Mise à jour terminée. Pour connaître les apports de la version 13.8.4 par rapport à notre ancienne version vous pouvez lire les "Release Notes" suivantes :
https://about.gitlab.com/releases/2021/02/11/security-release-gitlab-13-8-4-released/
https://about.gitlab.com/releases/2021/02/05/gitlab-13-8-3-released/
Commit 8ed16ca6 authored by Sylvain Dailler's avatar Sylvain Dailler
Work with Clement to add a cursor for proved part of a proof tree.
Added proof_state and functions to control it in controller_itp.
Tried to add a test case for it inside the command p to put a big
P next to a goal that is proved.
It is currently buggy. Needs investigating and cleaning.
parent e9cdc398
......@@ -25,26 +25,90 @@ let print_status fmt st =
| InternalFailure e -> fprintf fmt "InternalFailure(%a)" Exn_printer.exn_printer e
type transformation_status =
| TSscheduled | TSdone | TSfailed
| TSscheduled | TSdone of transID | TSfailed
let print_trans_status fmt st =
match st with
| TSscheduled -> fprintf fmt "TScheduled"
| TSdone -> fprintf fmt "TSdone"
| TSdone tid -> fprintf fmt "TSdone" (* TODO print tid *)
| TSfailed -> fprintf fmt "TSfailed"
open Ident
type proof_state = {
th_state: bool Hid.t;
tn_state: bool Htn.t;
pn_state : bool Hpn.t;
let init_proof_state () =
{th_state = Hid.create 7;
tn_state = Htn.create 42;
pn_state = Hpn.create 42}
type controller =
{ mutable controller_session : Session_itp.session;
proof_state : proof_state;
controller_env : Env.env;
controller_provers : (Whyconf.config_prover * Driver.driver) Whyconf.Hprover.t;
let create_controller env s = {
controller_session = s;
proof_state = init_proof_state ();
controller_env = env;
controller_provers = Whyconf.Hprover.create 7;
let find_tn c tid =
try Htn.find c.proof_state.tn_state tid with
| Not_found -> false
let find_pn c id =
try Hpn.find c.proof_state.pn_state id with
| Not_found -> false
(* Update the result of the theory according to its children *)
let update_theory th ps =
let goals = theory_goals th in
Hid.replace ps.th_state (theory_name th)
(List.for_all (fun id -> Hpn.find ps.pn_state id) goals)
let rec propagate_proof c (id: Session_itp.proofNodeID) =
let tr_list = get_transformations c.controller_session id in
let new_state = List.exists (fun id -> find_tn c id) tr_list in
if new_state != find_pn c id then
begin
Hpn.replace c.proof_state.pn_state id new_state;
update_proof c id
and propagate_trans c (tid: Session_itp.transID) =
let proof_list = get_sub_tasks c.controller_session tid in
let cur_state = find_tn c tid in
let new_state = List.for_all (fun id -> find_pn c id) proof_list in
if cur_state != new_state then
begin
Htn.replace c.proof_state.tn_state tid new_state;
propagate_proof c (get_trans_parent c.controller_session tid)
and update_proof c id =
match get_proof_parent c.controller_session id with
| Theory th -> update_theory th c.proof_state
| Trans tid -> propagate_trans c tid
(* [update_proof_node c id b] Update the whole proof_state
of c according to the result (id, b) *)
let update_proof_node c id b =
Hpn.replace c.proof_state.pn_state id b;
update_proof c id
(* [update_trans_node c id b] Update the proof_state of c to take the result of (id,b). Then
propagates it to its parents *)
let update_trans_node c id b =
Htn.replace c.proof_state.tn_state id b;
propagate_proof c (get_trans_parent c.controller_session id)
module type Scheduler = sig
......@@ -136,19 +200,28 @@ let run_timeout_handler () =
S.timeout ~ms:125 timeout_handler;
let schedule_proof_attempt c id pr ~limit ~callback =
let schedule_proof_attempt_r c id pr ~limit ~callback =
graft_proof_attempt c.controller_session id pr ~timelimit:5;
Queue.add (c,id,pr,limit,callback) scheduled_proof_attempts;
callback Scheduled;
let schedule_transformation c id name args ~callback =
let callback s = (match s with
| Done pr -> update_proof_node c id true
| Interrupted | InternalFailure _ -> update_proof_node c id false
| _ -> ());
callback s
in
schedule_proof_attempt_r c id pr ~limit:limit ~callback:callback
let schedule_transformation_r c id name args ~callback =
let apply_trans () =
