Une nouvelle version du portail de gestion des comptes externes sera mise en production lundi 09 août. Elle permettra d'allonger la validité d'un compte externe jusqu'à 3 ans. Pour plus de détails sur cette version consulter : https://doc-si.inria.fr/x/FCeS
Commit 92165a83 authored by François Bobot's avatar François Bobot
prover identification: use shortcuts
   shortcuts are defined in why3.conf. They are automatically
   generated using two mechanism:
   - a shortcut section in prover-detection-data.conf creates a shortcut
   for the first prover that match the regexp
   - the identifier used as family argument for the prover section in
   prover-detection-data.conf is used as shortcut for the prover. If
   different sections use the same argument the first one that match an
   existing prover is used for the shortcut.
parent 5a3641ec
......@@ -87,10 +87,10 @@ bad_programs () {
valid_goals () {
for f in $1/*.mlw; do
echo -n " "$f"... "
if $pgml -L modules -t 10 -P Alt-Ergo $f | grep -q -v Valid; then
if $pgml -L modules -t 10 -P alt-ergo $f | grep -q -v Valid; then
echo "valid test $f failed!"
echo "$pgml -P alt-ergo $f"
exit 1
else
echo "ok"
......@@ -306,3 +306,7 @@ command = "emacs23 --eval \"(setq coq-load-path '((\\\"%l/coq\\\" \\\"Why3\\\"))
[editor altgr-ergo]
name = "AltGr-Ergo"
command = "altgr-ergo %f"
[shortcut shortcut1]
name="Alt-Ergo"
shortcut="altergo"
......@@ -3,7 +3,7 @@ Require Export ZArith.
Open Scope Z_scope.
Require Export List.
Ltac ae := why3 "Alt-Ergo".
Ltac ae := why3 "alt-ergo".
Section S0.
Variable a:Set->Set.
......@@ -1108,7 +1108,7 @@ let tr_top_decl = function
| _, Lib.FrozenState _ -> ()
let pr_fp fp =
pr_str (Pp.string_of_wnl Whyconf.print_filter_prover_no_regexp fp)
pr_str (Pp.string_of_wnl Whyconf.print_filter_prover fp)
let why3tac ?(timelimit=timelimit) s gl =
(* print_dep Format.err_formatter; *)
......@@ -126,12 +126,45 @@ let load rc =
let tps = List.fold_left (cons (load_prover ITP)) atps itps in
tps
let load_prover_shortcut acc (_, section) =
let name = get_string section "name" in
let version = get_stringo section "version" in
let altern = get_stringo section "alternative" in
let shortcuts = get_stringl section "shortcut" in
let fp = mk_filter_prover ?version ?altern name in
List.fold_left (fun acc shortcut ->
(fp,shortcut)::acc
) acc shortcuts
type env =
(** memoization of (exec_name,version_switch)
-> Some output | None doesn't exists *)
prover_output : ((string * string),string option) Hashtbl.t;
(** existing executable table:
exec_name -> | Some prover_config unknown version (neither good or bad)
| None there is a good version *)
prover_unknown_version : (string, config_prover option) Hashtbl.t;
(** string -> prover *)
prover_shortcuts : (string, prover) Hashtbl.t;
mutable possible_prover_shortcuts : (filter_prover * string) list;
let create_env shortcuts =
{ prover_output = Hashtbl.create 10;
prover_unknown_version = Hashtbl.create 10;
prover_shortcuts = Hashtbl.create 5;
possible_prover_shortcuts = shortcuts;
let read_auto_detection_data main =
let filename = Filename.concat (Whyconf.datadir main)
"provers-detection-data.conf" in
try
let rc = Rc.from_file filename in
List.rev (load rc)
let shortcuts =
List.fold_left load_prover_shortcut [] (get_family rc "shortcut") in
List.rev (load rc), create_env shortcuts
| Failure "lexing" ->
Loc.errorm "Syntax error in provers-detection-data.conf@."
