fmt "verbose = %d@\n" config.verbose;
fprintf fmt "max_processes = %d@\n" config.max_running_processes;
fprintf fmt "default_editor = \"%s\"@\n" config.default_editor;
fprintf fmt "@.";
List.iter (save_prover fmt) config.provers;
close_out ch
......@@ -67,12 +72,13 @@ let load_main c (key, value) =
| "time_limit" -> c.time_limit <- Rc.int value
| "verbose" -> c.verbose <- Rc.int value
| "max_processes" -> c.max_running_processes <- Rc.int value
| "default_editor" -> c.default_editor <- Rc.string value
| s ->
eprintf "Warning: ignore unknown key [%s] in whyide config file@." s
let get_prover_data env id name ver c d =
let get_prover_data env id name ver c d e =
try
let dr = Driver.load_driver env d in
{ prover_id = id ;
......@@ -81,6 +87,7 @@ let get_prover_data env id name ver c d =
command = c;
driver_name = d;
driver = dr;
editor = e;
with _e ->
eprintf "Failed to load driver %s for prover %s. prover disabled@."
......@@ -92,6 +99,7 @@ let load_prover env id l =
let v = ref "?" in
let c = ref "?" in
let d = ref "?" in
let e = ref "" in
List.iter
(fun (key, value) ->
match key with
......@@ -99,10 +107,11 @@ let load_prover env id l =
| "version" -> v := Rc.string value
| "command" -> c := Rc.string value
| "driver" -> d := Rc.string value
| "editor" -> e := Rc.string value
| s ->
eprintf "Warning: ignore unknown key [%s] in prover data of whyide config file@." s)
l;
get_prover_data env id !name !v !c !d
get_prover_data env id !name !v !c !d !e
let load env c (key, al) =
match key with
......@@ -430,7 +439,7 @@ let detect_prover env acc data =
incr provers_found;
let c = make_command com data.command in
get_prover_data env data.prover_id data.prover_name ver
c data.driver :: acc
c data.driver "" :: acc
else
begin
prover_tips_info := true;
......@@ -8,6 +8,7 @@ type prover_data =
command : string;
type t =
......@@ -19,6 +20,7 @@ type t =
val read_config : Env.env -> t
......@@ -836,7 +836,12 @@ let edit_selected_row p =
let callback () =
Helpers.set_proof_status a old_status;
in
Scheduler.edit_proof ~debug:false ~editor:"coqide"
let editor =
match a.Model.prover.editor with
| "" -> gconfig.default_editor
| _ -> a.Model.prover.editor
in
~file
~driver:a.Model.prover.driver
~callback
