Commit 8fc6fcff authored by MARCHE Claude's avatar MARCHE Claude
fixed CHANGES
check if driver failed to load in use_api.ml
parent 75f9e888
......@@ -2,8 +2,10 @@
o WhyML with mutable record fields and type models
o why3replayer
* "logic" is not a keyword anymore, use "function" and "predicate"
* "parameter" keyword renamed to "val"
* new syntax for conjunction (/\) and disjunction (\/)
("and" and "or" do not exist anymore)
* functions to create an environment are now exported from Env
o [IDE] bug 12244 resolved by using Task.task_equal
o fixed Alt-ergo output: no triggers for "exists" quantifier
......@@ -89,7 +89,12 @@ let env : Env.env =
(* loading the Alt-Ergo driver *)
let alt_ergo_driver : Driver.driver =
Driver.load_driver env alt_ergo.Whyconf.driver
try
with e ->
eprintf "Failed to load driver for alt-ergo: %a@."
Exn_printer.exn_printer e;
exit 1
(* call Alt-Ergo *)
let result1 : Call_provers.prover_result =
Supports Markdown