......@@ -174,21 +207,6 @@ let sanitize_exec =
in
sanitizer first rest
type env =
let create_env () =
prover_unknown_version = Hashtbl.create 10 }
let ask_prover_version exec_name version_switch =
let out = Filename.temp_file "out" "" in
let cmd = sprintf "%s %s" exec_name version_switch in
......@@ -255,6 +273,19 @@ let add_prover_with_uniq_id prover provers =
let prover = {prover with Wc.prover = prover_id} in
Mprover.add prover_id prover provers
let add_prover_shortcuts env prover =
let rec aux = function
| (fp,s)::l when filter_prover fp prover ->
Hashtbl.replace env.prover_shortcuts s prover;
aux l
| a::l -> a::(aux l) in
env.possible_prover_shortcuts <- aux env.possible_prover_shortcuts
let add_id_prover_shortcut env id prover =
if not (Hashtbl.mem env.prover_shortcuts id) then
Hashtbl.replace env.prover_shortcuts id prover
let detect_exec env main data acc exec_name =
let s = ask_prover_version env exec_name data.version_switch in
match s with
......@@ -318,6 +349,8 @@ let detect_exec env main data acc exec_name =
(def_option (if old then " (it is an old version)." else ", Ok.")
data.message);
known_version env exec_name;
add_prover_shortcuts env prover;
add_id_prover_shortcut env data.prover_id prover;
add_prover_with_uniq_id prover_config acc
else (unknown_version env exec_name prover_config; acc)
......@@ -338,23 +371,32 @@ let detect_unknown env detected =
add_prover_with_uniq_id prover_config acc)
env.prover_unknown_version detected
let convert_shortcuts env =
Hashtbl.fold (fun s p acc ->
Mstr.add s p acc
) env.prover_shortcuts Mstr.empty
let run_auto_detection config =
let main = get_main config in
let l = read_auto_detection_data main in
let env = create_env () in
let detect = List.fold_left (detect_prover env main) Mprover.empty l in
let length_detected = Mprover.cardinal detect in
let detect = detect_unknown env detect in
let length_unsupported_version = Mprover.cardinal detect - length_detected in
let l,env = read_auto_detection_data main in
let detected = List.fold_left (detect_prover env main) Mprover.empty l in
let length_detected = Mprover.cardinal detected in
let detected = detect_unknown env detected in
Mprover.cardinal detected - length_detected in
eprintf
"%d provers detected and %d provers detected with unsupported version@."
length_detected length_unsupported_version;
set_provers (set_editors config (read_editors main)) detect
let shortcuts = convert_shortcuts env in
let config = set_editors config (read_editors main) in
let config = set_prover_shortcuts config shortcuts in
let config = set_provers config detected in
config
let list_prover_ids () =
let config = default_config "/dev/null" in
let l,_ = read_auto_detection_data main in
let s = List.fold_left (fun s p -> Sstr.add p.prover_id s) Sstr.empty l in
Sstr.elements s
......@@ -374,12 +416,20 @@ let get_altern id path =
let alt = Filename.basename path in
get_suffix id alt
let add_existing_shortcuts env shortcuts =
let aux shortcut prover =
Hashtbl.replace env.prover_shortcuts shortcut prover;
List.filter (fun (_,s) -> s = shortcut) env.possible_prover_shortcuts
in
Mstr.iter aux shortcuts
let add_prover_binary config id path =
add_existing_shortcuts env (get_prover_shortcuts config);
let l = List.filter (fun p -> p.prover_id = id) l in
if l = [] then Loc.errorm "Unknown prover id: %s" id;
(fun acc data -> detect_exec env main data acc path) Mprover.empty l in
......@@ -399,4 +449,7 @@ let add_prover_binary config id path =
let p = {p with prover = prover_id} in
add_prover_with_uniq_id p provers in
let provers = Mprover.fold fold detected provers in
set_provers config provers
let config = set_provers config provers in
config
......@@ -201,6 +201,7 @@ type config = {
config : Rc.t;
main : main;
provers : config_prover Mprover.t;
prover_shortcuts : prover Mstr.t;
editors : config_editor Meditor.t;
provers_upgrade_policy : prover_upgrade_policy Mprover.t;
......@@ -250,6 +251,19 @@ let set_provers rc provers =
let family = Mprover.fold set_prover provers [] in
set_family rc "prover" family
let set_prover_shortcut shortcut prover family =
let section = empty_section in
let section = set_string section "name" prover.prover_name in
