Commit 93768735 authored by MARCHE Claude's avatar MARCHE Claude
atetmpt to fix bug in execute
parent 2491615d
module Test
use import ref.Ref
let foo () =
let (a1, a2) = (ref 0, ref 0) in
why3 execute execute.mlw Test.foo
...@@ -517,19 +517,35 @@ let rec to_program_value_rec env regions s ity ls vl = ...@@ -517,19 +517,35 @@ let rec to_program_value_rec env regions s ity ls vl =
(* absurd, it would be a pure type *) (* absurd, it would be a pure type *)
assert false assert false
let rec get_regions acc ity =
match ity.ity_node with
| Ityvar _ -> assert false
| Ityapp(_,ty,rl) ->
List.map (get_reg env) rl
| Itypur(ts,tl) ->
eprintf "@[<hov 2>error while fetching regions from value %a@ of type %a@]@."
print_value v Mlw_pretty.print_vty ty;
assert false
let to_program_value env s ty v = let to_program_value env s ty v =
match ty,v with match ty,v with
| VTarrow _, _ -> s,v | VTarrow _, _ -> s,v
| VTvalue ity,Vapp(ls,vl) -> | VTvalue ity,Vapp(ls,vl) ->
if ity_immutable ity then s,v else if ity_immutable ity then s,v else
begin begin
(* ls must be a constructor of a record with mutable fields *) let regions = [] in
let regions = (*
match ity.ity_node with match ity.ity_node with
| Ityapp(_,_,rl) -> | Ityapp(_,_,rl) ->
List.map (get_reg env) rl List.map (get_reg env) rl
| _ -> assert false | Ityvar _ -> assert false
| Itypur(ts,tl) ->
assert false
in in
let s,regions,v = to_program_value_rec env regions s ity ls vl in let s,regions,v = to_program_value_rec env regions s ity ls vl in
match regions with match regions with
| [] -> s,v | [] -> s,v