let task = get_task c.controller_session id in
try
let subtasks = Trans.apply_transform_args name c.controller_env args task in
let _tid = graft_transf c.controller_session id name args subtasks in
callback TSdone;
let tid = graft_transf c.controller_session id name args subtasks in
callback (TSdone tid);
false
with e when not (Debug.test_flag Debug.stack_trace) ->
Format.eprintf
......@@ -160,6 +233,13 @@ let schedule_transformation c id name args ~callback =
S.idle ~prio:0 apply_trans;
callback TSscheduled
| TSdone tid -> update_trans_node c tid false (*(get_sub_tasks c.controller_session tid = [])*) (* TODO need to change schedule transformation to get the id ? *)
| TSfailed -> ()
| _ -> ()); callback s in
schedule_transformation_r c id name args ~callback:callback
let read_file env ?format fn =
let theories = Env.read_file Env.base_language env ?format fn in
let ltheories =
......@@ -23,7 +23,7 @@ type proof_attempt_status =
val print_status : Format.formatter -> proof_attempt_status -> unit
type transformation_status = TSscheduled | TSdone | TSfailed
type transformation_status = TSscheduled | TSdone of transID | TSfailed
val print_trans_status : Format.formatter -> transformation_status -> unit
......@@ -51,14 +51,36 @@ module type Scheduler = sig
open Ident
(** Correspondance between a node of the proof tree
and its state (proved or not) *)
type controller = private
val create_controller : Env.env -> Session_itp.session -> controller
(** [update_proof_node c id b] Update the whole proof_state
val update_proof_node: controller -> Session_itp.proofNodeID -> bool -> unit
(** [update_trans_node c id b] Update the whole proof_state of c
according to the result (id,b) *)
val update_trans_node: controller -> Session_itp.transID -> bool -> unit
(** Used to find if a proof node is proved or not TODO remove *)
val find_pn: controller -> Session_itp.proofNodeID -> bool
module Make(S : Scheduler) : sig
val schedule_proof_attempt :
......@@ -57,6 +57,23 @@ type file = {
file_theories : theory list;
module Proofnodeid = struct
type t = proofNodeID
let compare (x : proofNodeID) y = Pervasives.compare x y
let equal (x : proofNodeID) y = x = y
let hash (x : proofNodeID) = x
module Transid = struct
type t = transID
let compare (x : transID) y = Pervasives.compare x y
let equal (x : transID) y = x = y
let hash (x : transID) = x
module Hpn = Exthtbl.Make(Proofnodeid)
module Htn = Exthtbl.Make(Transid)
type session = {
proofNode_table : proof_node Hint.t;
mutable next_proofNodeID : int;
......@@ -67,6 +84,17 @@ type session = {
session_prover_ids : int Hprover.t;
(* TODO replace *)
let init_Hpn (s : session) (h: 'a Hpn.t) (d: 'a) : unit =
Hint.iter (fun k _pn -> Hpn.replace h k d) s.proofNode_table
let init_Htn (s : session) (h: 'a Htn.t) (d: 'a) : unit =
Hint.iter (fun k _pn -> Htn.replace h k d) s.trans_table
let session_iter_proofNode f s =
Hint.iter
(fun id pn -> if id < s.next_proofNodeID then f pn)
......@@ -17,6 +17,11 @@ unique identifiers of type [proofNodeId]
type session
type proofNodeID
type transID
module Hpn: Exthtbl.S with type key = proofNodeID
module Htn: Exthtbl.S with type key = transID
type theory
......@@ -49,7 +54,6 @@ type proof_attempt = {
proof_obsolete : bool;
proof_script : string option; (* non empty for external ITP *)
type transID
type proof_parent = Trans of transID | Theory of theory
......@@ -365,8 +365,16 @@ let rec print_proof_node s (fmt: Format.formatter) p =
| Some pn -> pn = p
| _ -> false
in
(* TODO proved or not to be done on the whole tree. Just a test *)
let is_proved () =
match is_goal_cursor () with
| Some p -> Controller_itp.find_pn cont p
| _ -> false
in
if current_goal then
fprintf fmt "**";
if is_proved () then
fprintf fmt "P";
fprintf fmt
"@[<hv 2> Goal %s; parent %s;@ @[<hov 2>[%a]@]@ @[<hov 2>[%a]@]@]"
......@@ -483,7 +491,7 @@ let test_transform_and_display fmt args =
fprintf fmt "transformation status: %a@."
Controller_itp.print_trans_status status;
match status with
| TSdone -> (ignore (move_to_goal_ret next_node);
| TSdone tid -> (ignore (move_to_goal_ret next_node);
test_print_goal fmt [])
| _ -> ()
in