let section = set_string section "version" prover.prover_version in
let section =
set_string ~default:"" section "alternative" prover.prover_altern in
let section = set_string section "shortcut" shortcut in
("definition", section)::family
let set_prover_shortcuts rc shortcuts =
let family = Mstr.fold set_prover_shortcut shortcuts [] in
set_family rc "shortcut" family
let set_editor id editor (ids, family) =
if Sstr.mem id ids then raise NonUniqueId;
......@@ -312,6 +326,20 @@ let load_prover dirname provers (_,section) =
extra_drivers = [];
} provers
let load_shortcut acc (_,section) =
let version = get_string section "version" in
let altern = get_string ~default:"" section "alternative" in
let prover = { prover_name = name;
prover_version = version;
prover_altern= altern} in
if shortcut.[0] = '^' then
invalid_arg "prover shortcut can't start with a ^";
Mstr.add shortcut prover acc
) acc shortcuts
let load_editor editors (id, section) =
Meditor.add id
{ editor_name = get_string ~default:id section "name";
......@@ -384,6 +412,8 @@ let get_config (filename,rc) =
in
let provers = get_family rc "prover" in
let provers = List.fold_left (load_prover dirname) Mprover.empty provers in
let shortcuts = get_family rc "shortcut" in
let shortcuts = List.fold_left load_shortcut Mstr.empty shortcuts in
let editors = get_family rc "editor" in
let editors = List.fold_left load_editor Meditor.empty editors in
let policy = get_family rc "uninstalled_prover" in
......@@ -392,6 +422,7 @@ let get_config (filename,rc) =
config = rc;
main = main;
provers = provers;
editors = editors;
provers_upgrade_policy = policy;
......@@ -414,31 +445,31 @@ let read_config conf_file =
raise (ConfigFailure (fst filenamerc, Buffer.contents b))
(** filter prover *)
type regexp_desc = { reg : Str.regexp; desc : string}
let mk_regexp s = { reg = why3_regexp_of_string s; desc = s}
type filter_prover =
{ filter_name : Str.regexp; filter_desc_name : string;
filter_version : Str.regexp; filter_desc_version : string;
filter_altern : Str.regexp; filter_desc_altern : string;
{ filter_name : regexp_desc;
filter_version : regexp_desc option;
filter_altern : regexp_desc option;
let mk_filter_prover ?(version="^") ?(altern="^") ~name =
let reg = why3_regexp_of_string in
{ filter_name = reg name ; filter_desc_name = name;
filter_version = reg version ; filter_desc_version = version;
filter_altern = reg altern ; filter_desc_altern = altern}
let mk_filter_prover ?version ?altern name =
begin match version with
| Some "" -> invalid_arg "mk_filter_prover: version can't be an empty string"
| _ -> () end;
{ filter_name = mk_regexp name;
filter_version = option_map mk_regexp version;
filter_altern = option_map mk_regexp altern;
let print_filter_prover fmt fp =
fprintf fmt "%s,%s,%s"
fp.filter_desc_name fp.filter_desc_version fp.filter_desc_altern
let print_filter_prover_no_regexp fmt fp =
let all s = s = "^" in
fprintf fmt "%s%s%s"
fp.filter_desc_name
(if all fp.filter_desc_version then
(if all fp.filter_desc_altern then "" else ",")
else "," ^ fp.filter_desc_version)
else ("," ^ fp.filter_desc_altern))
match fp.filter_version, fp.filter_altern with
| None , None -> fprintf fmt "%s" fp.filter_name.desc
| Some v, None -> fprintf fmt "%s,%s" fp.filter_name.desc v.desc
| None , Some a -> fprintf fmt "%s,,%s" fp.filter_name.desc a.desc
| Some v, Some a -> fprintf fmt "%s,%s,%s" fp.filter_name.desc v.desc a.desc
exception ProverNotFound of config * filter_prover
exception ProverAmbiguity of config * filter_prover * config_prover Mprover.t
......@@ -446,46 +477,42 @@ exception ParseFilterProver of string
let parse_filter_prover s =
let sl = Util.split_string_rev s ',' in
let match_all = Str.regexp "" in
(* reverse order *)
match sl with
| [name] ->
{filter_name = reg name ; filter_desc_name = name;
filter_version = match_all ; filter_desc_version = "^";
filter_altern = match_all ; filter_desc_altern = "^"}
| [version;name] ->
| [altern;"";name] ->
| [altern;version;name] ->
| [name] -> mk_filter_prover name
| [version;name] -> mk_filter_prover ~version name
| [altern;"";name] -> mk_filter_prover ~altern name
