Commit 9320bc9c authored by Clément Fumex's avatar Clément Fumex
add name to goal
parent dd787602
...@@ -34,6 +34,7 @@ type proof_attempt_node = { ...@@ -34,6 +34,7 @@ type proof_attempt_node = {
type proof_node = { type proof_node = {
proofn_name : Ident.ident;
proofn_task : Task.task; proofn_task : Task.task;
proofn_parent : proof_parent; proofn_parent : proof_parent;
proofn_attempts : proof_attempt_node Hprover.t; proofn_attempts : proof_attempt_node Hprover.t;
...@@ -118,18 +119,30 @@ let remove_proof_attempt (s : session) (id : proofNodeID) ...@@ -118,18 +119,30 @@ let remove_proof_attempt (s : session) (id : proofNodeID)
let pn = get_proofNode s id in let pn = get_proofNode s id in
Hprover.remove pn.proofn_attempts prover Hprover.remove pn.proofn_attempts prover
(* [mk_proof_node s t p id] register in the session [s] a proof node (* [mk_proof_node s n t p id] register in the session [s] a proof node
of proofNodeID [id] of parent [p] of task [t] *) of proofNodeID [id] of parent [p] of task [t] *)
let mk_proof_node (s : session) (t : Task.task) (parent : proof_parent) let mk_proof_node (s : session) (n : Ident.ident) (t : Task.task)
(node_id : proofNodeID) = (parent : proof_parent) (node_id : proofNodeID) =
let pn = { proofn_task = t; proofn_parent = parent; let pn = { proofn_name = n;
proofn_task = t;
proofn_attempts = Hprover.create 7; proofn_attempts = Hprover.create 7;
proofn_transformations = []} in proofn_transformations = []} in
Hint.add s.proofNode_table node_id pn Hint.add s.proofNode_table node_id pn
let mk_transf_proof_node (s : session) (tid : int) (t : Task.task) = let mk_proof_node_no_task (s : session) (n : Ident.ident)
mk_proof_node s n None parent node_id
let mk_proof_node_task (s : session) (t : Task.task)
let name,_,_ = Termcode.goal_expl_task ~root:false t in
mk_proof_node s name t parent node_id
(t : Task.task) =
let id = gen_proofNodeID s in let id = gen_proofNodeID s in
mk_proof_node s t (Trans tid) id; mk_proof_node_task s t (Trans tid) id;
id id
let mk_transf_node (s : session) (id : proofNodeID) (node_id : transID) let mk_transf_node (s : session) (id : proofNodeID) (node_id : transID)
...@@ -322,7 +335,9 @@ let read_file_session_and_shapes dir xml_filename = ...@@ -322,7 +335,9 @@ let read_file_session_and_shapes dir xml_filename =
[g] of nodeID [id] into the session [s] *) [g] of nodeID [id] into the session [s] *)
let rec load_goal session old_provers parent g id = let rec load_goal session old_provers parent g id =
match g.Xml.name with match g.Xml.name with
| "goal" -> mk_proof_node session None parent id; | "goal" ->
let gname = load_ident g in
mk_proof_node_no_task session gname parent id;
List.iter (load_proof_or_transf session old_provers id) g.Xml.elements; List.iter (load_proof_or_transf session old_provers id) g.Xml.elements;
| "label" -> () | "label" -> ()
| s -> | s ->
