Commit 94184291 authored by Jean-Christophe Filliâtre's avatar Jean-Christophe Filliâtre
a mere generalization
parent 1f163b68
......@@ -8,14 +8,15 @@ module Fill
use import int.Int
use import module array.Array
type tree = Null | Node tree int tree
type elt
type tree = Null | Node tree elt tree
predicate contains (t: tree) (x: int) = match t with
predicate contains (t: tree) (x: elt) = match t with
| Null -> false
| Node l y r -> contains l x || x = y || contains r x
let rec fill (t: tree) (a: array int) (start: int) : int =
let rec fill (t: tree) (a: array elt) (start: int) : int =
{ 0 <= start <= length a }
match t with
| Null ->