| [altern;version;name] -> mk_filter_prover ~version ~altern name
| _ -> raise (ParseFilterProver s)
let filter_prover fp p =
let check schema s = Str.string_match schema s 0 in
check fp.filter_name p.prover_name
&& check fp.filter_version p.prover_version
&& check fp.filter_altern p.prover_altern
let check s schema = Str.string_match schema.reg s 0 in
check p.prover_name fp.filter_name
&& option_apply true (check p.prover_version) fp.filter_version
&& option_apply true (check p.prover_altern) fp.filter_altern
let filter_provers whyconf fp =
Mprover.filter (fun p _ -> filter_prover fp p) whyconf.provers
let filter_one_prover config fp =
let provers = Mprover.filter (fun k _ -> filter_prover fp k)
config.provers in
try
if fp.filter_version = None && fp.filter_altern = None then
let prover = (Mstr.find fp.filter_name.desc whyconf.prover_shortcuts) in
try
let prover_config = Mprover.find prover whyconf.provers in
Mprover.singleton prover prover_config
with Not_found ->
(** shortcut send to nothing *)
Mprover.empty
else raise Not_found
with Not_found ->
let filter_one_prover whyconf fp =
let provers = filter_provers whyconf fp in
if Mprover.is_num_elt 1 provers then
snd (Mprover.choose provers)
else if Mprover.is_empty provers then
raise $ ProverNotFound (config,fp)
raise $ ProverNotFound (whyconf,fp)
else
raise $ ProverAmbiguity (config,fp,provers)
raise $ ProverAmbiguity (whyconf,fp,provers)
(** merge config *)
......@@ -504,13 +531,9 @@ let merge_config config filename =
(** modify provers *)
let create_filter_prover section =
let version = get_string ~default:"^" section "version" in
let altern = get_string ~default:"^" section "alternative" in
{ filter_name = why3_regexp_of_string name;
filter_version = why3_regexp_of_string version;
filter_altern = why3_regexp_of_string altern;
filter_desc_name = ""; filter_desc_version = ""; filter_desc_altern = "";
} in
let prover_modifiers = get_family rc "prover_modifiers" in
List.map (fun (_,sec) -> create_filter_prover sec, sec) prover_modifiers in
......@@ -551,6 +574,7 @@ let save_config config =
let get_main config = config.main
let get_provers config = config.provers
let get_prover_shortcuts config = config.prover_shortcuts
let get_policies config = config.provers_upgrade_policy
let get_prover_upgrade_policy config p =
Mprover.find p config.provers_upgrade_policy
......@@ -567,6 +591,12 @@ let set_provers config provers =
provers = provers;
let set_prover_shortcuts config shortcuts =
{config with
config = set_prover_shortcuts config.config shortcuts;
let set_editors config editors =
{ config with
config = set_editors config.config editors;
......@@ -626,10 +656,10 @@ let () = Exn_printer.register (fun fmt e -> match e with
| NonUniqueId ->
Format.fprintf fmt "InternalError : two provers share the same id"
| ProverNotFound (config,fp) ->
fprintf fmt "No prover in %s corresponds to %a@."
fprintf fmt "No prover in %s corresponds to \"%a\"@."
(get_conf_file config) print_filter_prover fp
| ProverAmbiguity (config,fp,provers ) ->
fprintf fmt "More than one prover in %s correspond to %a: %a@."
fprintf fmt "More than one prover@ in %s@ correspond@ to \"%a\":@ %a@."
(Pp.print_iter2 Mprover.iter Pp.space Pp.nothing print_prover Pp.nothing)
provers
......@@ -129,6 +129,12 @@ val set_provers : config -> config_prover Mprover.t -> config
val is_prover_known : config -> prover -> bool
(** test if a prover is detected *)
val get_prover_shortcuts : config -> prover Mstr.t
(** return the prover shortcuts *)
val set_prover_shortcuts : config -> prover Mstr.t -> config
(** set the prover shortcuts *)
type config_editor = {
editor_name : string;
editor_command : string;
......@@ -173,14 +179,11 @@ val set_policies : config -> prover_upgrade_policy Mprover.t -> config
type filter_prover
val mk_filter_prover :
?version:string -> ?altern:string -> name:string -> filter_prover
?version:string -> ?altern:string -> (* name *) string -> filter_prover
val print_filter_prover :
Format.formatter -> filter_prover -> unit
val print_filter_prover_no_regexp :
val parse_filter_prover : string -> filter_prover
(** parse the string representing a filter_prover:
- "name,version,altern"
