Commit 8e1de5b1 authored by Sylvain Dailler's avatar Sylvain Dailler
ce: printer_mapping's list_projections is now a string -> ident map
The projection is now recorded with its ident which allow us to rewrite
the projections in counterexamples. We use the id_string which is only an
approximation of what can be seen in the task (but it is close enough).
parent 8ed7c5ec
...@@ -34,6 +34,10 @@ IDE ...@@ -34,6 +34,10 @@ IDE
now generates counterexamples now generates counterexamples
* added support for GTK3 * added support for GTK3
Counterexamples
* Field names now use ident names instead of smt generated ones:
int32qtint -> int32'int
Provers Provers
* support for Z3 4.8.1 (released Oct 16, 2018) * support for Z3 4.8.1 (released Oct 16, 2018)
* support for Z3 4.8.3 (released Nov 20, 2018) * support for Z3 4.8.3 (released Nov 20, 2018)
This diff is collapsed.
...@@ -6,28 +6,28 @@ Line 5: ...@@ -6,28 +6,28 @@ Line 5:
r, [[@mlw:reference_var], [@introduced], r, [[@mlw:reference_var], [@introduced],
[@field:0:contents]] = {"type" : "Record" , [@field:0:contents]] = {"type" : "Record" ,
"val" : {"Field" : [{"field" : "contents" , "val" : {"Field" : [{"field" : "contents" ,
"value" : {"proj_name" : "int32qtint" , "type" : "Proj" , "value" : {"proj_name" : "int32'int" , "type" : "Proj" ,
"value" : {"type" : "Integer" , "value" : {"type" : "Integer" ,
"val" : "22" } } }] } } "val" : "22" } } }] } }
Line 7: Line 7:
r, [[@mlw:reference_var], [@introduced], [@field:0:contents], r, [[@mlw:reference_var], [@introduced], [@field:0:contents],
[@model_trace:r]] = {"type" : "Record" , [@model_trace:r]] = {"type" : "Record" ,
"val" : "84" } } }] } } "val" : "84" } } }] } }
Line 8: Line 8:
"val" : "42" } } }] } } "val" : "42" } } }] } }
Line 9: Line 9:
Line 7: Line 7:
Line 8: Line 8:
Line 9: Line 9:
Line 7: Line 7:
Line 8: Line 8:
Line 9: Line 9:
Line 7: Line 7:
Line 8: Line 8:
Line 9: Line 9:
...@@ -2,45 +2,45 @@ Strongest Postcondition ...@@ -2,45 +2,45 @@ Strongest Postcondition
bench/ce/jlamp_array.mlw Array VC f: Timeout or Unknown bench/ce/jlamp_array.mlw Array VC f: Timeout or Unknown
Counter-example model:File jlamp_array.mlw: Counter-example model:File jlamp_array.mlw:
Line 11: Line 11:
two, [] = {"proj_name" : "to_int1" , "type" : "Proj" , two, [] = {"proj_name" : "to_int" , "type" : "Proj" ,
"val" : "2" } } "val" : "2" } }
Line 14: Line 14:
three, [] = {"proj_name" : "to_int1" , "type" : "Proj" , three, [] = {"proj_name" : "to_int" , "type" : "Proj" ,
"val" : "3" } } "val" : "3" } }
Line 18: Line 18:
a, [[@introduced]] = {"proj_name" : "to_int1" , "type" : "Proj" , a, [[@introduced]] = {"proj_name" : "to_int" , "type" : "Proj" ,
"value" : {"type" : "Integer" , "val" : "2" } } "value" : {"type" : "Integer" , "val" : "2" } }
Line 22: Line 22:
a, [[@introduced], [@model_trace:a]] = {"proj_name" : "to_int1" , a, [[@introduced], [@model_trace:a]] = {"proj_name" : "to_int" ,
"type" : "Proj" , "value" : {"type" : "Integer" , "type" : "Proj" , "value" : {"type" : "Integer" ,
Line 11: Line 11:
Line 14: Line 14:
"value" : {"type" : "Integer" , "val" : "3" } } "value" : {"type" : "Integer" , "val" : "3" } }
Line 18: Line 18:
a, [[@introduced], a, [[@introduced],
[@at:'Old:loc:location], [@at:'Old:loc:location],
[@at:'Old:loc:location] = {"proj_name" : "to_int1" , [@at:'Old:loc:location] = {"proj_name" : "to_int" ,
Line 21: Line 21:
three, [[@model_trace:three]] = {"proj_name" : "to_int1" , three, [[@model_trace:three]] = {"proj_name" : "to_int" ,
Line 22: Line 22:
...@@ -48,27 +48,27 @@ bench/ce/jlamp_array.mlw Array VC g: Valid ...@@ -48,27 +48,27 @@ bench/ce/jlamp_array.mlw Array VC g: Valid
bench/ce/jlamp_array.mlw Array VC g: Timeout or Unknown bench/ce/jlamp_array.mlw Array VC g: Timeout or Unknown
Line 11: Line 11:
Line 14: Line 14:
Line 24: Line 24:
Line 27: Line 27:
Line 28: Line 28:
...@@ -76,32 +76,32 @@ bench/ce/jlamp_array.mlw Array VC h: Valid ...@@ -76,32 +76,32 @@ bench/ce/jlamp_array.mlw Array VC h: Valid
bench/ce/jlamp_array.mlw Array VC h: Timeout or Unknown bench/ce/jlamp_array.mlw Array VC h: Timeout or Unknown
Counter-example model:File array.mlw: Counter-example model:File array.mlw:
Line 32: Line 32:
File jlamp_array.mlw: File jlamp_array.mlw:
Line 11: Line 11:
Line 14: Line 14:
Line 30: Line 30:
Line 33: Line 33:
Line 34: Line 34:
...@@ -2,45 +2,45 @@ Weakest Precondition ...@@ -2,45 +2,45 @@ Weakest Precondition
Line 11: Line 11:
Line 14: Line 14:
Line 18: Line 18:
Line 22: Line 22:
Line 11: Line 11:
Line 14: Line 14:
Line 18: Line 18:
Line 21: Line 21:
Line 22: Line 22:
Line 11: Line 11:
Line 14: Line 14:
Line 24: Line 24:
Line 27: Line 27:
Line 28: Line 28:
Line 32: Line 32:
Line 11: Line 11:
Line 14: Line 14:
Line 30: Line 30:
Line 33: Line 33:
Line 34: Line 34:
...@@ -2,11 +2,11 @@ Strongest Postcondition ...@@ -2,11 +2,11 @@ Strongest Postcondition
Line 11: Line 11:
Line 14: Line 14:
Line 22: Line 22:
...@@ -15,15 +15,15 @@ the check fails with all inputs ...@@ -15,15 +15,15 @@ the check fails with all inputs
Line 11: Line 11:
Line 14: Line 14:
